Old 02-16-2020, 04:25 PM   #3809
86prime
Drives: 18 BRZ tS
What do you mean by full conversion? I meant buy an actual tS. Did the tS get disallowed from STX?
Sent from my LG-H932 using Tapatalk
86prime is offline   Reply With Quote
Old 02-17-2020, 08:15 AM   #3810
M0nk3y
Originally Posted by CoolHandMoss View Post
I am hearing that the yokohamas like some rather high pressures. I was thinking about starting out around 33 square. Would anyone care to share what pressures have ended up working well for them?
Start around 30, you have around a 3-4 PSI window where times appear to not change but behavior of the car and feel of the tire does. Adjust as you see fit.
Kyle H. - #89 STX
Old 02-17-2020, 11:33 AM   #3811
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Originally Posted by Clutch Dog View Post
unless its factory equipped with the lip, side skirts, and diffuser
the wing is a no no unless you do a full conversion.,
Can you explain a full conversion, and how to ensure you convert it properly? ex. you need XYZ and dont need ABC from a standard brz to a TS
SON1C is offline   Reply With Quote
Old 02-17-2020, 02:39 PM   #3812
CoolHandMoss
Drives: 2013 FRS
Excellent. Thanks.
CoolHandMoss is offline   Reply With Quote
Old 02-20-2020, 11:04 AM   #3813
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Full conversion = full conversion. It's easier and smarter to just buy a ts if you want the aero (which doesn't do anything at autocross anyway)
Old 02-20-2020, 12:35 PM   #3814
86prime
Drives: 18 BRZ tS
Aero is disallowed in autox (lower classes) for a reason
Old 02-20-2020, 12:41 PM   #3815
Autoxer62
In both Street and Street Touring, the rule is that you can convert a car from one spec to another if you do *all* the changes. So if you want package B and it includes an aero kit, springs, seats, and a giant subwoofer then you have to install all of those parts, not just the bits you like. If you want to mix and match, then it's time to move to Street Prepared, which allows update/backdate of any individual part from the same line in the class listing.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 02-20-2020, 07:22 PM   #3816
SON1C
SON1C's Avatar
thank you
I was asking more on clarification of say, all of the exterior pieces
Old 02-20-2020, 07:25 PM   #3817
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
XS-A might be a cheaper alternative but its region only
Old 02-20-2020, 07:51 PM   #3818
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you're serious about an XSA car I think you'll dump $10k+ into the engine, you'll want to push >350whp methinks, which will eat trannys. You'll be playing on 295-315 wide tires so you're not saving much on tires even though they're 200tw.
Does LPSP allow update backdate? I'd go play in DSP if cost was a concern, the car makes good power on E85 and not cutting the fenders should keep you on <275 tires. A 315/30/18 BFG is more expensive than a 275/35/17 A7.
But if competitiveness isn't a priority play with whatever tires make you happy.
ineedyourdiddly
Old 02-20-2020, 10:32 PM   #3819
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Old 02-20-2020, 10:36 PM   #3820
strat61caster
Does something =/= makes enough speed to make up for my shitty driving
ineedyourdiddly
Old 02-21-2020, 09:33 AM   #3821
M0nk3y
Honestly I think you're light on the $10k figure on a reliable turbo build. I think UP/BP is not legal for LPSP, but I haven't paid much attention because I don't think twins can be competitive against a full prep RX8
Totes. What's even more stupid is that TT Touring Classes can't benefit from Aero yet they want to drift away from Solo type rule classing to allow tuning in the lowest form of prep level there is to offer.
But that's a soapbox for another day
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
DocWalt (02-21-2020), strat61caster (02-21-2020)
Old 02-21-2020, 11:05 AM   #3822
Breadman
Breadman's Avatar
not to split hairs but youd be in XS B since removing the spare would drop you below the 2750lb limit of A
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
