Old 02-13-2020, 02:47 PM   #225
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Finally installed my swizz cheezed ebrake. Was waiting on my new ebrake handle to show up
So drilled down the ebrake to save .5 lb of it, new handle added .25lb back on.
While I had everything apart was able to take over .25 off the brackets for the ebrake lines/ removed rear most bracket for center console not needed
Stock 3.1
swisscheesed with new heavier handle
Ebrake line brackets
One less bracket and material removal
Installed
Weight saved .5lbs total
New weight 2330.75 LBS
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Tristor (02-26-2020)
Old 02-13-2020, 03:46 PM   #226
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Have you considered 3D printing any items to save weight? I think you could skeletonize your e-brake with this technique without sacrificing any functional integrity.
Sent from my Pixel 2 using Tapatalk
ROFL it's Waffle is offline   Reply With Quote
Old 02-13-2020, 05:20 PM   #227
SuperTom
SuperTom's Avatar
I would love to one day have an aluminum or CF 3Dprinter.
Functional integrity wasn't sacrificed drilling multiple smaller holes vs. a few big holes. I can pull on the ebrake hard and it feels just as solid as before. Most of that steel is pretty thick
Old 02-19-2020, 02:36 PM   #228
SuperTom
SuperTom's Avatar
Just added some weight today but hopefully the aero benefits will outweight the gain especially with all the highway driving I do.
Added on the Verus non-aggressive diffuser. With hardware used adds 8.5lbs on the rear
Say its looks great and is sturdy. Fit with my FactionFab ti exhaust. Only thing with mine was the back of the diffuser (toward the front of the car) had to be at full droop to go over the muffler cannisters.
You can see at full droop in the rear air will still be able to get up the inside of the diffuser. So the Verus suspension cover is mandatory in my case. I think ill be making my own very soon.
This aero project is not complete but will be working on ways to smooth the underbody to the diffuser.
New weight up to 2339
Old 02-19-2020, 03:34 PM   #229
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Which handle is that?
tehShirt is offline   Reply With Quote
Old 02-19-2020, 04:32 PM   #230
SuperTom
SuperTom's Avatar
Its called SSCO anodized on ebay. I like it very much. Pulling on the handle just feels more positive, even with material removed on my ebrake. The center grippy area can also be removed, believe there are other colors available.
You do have to get your own drift button
https://www.ebay.com/itm/SSCO-ANODIZ...72.m2749.l2649
tehShirt (02-19-2020)
Old 02-19-2020, 05:09 PM   #231
tehShirt
tehShirt's Avatar
Thanks for the link, I imagine it gets warm in the summer being aluminum. I had contacted someone about making a handle from Delrin, but that never panned out.
Old 02-19-2020, 05:54 PM   #232
86TOYO2k17
Drives: 2017 toyota 86
Is your muffler in the way or the pipe going to the muffler?
My csg mxp catback muffler fit but the pipe to muffler was routed in a way it got in the way so i just cut off some of the diffuser metal in that area. Made no real negative difference but i could now mount diffuser up as high as possible. I think it offers most drag reduction downforce and ground clearance higher up it is.
Old 02-25-2020, 04:47 PM   #233
andrew4554
Drives: 2015 Scion FRS
Do you have a link for the calipers? love the thread!
andrew4554 is offline   Reply With Quote
Old 02-25-2020, 05:44 PM   #234
SuperTom
SuperTom's Avatar
The roundness of the canisters(mufflers is what would be touching the diffuser. I will be filling in the space from the diffuser up past the gas tank soon. So the diffuser hanging low wont matter as much, although I prefer if it were up higher as well. My concern with it hanging low is air getting trapped above the diffuser, so that space will get filled.
Old 02-25-2020, 05:51 PM   #235
SuperTom
SuperTom's Avatar
Thanks for the compliment.
The calipers were on rock auto. Search for 2006 Subaru Impreza 2.5 Turbocharged (WRX) rear calipers. You have option to get plain, or pay a little more for the Red powdercoated like I did. Part #'s is
CENTRIC 14247525 & CENTRIC 14247526. Looks like they are selling out fast.
Old 03-09-2020, 06:15 PM   #236
beltax90
beltax90's Avatar
Drives: 2010 corolla
Can't wait for more updates on this thing!
beltax90 is offline   Reply With Quote
The Following User Says Thank You to beltax90 For This Useful Post:
SuperTom (03-09-2020)
Old 03-09-2020, 06:38 PM   #237
Lantanafrs2
Drives: 2013 frs red
Car must feel great right now. Hows the acceleration?
Lantanafrs2 is offline   Reply With Quote
Old 03-09-2020, 07:47 PM   #238
SuperTom
SuperTom's Avatar
Just removed my stock wheels and spacers and put my hypergrams back on. Light wheels definitely make a difference in that instant acceleration
Currently working on the undercar aero to mate up with the rear diffuser. Mainly making smooth panels for the whole underbody. And just got a genuine SARD wing to install. Family situations have slowed progress
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Lantanafrs2 (03-09-2020), why? (03-11-2020)
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
