Old 03-18-2020, 02:53 PM   #1
timfleur
Drives: 2017 toyota GT 86
Need help on how to intall Spoiler
I just bought a spoiler a NRS Nur GTS Euro from ebay.
Does anyone know the best way to install this spoiler. I cant find any how to videos anywhere.
Do i just put it on with 3m tape or do i have to drill into my trunk.
I need help.
this is the spoiler here
https://i.ebayimg.com/images/g/OK4AA...M2/s-l1600.jpg
timfleur is offline   Reply With Quote
Old 03-18-2020, 03:00 PM   #2
Are there studs or bolt holes underneath? If so then break out the drill.
Old 03-18-2020, 03:04 PM   #3
timfleur
yes there are. The inside of the trunk is pretty thick tho. If i do that i will have to do some cutting as well i think.
That might be the best way i think.
Old 03-18-2020, 03:38 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you asked a shop how much they'd charge to install it? May be cheaper than potentially ruining your trunk and the spoiler!
I'll work on the engine all day, but when it comes to drilling holes into the body, I know I suck at measuring and pay to let someone else measure twice and cut once for me who has insurance behind them.
Old 03-18-2020, 03:55 PM   #5
ls1ac
ls1ac's Avatar
A shop should have some clever little devices that screw up into the nut holes. These have a point exposed. Put tape over the mounting area, place the wing carefully in position and exert down presser. If done correctly will transfer marks to the tape. Then drill. Putting double-sided tape will also help with waterproofing and possible vibration.
That large a wing will defiantly need bolts.
Old 03-18-2020, 04:06 PM   #6
timfleur
I will definitely take it to a shop instead. Ill let a pro handle it. i dont want to damage or break anything
Old 03-18-2020, 04:07 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I need help.
If you lack a spoiler and your new spoiler has bolts that line up with the stock holes then swap trunk lids with someone who has a stock spoiler. There is a lot of demand for his swap.
Old 03-19-2020, 05:58 PM   #8
mrhayes1
Drives: 2013 Scion FRS white
As said above by someone else, I also used tape and I put tape on my spoiler bolts and stuck it on the trunk and then when you lift up to remove the spoiler you can use the tape to see where you need to drill holes. I installed the stock 2013-2015 BRZ spoiler on my FRS and it is quite challenging. Drilling the holes was easy but when I put on the spoiler the bolts came out inside the thick part of the trunk and it was too hard to then screw the nuts on. I then used a big hole driller (3/4 inch) and put two large holes in the inside of my trunk to be able to get the nuts on. However, I didn't really care since I have a trunk liner cover that hides those large holes.
Point is, if you are not somewhat handy with this type of stuff def take it to a shop. Also, I looked up that spoiler on eBay and while I swear by 3m tape, that will most definitely not hold that spoiler as it is too large and there would just be too much leverage. However, you could probably just use 3m tape to attach a low duckbill spoiler and stuff like that. Also, as someone mentioned above, consider using 3m tape also. If you live in a very wet area I would consider having the shop add some touch up paint after they drill holes to prevent them from rusting out, but this is probably a bit overkill in most situations.
mrhayes1 is offline   Reply With Quote
Old 03-19-2020, 06:11 PM   #9
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
If you have any buddies that have been in factory labor/machining/metal fab for more than a few years they will likely have the skills to figure out what needs to be done. Depending on how much you trust them that might save some money. Just stay away from the "yo yo I got dis" guys.
NWFRS is offline   Reply With Quote
help me, help please, install, spoiler
Battle Aero Swan Neck Spoiler Paired W/ Rocket Bunny V2 Duck Bill Spoiler Preppy Cosmetic Modification (Interior/Exterior/Lighting) 30 02-10-2017 09:20 PM
Does the intake become audible after uel header intall? WhenzLunch BRZ First-Gen (2012+) — General Topics 8 02-17-2016 07:13 PM
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? FR-Sizzle Cosmetic Modification (Interior/Exterior/Lighting) 10 09-21-2015 02:29 PM
Boost gauge intall, where to cut? Sniper2606 Forced Induction 4 01-21-2014 03:05 PM
HSD coilovers intall in Super Street Stav CANADA 1 09-13-2013 05:27 PM
