Old 03-14-2020, 11:11 PM   #67607
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Random Thoughts - Part Deux
you mentioned the car gets tracked, does the track generally have more left high-G turns?
Most tracks run counter clockwise and that is what I have been assuming was the issue. But I haven't met anyone else that is burning through hubs like this. I talk to almost every other 86 owner I come across at the track and have come across two other people that have replaced a right front, but that is it I didn't buy OEM hubs this time. If the cheap ones last a year I'll keep buying them at 65/ea. I have only had a few off track excursions in the last few years so I don't think it is from taking a beating and roads in my area are generally pothole free. I run a more track oriented alignment but I have made compromises for tire wear and I run stock wheels on the street so it can't be from running high offset wheels. I must be doing something wrong.
NoHaveMSG is offline
Old 03-14-2020, 11:39 PM   #67608
soundman98
ProCrastinationConsultant
soundman98's Avatar
bad batch maybe?
soundman98 is offline
Old 03-14-2020, 11:44 PM   #67609
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Strange.
Sapphireho is offline
Old 03-15-2020, 12:43 AM   #67610
Since I pulled the motor and tranny, she is running fantastic. One of my favorite machines I've ever owned.
Have you considered getting a retirement job in a deli - ?
humfrz is offline
Old 03-15-2020, 12:47 AM   #67611
Are you replacing the hubs yourself?
humfrz is offline
korhun (03-16-2020), NoHaveMSG (03-15-2020)
Old 03-15-2020, 01:03 AM   #67612
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
LOL thanks
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (03-15-2020), korhun (03-16-2020), Ultramaroon (03-15-2020)
Old 03-15-2020, 06:59 AM   #67613
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I would gain too much weight.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Old 03-15-2020, 07:28 AM   #67614
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Saw a twin yesterday. I think that makes 4 now.
humfrz (03-15-2020)
Old 03-15-2020, 07:56 AM   #67615
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I've just started watching the first episode of this. It has made me laugh a couple of times. A show that makes me laugh has to get high ratings from me.
[ame]https://www.youtube.com/watch?v=gczkM8cL2hs[/ame]
Senior Person: "What made you answer the phone?"
Junior: "Well, the phone was ringing and...I picked it up."
Senior Person: "Your logic escapes me."
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Old 03-15-2020, 09:36 AM   #67616
ls1ac
ls1ac's Avatar
Possible try disassembling the hub after a few hundred miles, check, re lube and reassemble. Sometimes bearings will seat a little further after running for a while. Might also verify torque wrench specks as sometimes they will change calibration. Also check spindle to make sure it has not been bent.
ls1ac is offline
The Following User Says Thank You to ls1ac For This Useful Post:
soundman98 (03-15-2020)
Old 03-15-2020, 12:21 PM   #67617
cjd
cjd's Avatar
Drives: 2017 BRZ
Front hubs are sealed bolt-on affairs. There's pretty much nothing you can do (which comes to mind, anyway) to damage it unless you're hammering on the axle. Also no real way to do preventative maintenance.
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
humfrz (03-15-2020)
Old 03-15-2020, 12:53 PM   #67618
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
bad batch maybe?
I am going to cut this one apart carefully and see if I can see what type of failure it is. Could be contamination, grease breakdown from heat, or just wear.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 03-15-2020, 12:59 PM   #67619
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Looking back on limited edition 86/BRZ. We had more than 20... if you count worldwide. That’s pretty good rec, I think.
ichitaka05 is offline
The Following 6 Users Say Thank You to ichitaka05 For This Useful Post:
Clutch Dog (03-15-2020), Dadhawk (03-15-2020), JD001 (03-15-2020), korhun (03-16-2020), NoHaveMSG (03-15-2020), Spuds (03-15-2020)
Old 03-15-2020, 01:44 PM   #67620
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
We have some pretty cool ones. and in classic scion branding those limited editions where way cool.
Im still upset that as far as subaru based we didnt get an "S209" or something special package. the highest performance we got was a BRZ TS, which I guess can be akin to the 14R scion.
I also wish the hakone came with the performance package. that woulda been rad.
( says the guy who bought two white 86s...)
Clutch Dog is offline
The Following 4 Users Say Thank You to Clutch Dog For This Useful Post:
Dadhawk (03-15-2020), ichitaka05 (03-15-2020), korhun (03-16-2020), Tcoat (03-15-2020)
