Old 02-19-2020, 03:16 AM   #15
askho
Drives: 2013 Subaru BRZ
I might get some flak for saying this but I put a little bit of pressure on the shifter before engaging the clutch and letting off the gas. I've found that this helps the transmission slot into second smoothly and quickly after doing this. I only put enough pressure to feel that the shifter no longer has any play while in first gear, i also don't do this when the transmission is cold.
I've also found it helps do do everything quick at the same time. Letting off the gas pressing in the clutch and shifting at the same time gave me better results than doing things one at a time.
askho is offline   Reply With Quote
Old 02-19-2020, 06:27 AM   #16
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
A- I don't drive my car in winter.
B- I sometimes get completely locked out of second when car is cold. I go to 3rd.
C- I found if I rev up to 4k it shifts smooth.
All cars have their quirks.
CB750F is offline   Reply With Quote
Old 02-19-2020, 06:32 AM   #17
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Who doesn't like a little drama in their lives every now and then?
... but I put a little bit of pressure on the shifter before engaging the clutch and letting off the gas. I've found that this helps the transmission slot into second smoothly and quickly after doing this. I only put enough pressure to feel that the shifter no longer has any play while in first gear, i also don't do this when the transmission is cold.
In my first manual, I think I did something like this, resting my hand on the shifter when not in use... I'm pretty sure that's what led to me wrecking my synchros somewhere between 35k and 57k miles (2008 Civic), and again at 97k (both covered under my warranty lol). OP has not mentioned mileage/mods here, though I haven't been to the New Member forum yet to verify. Previous owner may have done what I did, who knows.
Joke is on all of us if it's a sequential shifter LOL
ROFL it's Waffle is offline   Reply With Quote
Old 02-19-2020, 07:32 AM   #18
THIS ^
It is all one action not a series of separate ones. Trying to do each movement separating is the second most common error I see when teaching people to drive MT.
The most common error is people that grab their knob in a whole hand death grip and try to ram it into gear Fast and Furious style. This method requires all of your body positions to be perfect or else you are fighting where the shifter actually wants to go. Maybe OK with FWD or other cars with all sorts of cables and linkages to take up the imprecise movement but fails miserably when the shifter is directly connected to the tranny.
You need to lightly caress your knob with an open palm and a couple of fingers to gently yet quickly guide it into the slot where it wants to go.
Old 02-19-2020, 08:14 AM   #19
ROFL it's Waffle
This car has a mechanical shift linkage? @SuperTom could be another great item to skeletonize for your featherweight build.
Old 02-19-2020, 08:29 AM   #20
Which one will hide your errors more
Old 02-19-2020, 08:45 AM   #21
ROFL it's Waffle
I just had no idea it was a mechanical linkage, I'm very pleased!
Old 02-19-2020, 10:02 AM   #22
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
As it seems to have covered; one motion of throttle adjustment, clutch, and shifting happen at once always nets me best results in the cold. Doesn't have to be quick, but a smooth deliberate shift with no hesitation.
It's such a auto pilot habit now that whenever I see these threads and I think about slowing it down, shifting into second gets crunchy and doesn't always want to go into gear. I would generalize all of my shift issues down to this. Whenever I have shift issues it's because I was lazy with shift timing, or throttle.
The only other occasions where there are issues is when it's -25, -30c and the cars been sitting out all day. Now if that happens I just let it warm up for a few minutes and shift the car a few times before I set off.
Old 02-19-2020, 10:29 AM   #23
I blame Hollywood for much of the poor shifting people use since they need to make it exciting not realistic.
Old 02-19-2020, 11:08 AM   #24
askho
Hahaha of course when I say this I don’t leave my hand on the shifter or put any unnecessary force on the shifter unless I’m shifting. It’s just a lil bit of pressure before I let of the gas and push in the clutch. It’s like a tenth of a second of light pressure and it lets me shift gears with next to no force.
Old 02-19-2020, 11:22 AM   #25
ROFL it's Waffle
So it's Hollywood's fault for phasing out of the manual transmission, everything is going hands-free...
Old 02-19-2020, 12:58 PM   #26
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I think the underside of that linkage piece has some hollowed holes already. BUt it was already on my mind if/when I do a lightweight flywheel ill have it all apart
SuperTom is offline   Reply With Quote
Old 02-19-2020, 01:31 PM   #27
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Whoa! I thought this thread was regarding transmission GRIND.
I must be mistaken . . .
LimitedSlip is offline   Reply With Quote
Old 02-19-2020, 01:46 PM   #28
Well you can treat your tranny however you wish!
2nd Gear Grind Stonewall CANADA 12 04-06-2018 01:36 PM
5th gear grind Hugo Issues | Warranty | Recalls / TSB 7 06-08-2016 08:33 AM
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
