Old 02-09-2020, 04:56 PM   #1
SmoothIsSlow
Nail in race tire, what should i do?
I found a nail (or rather a large staple?) deep in the treads of in one of my GT Radial SX2 (miraculously it didn't seem to be leaking air and I drove on it for quite a couple of months after the race season was over).
Now that race season is starting, I am left with 3 options:
1) Buy another 225 45R17 GT Radial SX2 to replace this one. Keep running 3mm spacers for front strut clearance.
2) Patch the existing tire, keep running spacers up front (and 225 square)
3) Buy a pair of 215 45R 17 GT Radial SX2, run the 215s up front (hopefully without spacers) and 225s in the back.
By the way, the wheels are Enkei VR5 w/ 45mm offsets. I really disliked having to run spacers (although if I dial the camber from -2.4* back to -2.0*, I may be able to run without spacers)
SmoothIsSlow is offline   Reply With Quote
Old 02-09-2020, 05:15 PM   #2
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
Pull the metal out of the tyre. If it doesn't leak, race on. If it leaks, plug it and race on.
this has nothing to do with running a staggered setup or not. You obviously have the wrong wheel offset if you need a 3mm spacer, but that's so small I wouldn't even think about running a different tyre up front to remove it.
Race on!
Subsonic is offline   Reply With Quote
The Following 2 Users Say Thank You to Subsonic For This Useful Post:
Icecreamtruk (02-17-2020), Mr.ac (02-10-2020)
Old 02-09-2020, 09:39 PM   #3
4)Get sponsored by a tire company.
femaledog (02-09-2020), soundman98 (02-09-2020)
Old 02-16-2020, 10:55 PM   #4
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
I have patched a few SX2's and they have never leaked. As long as the hole is not near the sidewall, a proper "tire off" patch will work fine.
I would stay with 'square' setup to maintain your over/under steer balance. Also better tire life, as you can rotate your tires.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
SPEEDWELL FORGED RACE WHEELS | Wheel/Tire/Coilover Package Specials! eastendraceshop Wheels and Tires 120 11-07-2019 06:59 PM
Screw / Nail in tire kpamir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-03-2015 12:20 AM
Got a nail! Fixable? jbravo373 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-03-2013 05:28 PM
Nail in the sidewall ApoNono Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-15-2013 07:54 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
