Old 02-26-2020, 10:59 AM   #113
bslate3
Drives: 2015 CWP BRZ
245 or 255 A052’s? Which are you using? It looks like they run pretty wide and the 255 may be a tiny bit pinched?
The weird thing is the 255 is cheaper than the 245.
bslate3 is offline   Reply With Quote
Old 02-26-2020, 11:55 AM   #114
tony_r
tony_r's Avatar
Drives: '15 STX
I wouldn't run the 255 on anything less than 9.5"
tony_r is offline   Reply With Quote
Old 02-26-2020, 05:35 PM   #115
racingfool
racingfool's Avatar
Drives: Miata
STX is 9" max.
racingfool is offline   Reply With Quote
Old 02-26-2020, 06:46 PM   #116
cjd
cjd's Avatar
Drives: 2017 BRZ
On a '15, probably 245. Unless you want the extra tire diameter
Old 02-26-2020, 08:43 PM   #117
e1_griego
e1_griego's Avatar
Drives: Many
I got 245s. They look pretty damned wide...
I bought a set of 255s for my s13 which has 9.5" wheels and I bet they're gonna be a little pinched.
e1_griego is offline   Reply With Quote
Old 02-27-2020, 07:30 PM   #118
tony_r
tony_r's Avatar
Drives: '15 STX
Originally Posted by racingfool View Post
STX is 9" max.
I'm aware of that, I will still say the same thing.
Old 02-27-2020, 08:16 PM   #119
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
maybe he lives in a world where tire roll over is unaffected by tire to rim ratios?
Clutch Dog is offline   Reply With Quote
Old 02-27-2020, 08:37 PM   #120
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
is there a consensus on 255 vs 245 on a 17x9 wheel?
SON1C is offline   Reply With Quote
Old 02-27-2020, 09:03 PM   #121
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
Yes. Generally, people run a 245. Many people tried 255s over the years, and it wasn't faster.
I actually ran a 255 Yokohama A052 last year at Nationals, because it was all I could get at that time. It wasn't terrible. I'm using a 245 Yokohama this year.
On 17 x 9 RPF1s, I measured the mounted section width of my 245 RE-71R and compared it to the Yokohama 245 A052. They were the same.
Sent from my SM-G930P using Tapatalk
sifl is offline   Reply With Quote
Old 02-28-2020, 05:56 PM   #122
Roadphantom
Drives: FR-S - STX
I know they are not the tire to have, but has anyone tried SUR4G? Let me know if you have any feedback or psi reference.
Sent from my Pixel 2 using Tapatalk
Roadphantom is offline   Reply With Quote
Old 02-28-2020, 10:35 PM   #123
Clutch Dog
i know if you can find em they are good. accessibility makes them hard. down here in the socal area its easier to find the federals for the cheap grippy tires. If i had to tier them id place em above the feds, and v720s only in sheer grip, they are loud and thrashy and turn in isnt as sensitive as say your rivals or 71rs.
Old 02-28-2020, 10:49 PM   #124
racingfool
racingfool's Avatar
Drives: Miata
71rs.
Made me think of this.
Old 02-28-2020, 11:05 PM   #125
Clutch Dog
not many things are cooler on 4 wheels
Old 03-02-2020, 01:25 PM   #126
Roadphantom
Drives: FR-S - STX
Originally Posted by M0nk3y View Post
Here I copied and pasted my setup and updated some items:
2016 Scion FRS:
Suspension:
MCS 2W Remotes - Custom Revalve & Coated Piston
400/350# Rates
Raceseng Camber Plates/Raceseng 1" Top Hats in Rear
Front: -4.2* Camber, 0 Toe
Rear: -2.5* Camber, 1/16" Total In
Ride Height - Front Wheels 25" from floor to center of fender above wheel. Rear set for 1/8" Rake
Karwan FSB
Mann Rear Bar set of Stiff (I adjust all the time though). RacerX Endlinks
RacerX LCA
Whiteline Subframe Insert Bushings
STi Engine Mounts
Whiteline Rear Transmission Bushing Insert
Engine:
aFe Momentum Intake
JDL 4-2-1 Header
JDL Ultra Quiet FP/OP Combo w/Cat
Perrin 2.5" Exhaust
MotoEast/XeroLimit Custom Dyno Tune
Perrin Oil Cooler
Wheels/Tires/Misc
AP Racing BBK w/Ferodo DS2500s
RPF1s 17x9 +35 with 245/40/17 RivalS 1.5s + Yokohama AO52s
Antigravity 680CA Battery w/PFTuning Tray
Grimmspeed Master Cylinder Brace
I don't know if I'm forgetting something, I probably am
How did you decide between the Raceseng 1in or 2in rear extended top hat?
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
