Drives: Toyota GT86
Clicking Noise in the rear area while Coasting
Hey guys,
I am very desperate, nobody seems to find the issue and I can’t find a thread discussing this problem etc. SEE VIDEO : So basically, in my Propshaft / Differential area, there is a “clicking” noise who appears while coasting, as soon as I press the Gas Pedal it stops immediately. It also occurs while downshifting and letting of the clutch (not rev-matching), 3 rapid clicks... Checked : - CV Joint are good - Axle Nut has been changed - Differential Mounts seem to be noisy, and one of the mounts bolt was little bit bent, but wasn’t replaced for now Thinking : - Maybe loose/broken propshaft ? - Loose Differential mounts - Broken Differential All help would be great, please help me solve this myserti! Thank you! SEE VIDEO : Last edited by Inteze; 02-10-2020 at 03:34 PM. |
#2 | |
Drives: 2017 Subaru BRZ
Sent from my SM-G960W using Tapatalk |
#3 | |
Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
#4 |
Drives: Toyota GT86
#5 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I feel like we could better answer your question if we knew basics like, what year, mods done, mileage... DD or track car, etc.
Does this video harmonize with your problem? [ame]https://www.youtube.com/watch?v=KwoMUejhs_Q[/ame] |
#6 |
Could be the U joints on the drive shaft. There are 3 of them.
#7 |
Drives: Toyota GT86
#8 |
Drives: Toyota GT86
#9 |
Drives: FR-S Whiteout
I thought your car was a 17 and up form the taillights... So no warranty coverage.
Are you 100% certain its not the CV joint? I removed my clicking axle at maybe about 60K miles-ish and removed the boot. The grease was completely liquified. It pored out like it was oil, not grease. A 2013 lowered 86 with a bad original axle is no surprise to me. Even expected. Just throwing that out there.
Intent > Content
cowardice is the mother of cruelty. |
| The Following 3 Users Say Thank You to solidONE For This Useful Post: |
#10 | |
I am also thinking CV joint, and the reason it's not clicking more is just because you lifted it up and are putting only rotational stress on the CV joint, not rotational and tire/road resistance. Sounds like you just need to re-grease the joint and inspect the boot for cracks, replace if necessary (not in that order lol). |
| The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | solidONE (02-19-2020) |
#11 |
Drives: Toyota GT86
Little update :
CV Joint broke, Axle had to be replaced everything fine now |
| Tags |
| clicking, differential, noise, propshaft, rear |
| Clicking noise from the rear | Seiryuu | Issues | Warranty | Recalls / TSB | 18 | 05-17-2020 08:07 PM |
| Clicking Noise From Rear Axle TSB | Bach415 | Issues | Warranty | Recalls / TSB | 0 | 09-16-2019 04:43 PM |
| Clicking / Ticking Rear Noise | shellslinger | Issues | Warranty | Recalls / TSB | 19 | 07-20-2017 09:40 PM |
| clicking noise from drivers side rear | CARBONGT86 | CANADA | 11 | 08-23-2015 06:58 PM |
| Clicking noise in wheel area, driver side | Rabbit of Caerbonnog | Issues | Warranty | Recalls / TSB | 19 | 02-18-2015 01:59 PM |
