| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2016 Scion FR-S
30K Service: Clutch Bleed?
I just called the dealer about the 30K scheduled service and they want to bleed the clutch for like $130. I have read several threads on the 30k service and none mention this. I thought the 30k service was going to be basically just oil/filter change, brake fluid, air filter, and cabin filter.
The dealer also wants to do some fuel and oil additives for like $50 and $100 which seems like way too much. Is the clutch bleed part of the 30k service? The manual just says inspect clutch fluid at 30k. Has anyone else had the dealer suggest this as part of the 30k service? At what mileage do you typically need to bleed the clutch and change the clutch fluid? Last edited by Infinity; 03-13-2020 at 08:35 PM. |
#2 |
[insert cool phrase here]
Drives: BRZ Premium
What da funk $130 for that? Is that before or after a hand job?
Cause that's the only way I'll pay that much. I would tell them politely to fist their butt hole. Honestly if you want to pay that much I would go to any quickly lube place, at lest you'll get an oil change, all the fluids toped off, and/or a cheap interior vacuum.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | 0x56 (04-22-2020) |
#3 |
Drives: 2013 FR-S Series 10
In general, never do these services. Just bring your car in for your fluid changes and major items (spark plugs at 60k come to mind).
Bleeding the clutch is probably not necessary unless your slave cylinder has leaked at some point. If you want just pull out the old fluid with a syringe/baster and put new fluid in and call it a day.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | Infinity (03-13-2020) |
#4 | |
Drives: MDX, Camry
Sent from my Pixel 3 XL using Tapatalk |
#5 |
ProCrastinationConsultant
$130 doesn't sound too bad to me. i can reasonably see $85 for labor and $45 for shop materials.
i haven't met many people or companies that work for free.
| Clutch fluid won't bleed. | ML | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-19-2018 08:35 AM |
| DIY : How to bleed your brakes | justinco | DIY (Do-It-Yourself) Guides | 4 | 09-05-2017 02:40 PM |
| Valve/nipple (bleed?) next to clutch line? | BRZyJ | Engine, Exhaust, Transmission | 2 | 06-14-2017 12:28 AM |
| Clutch grinding. Need service recommendation | rhythmM | Southern California | 6 | 04-07-2016 06:16 AM |
| OAKOS/DVR Service Specials! Clutch Install $399! Timing Belt $199! St. Heights, MI | OAKOS Automotive | Great Lakes | 78 | 05-14-2015 12:10 PM |
