Old 03-01-2016, 06:56 AM   #85
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Its a goose, sent to eat the crickets
RichardsFRS is offline   Reply With Quote
Old 03-01-2016, 06:57 AM   #86
RichardsFRS
Doesn't sound like a honk, sounds like metal to metal, that sounds pretty bad
Old 03-29-2016, 08:18 PM   #87
Astroboy
Astroboy's Avatar
Drives: None
If it really just is the throw out bearing Its not that bad
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 02-14-2018, 01:59 PM   #88
bemgikim
Drives: FRS
Master Cylinder
Originally Posted by Monogram View Post
Toyota replaced the transmission, clutch, and throw-out bearing in my FRS, and it did not fix the honk noise. They then replaced the clutch master cylinder and slave cylinder which fixed the noise. The noise is coming from the clutch master cylinder, and replacing the trans/clutch/throw-out bearing does not fix the noise.
Has the noise ever came back ever since you replaced the Clutch Master Cylinder?
bemgikim is offline   Reply With Quote
Old 02-13-2020, 09:42 AM   #89
H_K
Drives: '13 Scion fr-s
Originally Posted by timfacchin View Post
Hi guys, just wanted to give a VERY long-term follow-up on this in the hopes it may help somebody else. Many thanks to all but especially Monogram for all of his (accurate) assistance.
I took my BRZ in for some warranty work at the end of last winter, one of those issues was this honking noise. Wouldn't you know it, as soon as I brought it in the honking stopped. Turns out, the honking noise is VERY temperature (and possibly humidity) sensitive. I happened to bring the car in on a random 70 degree day. No dice. Got the car back and sure enough, it was mostly gone.
Well, it's winter again here in NY and almost as soon as the temperate entered the 40s the old honk came back. It seems to be at it's loudest between 30* and 45* but I haven't quite nailed down a pattern.
Anyway, I waited for a nice cold patch and brought it in. It took some convincing to have them try the master cylinder on the clutch but they did the work and that fixed my issue. I've had several days since in the bad temperature range and all's been silent. Love it.
Also had them tackle the crickets while it was in...new high-pressure fuel pump and now I don't know what to do with all of the silence. I'm going to need a better stereo.
Thanks again to everyone for all of your help!
How much did the fix cost at the dealership?
H_K is offline   Reply With Quote
Old 02-13-2020, 09:49 AM   #90
Just lube it all up well. Cost me $8 for a tube of grease and the noise never happened again.
Old 02-14-2020, 10:28 AM   #91
H_K
Where to put the grease? I can't pinpoint what is making the honking sound.
Old 02-14-2020, 10:48 AM   #92
You need to get to the shafts for the master and slave and grease them up.
Old 02-14-2020, 11:01 AM   #93
H_K
Forgive me, I'm not a pro. Do you have a diagram of where this is located? I'm not sure what the clutch master/slave cylinder looks like.
Old 02-14-2020, 11:06 AM   #94
Here you go. Don't need as much as this dude uses though.
[ame]https://www.youtube.com/watch?v=8v3J1ltziG0[/ame]
Old 02-14-2020, 11:51 AM   #95
H_K
Oh, thanks! That looks very easy. Interestingly, I also have that squeaky pedal noise too so maybe this will kill two birds with one stone.
I'll grab some grease this weekend and report back on if it worked.
Old 02-14-2020, 11:55 AM   #96
If that doesn't do it there are further steps that can be done but start with this and see.
Old 02-14-2020, 12:00 PM   #97
H_K
One more quiiiick question. Does it have to be marine grease, as in the video?
Old 02-14-2020, 12:04 PM   #98
No. I used a lithium grease that I had kicking around. You don't need much just a thin coat (not like he put on).
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 02:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 04:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 06:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
