Old 03-09-2020, 11:02 AM   #67425
HaXx
Drives: jrsc_brz
Good call. You may drive the car forever and never get pulled over but their is no sense tempting a bored cop that has nothing better to do by waving a "pick me" flag at him.
i found a 10 pack for 10 bucks, they are called "t10" bulbs. on my bulb it says e6 12v 5w w5w, but i think the t10 is exactly the same. not much comes up when i search e6,so im not sure why it says that on my bulb, if it even means anything
https://www.amazon.com/Halogen-Repla...3765580&sr=8-6
HaXx is offline
Old 03-09-2020, 11:07 AM   #67426
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Received the quarterly update on my 401k this weekend. Immediately put it in the document shredder as I'm fairly certain I should save the money I would otherwise spend on booze if I read it.
ScoobsMcGee is offline
The Following 7 Users Say Thank You to ScoobsMcGee For This Useful Post:
Dadhawk (03-09-2020), daiheadjai (03-10-2020), humfrz (03-09-2020), soundman98 (03-09-2020), Spuds (03-09-2020), Tcoat (03-09-2020), wolffbite (03-09-2020)
Old 03-09-2020, 11:23 AM   #67427
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Usually searching [Year Model Location] "Bulb" works pretty well. You can always pay an extra few cents at the local auto parts store and just have them look it up for you to confirm fitment.
Spuds is offline
Old 03-09-2020, 11:23 AM   #67428
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Some fuckard try to use my username as a reference to scam member here! Just changing the last part thinking no one notice. Well FU!
Btw if you’re wondering what kind of PM it was, it was this:
ichitaka06 posted a TRD Lowering Springs 17+ for sale Some weeks ago. Here is her email.
ichitaka05 is offline
The Following 7 Users Say Thank You to ichitaka05 For This Useful Post:
korhun (03-09-2020), p1l0t (03-09-2020), ScoobsMcGee (03-09-2020), soundman98 (03-09-2020), Spuds (03-09-2020), Tcoat (03-09-2020), wolffbite (03-09-2020)
Old 03-09-2020, 11:31 AM   #67429
Well apparently #6 is a female so can't be you.
Tcoat is offline
ichitaka05 (03-09-2020), soundman98 (03-09-2020)
Old 03-09-2020, 11:34 AM   #67430
Any issues converting halogens to LEDs (assuming that's what you did)?
I've had no issues in the FRS, although the hi-beams are an issue as they are used for DRLs at half power but the LEDs are full power. Really isn't an issue during the day, and I always turn the lights on before it becomes a problem. I could just turn the DRLs off if it were.
Like @Tcoat says as long as you buy good quality ones intended as replacements, I haven't seen an issue. Lighting experts might disagree of course.
Dadhawk is offline
Spuds (03-09-2020)
Old 03-09-2020, 12:33 PM   #67431
p1l0t
p1l0t's Avatar
Oooh wait a female where?
p1l0t is offline
korhun (03-09-2020)
Old 03-09-2020, 12:37 PM   #67432
I would assume banned now.
Tcoat is offline
korhun (03-09-2020), soundman98 (03-09-2020)
Old 03-09-2020, 01:29 PM   #67433
Went to the boss's home for wine tasting this afternoon.Tried maybe 20 different wines, didn't spit many of them. I haven't been this drunk in a long time. Thing is, I remember I used to go out 2 maybe 3 times a week and get smashed anf only suffer a mild hang over the next day.
F*ck this getting old shit.
it was a wine tasting -
humfrz is offline
Tcoat (03-09-2020)
Old 03-09-2020, 01:32 PM   #67434
p1l0t
p1l0t's Avatar
Don't ban the women!
p1l0t is offline
korhun (03-09-2020)
Old 03-09-2020, 01:39 PM   #67435
NEVER read those! -
humfrz is offline
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (03-09-2020), daiheadjai (03-10-2020), ScoobsMcGee (03-09-2020)
Old 03-09-2020, 02:47 PM   #67436
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
i was assuming you know what a tap is, but i'll explain really quickly, just so we're on the same page--- 'taps' are different connection points within the transformer to vary the output voltage.
is the replacement transformer tapped exactly the same? this is my first concern. if the transformer was replaced, they had to re-tap it, but they might have re-tapped it to account for an assumed voltage sag at load that might not have been done before.
is this a transformer part of your companies property or is it the electrical providers transformer?
every time i've set a transformer, i leave it at the factory tap points, power everything up, measure each leg, and then power-down and re-tap to get as close to the specified voltage as possible.
do you have a bluetooth meter that you can clip on and safely monitor/record the voltage sag while the machine is running? i'm wondering if there could also be a voltage sag issue if the transformer was improperly sized for the loads you're running, and it's causing a brownout scenario within the machine.
i remember you saying before that the elements were custom built buy a guy-- is there a spec sheet for how quickly they're supposed to come up to temp, or hold a specific temp? measuring that rate could also show if there's an electrical supply issue if it rises to temp faster than it should.
I did not know what a tap was, thank you. I did check the output at my panel, and had an electrician check it. I am getting around 483 a leg. One of them was a little bit higher. I haven't tried monitoring it, I will do that next.
I really think we just need to turn the oven down a little. The elements are cast refractory cement and the resistor wire(N7 NiChrome) is encased in it. N7 is good to 2200-2300F. I wouldn't doubt we are pushing close to that to get the ambient temp of the oven to 1800F.
NoHaveMSG is offline
Old 03-09-2020, 03:14 PM   #67437
This wouldn't be an issue for me. I've never met a wine I thought wouldn't have been better mixed with oil and poured over a salad.
Now, if it were a bourbon or tequila tasting, I'd probably still be sleeping it off.
Dadhawk is offline
Old 03-09-2020, 07:56 PM   #67438
cjd
cjd's Avatar
Drives: 2017 BRZ
Stop assuming people fall into a single comfortable place in a presumed binary existence! Just because Ichi is comfortable being both a 5 AND a 6 isn't a reason to discount one of them.
cjd is offline
The Following 2 Users Say Thank You to cjd For This Useful Post:
soundman98 (03-09-2020), Tcoat (03-09-2020)
