Old 03-16-2020, 09:49 AM   #43
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by QHawk View Post
Where do the illustrations that you posted come from?
The second post in the following thread has a link to the 2018 BRZ wiring diagrams. There may be some differences between years, etc. but these vehicles don't tend to change much.
http://www.ft86club.com/forums/showthread.php?t=137601
LimitedSlip is offline   Reply With Quote
Old 03-16-2020, 12:22 PM   #44
LimitedSlip
Originally Posted by FR-S2GT86 View Post
I’ll bet that a couple of the wires are in the wrong pin positions of either the male or female plug at that location and aren’t mating up to their respective male or female pins.
Perhaps when the wiring harness was being assembled the pins were not fully seated and didn't get locked down. When the two halves of HD2 were plugged together those pins slid partially out of HD2 instead of sliding together. We might be interested in pins 1 and 7 of HD2. Interestingly enough, those two pins are both on the same end of HD2.
The Following User Says Thank You to LimitedSlip For This Useful Post:
QHawk (03-16-2020)
Old 03-16-2020, 01:29 PM   #45
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Yes, that is also a possibility. I remember that Ford had some issues back in the early to mid 80’s on a handful of trucks and Broncos where two of their speaker wires were reversed according to the diagrams and we had to de-pin and correctly re-pin the OEM or aftermarket harnesses so that the speakers and wiring would properly match up and be in phase with each other. Mistakes at the factories can be made.
That HD2 plug would be easily accessible where it’s located to check those wires.
FR-S2GT86 is offline   Reply With Quote
Old 03-16-2020, 01:45 PM   #46
p1l0t
p1l0t's Avatar
If you try to fix it yourself, do not break anything and do not tell them you attempted to fix it yourself or they may just say it voids the warranty.
Tcoat (03-16-2020)
Old 03-16-2020, 01:54 PM   #47
LimitedSlip
For more info and a picture of HD2 check posts 11 and 12 of this thread:
http://www.ft86club.com/forums/showthread.php?t=85872
Old 03-16-2020, 08:37 PM   #48
Terrymcfadd
Terrymcfadd's Avatar
Drives: 2020 86 Hakone Edition
This guy leads me to believe the signal passes through the tweeter wiring to the door speaker. [ame]https://m.youtube.com/watch?v=fJzRDDDbM9w[/ame] . I’ve been sizing up the sound system for 2 weeks now. I took it to a sound shop today, and asked how he could appreciably improve on the 8 speaker system. He listened to lots of different music, adjusted the EQ many different ways, and surprised me in that:
- at higher volumes it came alive beyond what I thought it could
- it produces a lot of base but need to crank it (not bone slamming, teeth jarring, window shaking bass, mind you) but goes beyond my normal needs
- tweaking the EQ dialed in much better sound at lower volumes (12-15) Bass -3, mid -2, treb +2. I Might be able to live with this, surprised!
You should be getting noticeable bass out of the door speaker.
I’ve poured over the online manual, scoured the internet, asked the dealer for info, but cannot establish the rating of the HU or amp in terms of power. Will happily share any more that I discover.
Terrymcfadd is offline   Reply With Quote
Old 03-16-2020, 09:10 PM   #49
soundman98
ProCrastinationConsultant
soundman98's Avatar
this guy is an idiot that has no business owning a screwdriver, let alone telling anyone anything about audio. i stopped at 8 minutes. i can give you an itemized list of the things wrong up to that point, but it really is a waste of all of our time.
Old 03-16-2020, 09:27 PM   #50
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
I thought I was doing you a service by picking up at 8-minutes, but he's cutting apart the speaker cone with a box cutter like he's peeling an orange. 9:30 minutes in and he's mangling the crap out of it .. and there goes the cone...
ROFL it's Waffle is offline   Reply With Quote
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
soundman98 (03-16-2020)
Old 03-16-2020, 09:54 PM   #51
QHawk
QHawk's Avatar
Drives: 2020 86GT
The picture made the difference. I found the HD2, and it's properly connected. When the dealer corrects this problem, I'll be sure to get an explanation of what was wrong.
QHawk is offline   Reply With Quote
Old 03-16-2020, 10:03 PM   #52
soundman98
soundman98's Avatar
I try to be nice. I try to give people the benefit of the doubt. This guy just took that benefit, tied it to a string, and flew it like a kite.
Old 03-17-2020, 02:23 AM   #53
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Just a few minutes with a volt meter at that plug would tell you if you’ve got 12 volts coming in and going out on the two wires.
Old 03-17-2020, 04:16 PM   #54
QHawk
QHawk's Avatar
Drives: 2020 86GT
True. But you must be far more flexible than I am. I'll let the dealer's tech earn his money. I won't be paying him.
The Following User Says Thank You to QHawk For This Useful Post:
Tcoat (03-18-2020)
Old 03-17-2020, 04:54 PM   #55
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I hear ya’. I wish I were still as flexible as I used to be.
Old 03-18-2020, 10:03 AM   #56
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by jkwan View Post
From this thread: http://www.ft86club.com/forums/showthread.php?t=139286
It looks like a jumper is supposed to be used with this headunit. Any chance you can see if this is unplugged on your car?
tehShirt is offline   Reply With Quote
Door speakers not working after new head unit install lsr78 Electronics | Audio | NAV | Infotainment 17 04-27-2021 04:23 PM
WTB: 2020 Toyota 86 OEM Radio/Head Unit burgeralert Want-To-Buy Requests 7 08-16-2020 05:49 PM
MD: BRZ Head Unit + Speakers itsfun Audio/Visual, Electronics, Infotainment, NAV 2 04-06-2013 09:03 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 03:01 PM
