Old 03-08-2020, 06:43 AM   #1
Halo_2
Drives: 2014 MY15 86 GTS
Over fill oil
I just bought my 86 secondhand from a stealership and when I got home about (120kms of driving )decided to check the oil, it was over filled to the curve of the dipstick.
I drained the oil next day which came to nearly 2L.
Is there anything I should check to see if there was any damage?
Halo_2 is offline   Reply With Quote
Old 03-08-2020, 09:31 AM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Unless its pissing oil from the crank seals and blowing smoke out the tail pipes, you're fine, relax.
The Following 4 Users Say Thank You to RZNT4R For This Useful Post:
Mr.ac (04-11-2020), Rampage (04-12-2020), Spuds (03-22-2020), Tcoat (03-08-2020)
Old 03-08-2020, 11:29 AM   #3
Grady
Grady's Avatar
This.
Old 03-08-2020, 12:27 PM   #4
Yep. What RZN said.
If it caused an issue you would know without doubt by now.
soundman98 (03-08-2020)
Old 03-22-2020, 06:56 AM   #5
Halo_2
I checked today no oil in air intake, removed skidplate no gaskets underneath are blown or weeping.
The exhausts do look oily so ive cleaned them and will check again.
Only thing I noticed is a rough idle/misfire when cold according to the obd it isn't misfiring?
Old 03-22-2020, 10:33 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I believe that is done on purpose to bring the cat up to temperature. If the obd isn't showing a code, it's fine. Just let the engine run for 30 seconds before driving to figure itself out.
humfrz (03-22-2020), Tcoat (03-22-2020)
Old 03-22-2020, 10:44 AM   #7
RZNT4R
The very first 30ish seconds of engine operation, it runs rough because it's in low vacuum operation, it's running with the throttle plate open and de-timed as fuk to stop oil consumption on startup. Try this: before you start it, pump the brakes to deplete the vacuum in the booster, once it starts notice the lack of vacuum as the brake pedal remains stiff as wood. After 30ish seconds, you'll notice the sound change and the brake pedal will sink as the booster gets vacuum again.
This doesn't work for an automatic car though, as it uses a mechanical vacuum pump.
gravitylover (03-22-2020), humfrz (03-22-2020), Spuds (03-22-2020), Tcoat (03-22-2020)
Old 04-11-2020, 10:02 PM   #8
Halo_2
Is it normal for it to burn oil...im not seeing blue smoke out of the exhaust but im down to half a dipstick.
Old 04-12-2020, 12:00 AM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
over how long of a distance?
what do you mean by half a dipstick? it started out at the top of the hash marks @ operating temp, and is now measuring at halfway between them @ operating temp?
Old 04-12-2020, 12:07 AM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude. You are way, way, way, overthinking this.
You are fine. The car is fine.
Every and all internal combustion engines, from old ass to off the factory 2020 engine do burn a curtain amount of oil. Newer engines burns less due to better technology.
So again your car is fine.
Old 04-12-2020, 02:35 AM   #11
Halo_2
over 3K
Checking both when stone cold was at the top on the low side now its half way down.
Old 04-12-2020, 12:48 PM   #12
RZNT4R
Being a flat engine, cylinder walls tend to gather more oil than an engine with vertical cylinders, that is why break-in is very important on a flat engine to avoid oil consumption later on in life, a well broken in engine will be fine and not burn oil, and not-well broken in engine will also be fine, but burn oil all of it's life.
But .5L over 3000km on a subaru is acceptable consumption.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
alphasaur (07-17-2020), Halo_2 (04-12-2020)
Old 04-12-2020, 01:58 PM   #13
soundman98
soundman98's Avatar
sounds about normal to me.
Old 07-17-2020, 10:19 PM   #14
Halo_2
After changing to Toyota factory oil 0w-20, its no longer burning oil.
Is it necessary to pre-fill the oil filter? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 06-07-2016 03:58 PM
How often u guys fill the tires air? clfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 10-10-2014 01:42 PM
Factory Transmission Oil Fill - UOA R2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2014 01:50 PM
Fill and paint? or PDR... rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-12-2014 09:36 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 05:46 PM
