Old 03-16-2020, 01:21 PM   #393
gtpvette
Drives: 2015 FRS - FFR GTM
Originally Posted by venturaII View Post
That's a slick setup! Nice work.
Thanks,,, it'll double as a Covid-19 isolation ward.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following 3 Users Say Thank You to gtpvette For This Useful Post:
mrg666 (03-17-2020), Sportsguy83 (03-16-2020), Ultramaroon (03-17-2020)
Old 03-16-2020, 07:42 PM   #394
gtpvette
Sanded with 1500,, buffed and installed. Fronts aren't done as the bumper isn't installed.
The Following 6 Users Say Thank You to gtpvette For This Useful Post:
Code Monkey (03-16-2020), Hypnocracy (03-20-2020), mrg666 (03-17-2020), Raven86Project (03-17-2020), Ultramaroon (03-17-2020), Zer0 (03-16-2020)
Old 03-17-2020, 01:21 AM   #395
Brilliant improvisation! I will steal that sometime, I'm sure.
Old 03-17-2020, 09:59 AM   #396
gtpvette
Booth has worked pretty well considering. Wasn't terribly expensive either, 1000' roll of pallet wrap $29, two harbor freight tarps $35 or so, 4 AC filters $15 and a roll of duct tape.
Garage would be better if for nothing else the comments and question regarding when is it coming down from the wife LOL.
I'm going to try and spray the scoop an underside of hood this afternoon. Tomorrow paint the top of the hood and the bumper emblem. At that point the booth can go away. She who must be obeyed will be pleased.
Old 03-17-2020, 10:45 AM   #397
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Hmm...not sure I knew you'd installed a hitch. What brand, and what have you hauled with it so far?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 03-17-2020, 11:42 AM   #398
toast
Drives: 14 BSP Edelbrock BRZ
Please recycle the pallet wrap! Home Depot will take up to 6 mil plastic film.
toast is offline   Reply With Quote
Old 03-17-2020, 12:09 PM   #399
gtpvette
Hummm,,, not sure I remember,, I think it was a U-Haul but not 100% sure. I do remember it bolted between the bumper bar and the chassis. I got it so I could put a trailer hitch carrier for a large cooler. First time I used it the carrier was scraping the ground as it was too low. I've modified the hitch adapter to fix that. Works great as the cooler I use wont fit in the car.
Didn't know they did that,,, thanks.
Old 03-17-2020, 10:22 PM   #400
Bummer. My wife painted the tank and side covers of her Honda Shadow before we met. I'm a super lucky bastard.
Old 03-17-2020, 10:49 PM   #401
gtpvette
You Sir Are My Hero.
Old 03-22-2020, 07:20 PM   #402
gtpvette
Paint is complete. Still need to sand and buff hood and scoop. Hoods got a lot of crap in the paint for some reason. We'll see what tomorrow brings with sanding and buffing. I also painted an aftermarket emblem for the front bumper. Wanted to shave it all together but the shape of the bumper really needs an emblem. Filled in the SCION. Not 100% sure I like it.
The Following User Says Thank You to gtpvette For This Useful Post:
Zer0 (03-23-2020)
Old 03-26-2020, 10:10 PM   #403
gtpvette
A few final shots of the paint work......
Old 03-27-2020, 11:16 AM   #404
venturaII
venturaII's Avatar
Man...I cannot wait to the see the finished product and watch/hear it run! And I'm soooo glad you went with a more traditional button flare than a huge Rocket Bunny type...that car is gonna look sharp.
The Following User Says Thank You to venturaII For This Useful Post:
gtpvette (03-27-2020)
Old 04-18-2020, 06:31 PM   #405
gtpvette
Work continues. Lots of small tasks to complete,, basically a punch list before I try to start. Tomorrow I'll finish up a few then pull the motor hopefully for the last time. The biggest tasks are install the clutch, crank pully and oil pan. I want to detail the engine compartment as it's been sitting open for over two years and there's a little paint work to do as well. I need to detail the motor as well. It's amazing what the salt air does to aluminum.
July this year will be three years,,, just dam.
- Fix Dipstick
x Shorten lower radiator hard line
x Weld in bung on hard line for surge tank supply
X Lengthen fuel hose
x Trace and confirm location VSS and E85 wires
X Install Gas Cap
x Install pressure switch for AC
X Fab AC Lines
x Resolve PCV Lines
- Install Puke Tank
x Install clutch remote bleed
Pull motor/trans
Tighten Engine Side Fuel Line
Paint Valve Covers - Maybe
Detail engine bay
Detail Motor
Paint front support and above headlights
Install/Seal oil pan & pickup tube
Install new clutch
Install crank pulley
Fab transmission dust shield
Replace VSS
Install motor/trans
Fill Transmission
Install Oil Filter - Oil
Water
Reinstall dash
The Following 2 Users Say Thank You to gtpvette For This Useful Post:
Sportsguy83 (04-19-2020), Ultramaroon (04-20-2020)
Old 06-21-2020, 06:20 PM   #406
gtpvette
Took a bit of time off the work to do some honey do's, back at it again. Started the detail of engine compartment. For all of my years, cant say I've really every done this before. Wet rag, tooth brush and compressed air work pretty well considering it's been sitting open for almost 3 years. The aluminum on the motor has some oxidation that I still need to address but generally just about done.
I've also come to the conclusion the oil pan is a bit too close (for comfort) to the sway bar. I had bought an additional Oil Pan some time back so spent some time working on it this weekend. First problem the pan was nasty,, and I do mean nasty. Opted to clean it up myself. Made a redneck hot tank and cooked it for 3-4 hours. Did pretty well but should of put more degreaser in it. Hit it with brake cleaner, small wire brush then pressure cleaned. All in all came out OK.
OK for the modification. The back of the sump is just too close. You can see in the picture the area 'X'ed, just need 3/4" or so and I'll be happy. Like to have it cut up this week and sent out for welding.
Mike_ZN6 (06-21-2020), venturaII (07-14-2020)
Should I have just got a new motor? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 12 07-31-2017 08:51 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
K2 Motor? Ronin Sascha Engine, Exhaust, Transmission 8 08-16-2014 07:51 PM
Does every motor say #1 sosick Engine, Exhaust, Transmission 21 05-05-2014 10:28 AM
MOTOR UNION David Southern California 0 06-22-2013 02:32 PM
