View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-20-2012, 11:50 PM   #421
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Originally Posted by csaba View Post
All this bad gas conversation getting ridicoulos I mean cmon people!!! who would buy this car if you only can go to a certain gas station the answer is NO ONE!!!
All this people has experiencing this problem had bad gas that's bull shit....
Its clear the car has a issue and Toyota /Subaru has to address it!!
I think you're missing the point a little. People aren't claiming that they got bad gas, and therefore they're having HPFP issues. They're saying that the gas we get in the US in general has less lubricants than gas in Japan (or, more ethanol), with the effect being that the HPFP is quickly developing a chirping issue. So to test that theory, people are adding lubricants and/or trying non-ethanol gas. AND - in either case, there's no arguing that Toyota/Subaru should address it - but people are looking for stop-gap measures to "fix" the issue in the meantime.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
The Following 3 Users Say Thank You to brianbot5000 For This Useful Post:
NeedsmoreCowbell (07-21-2012), roddy (07-21-2012), sierra (07-21-2012)
Old 07-21-2012, 12:51 AM   #422
roddy
roddy's Avatar
Drives: '13 Ultramarine
The gas isn't "bad". I run everything I drive on it, including a Mustang with a supercharger and my wife's Acura RDX (turbo)...no problems. There's just something about some of it that these cars (presumably the HPFP) don't like. This is a car issue, not a fuel issue, and it needs to be addressed. Until it is, if one fuel or another shuts it up, or an additive works, I will use it. So far, gas without ethanol has worked for me.
The Following User Says Thank You to roddy For This Useful Post:
Old 07-21-2012, 03:23 AM   #423
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by mastertech86 View Post
warranty basically means any part on the car that suffers any type of "manufacture defect" is qualified for warranty replacement provided its still within the manufactures specified warranty time and mileage limit. any evidence found that the part in question was tampered with raises red flags and is usually denied.
even though it is a known problem and there isnt a fix yet, im sure we can all safely assume toyota is working on a fix. im just saying lets not give dealers a reason to give anyone a hard time when its recall time =) or hopefully in time there will be an upgraded HPFP option for the FRS through aftermarket =)
Nobody has mentioned any tampering with the HPFP.
I find it amazing that an upgraded after market HPFM wouldn't void the engine warranty. Even worse that it could be considered as a fix for the current problem rather than the original one being fixed and the owners apologised to for the inconveniece.
To come on a forum and warn against owners fixing their own problems because the dealers can't is piss weak!
Lastly, who is going to go into one of these self serving dealerships and say i've been putting a teaspoon of fuel lubricant in my tank for each gallon of fuel after listening to the 'apparent' dealer reaction in here?
What will there be to show for it after filling up with ethanol blend before taking the car in for the new you beaut modified HPFP whenever and ifever they get around to it?
sierra is offline   Reply With Quote
Old 07-21-2012, 09:14 AM   #424
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by Chewie4299 View Post
Here in CT it seems ALL gas is 10% ethanol so even shell 93 gives me the chirps.
I tried Lucas Oil upper cylinder lube in my last tank with no change
Looks like 2-cycle oil is what I'll stick with for now.
Did you ever experience tweet noise under driving condition with the ac is on? Since you used the lucas oil and the chirp went away I wonder if the tweet went away as well.
Hanzo is offline   Reply With Quote
The Following User Says Thank You to Hanzo For This Useful Post:
Old 07-21-2012, 09:47 AM   #425
wbradley
Sarcastic SOB
wbradley's Avatar
My FRS chirped at idle like crazy for weeks. Perhaps the extremely hot weathwr we were having could have affected things. Anyway, was using Petrocan 93 with 10% ethanol and switched to Vpower 91 from Shell and havent noticed the chirping since!
I need to make sure I'm posting on the most realated threads for this. Someone probably already made this observation.
The reason it happens a tankful or 2 later makes sense if my observation is correct.
Old 07-21-2012, 10:31 AM   #426
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
by tampering i meant adding additives in the gas tank...i have never seen the lubricant ppl are experimenting with to remidy the chirping noise but what if it leaves a by product behind as evidence a tech working on the car sees?
i only mentioned the aftermarket as an alternative "upgrade" over the factory one bringing to mind there are certain cars on the market already like the GTI that have these upgrades available but although not for some, they could just wait for an upgraded/ updated part from toyota themselves to fix the chirping issue.
and hey me knowing how the system works cause i do work as a tech and i do care about the community i just wanted to give you guys a heads up and find a way to work with the system so there isnt ever a headache to have to deal with.
mastertech86 is offline   Reply With Quote
Old 07-21-2012, 10:52 AM   #427
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Anyone ever try this stuff? I haven't seen this type of product listed, since the theme is ethanol issues...
Safeguard™ Ethanol Fuel Conditioner with Stabilizers
Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers was developed to specifically address issues associated with using ethanol based fuels. This applies to E-10, E-15, E-85, pure ethanol and any mixtures in between including gasoline. Our Product is completely soluble in all ethanol fuels and will not harm filters. Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers contains effective additives to prevent rust and corrosion associated with the use of ethanol fuels.
Safeguard™ Key Benefits:
• Cleans injectors, valve seats, combustion chambers and other critical fuel components
• Stabilizes fuel and prevents varnish & gum formation in ethanol and gasoline
• Combats deposits and protects your engine oil lubricants from the harmful effects of alcohol combustion
Safeguard™ treats up to 80 gallons(302.8) of ethanol fuel. One ounce treats five gallons of ethanol fuel. Our new 5.25 oz bottle treats up to 25 gallons (94.6 liters) of ethanol fuel. Recommended for use in automobile and marine applications.
NOT RECOMMENDED FOR DIESEL APPLICATIONS
Pscylo is offline   Reply With Quote
Old 07-21-2012, 11:13 AM   #428
sierra
It does everything but lubricate and if a 'tech' finds any in the system they will void your warranty, apparently.
Don't worry about it though, these are the same 'techs' that stuff up the service on your car every time it goes in, so incapable of forensic investigation at microscopic trace levels.
Old 07-21-2012, 11:19 AM   #429
sierra
If you have never seen the lubricant that shuts up the chirping with just 1:1000 that is a dedicated fuel lubricant designed to do its job and then combust without a trace, you aren't the dealer vehicle tech you profess to be.
Old 07-21-2012, 11:20 AM   #430
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
According the the write up, it blends completely anyways haha...I ask because people are using a lubricant to counter act the ethanol, why not try something made specifically to stabilize and remove the effects of ethanol?
What if lubricating isn't the key, but the lubricant happens to counter ethanol, but ends up fouling something else up in the process?
I haven't tried 2t personally, I have tried a couple additives that are made for use in an automobile though.
Old 07-21-2012, 12:37 PM   #431
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Have you tried revving your engine to 4000+ multiple times!
Mine stopped chirping with Shell gas as long as I stay below 3500 RPM, but it starts chirping if I rev the engine to 4500 multiple times. It stops chirping again on the next trip as long as I stay below 3500 RPM. It doesn't make sense to me, but this is better than chirping 100% of the time with Chevron gas.
Old 07-21-2012, 12:41 PM   #432
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Sparkplugs always tell the truth
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
The Following User Says Thank You to Oriental Life For This Useful Post:
mastertech86 (07-22-2012)
Old 07-21-2012, 04:48 PM   #433
mastertech86
I don't "profess" to be anything other than an employee for a dealership who was trying to make an effort to share my knowledge to the community and help out how ever I could. So how about instead of trying to worry about what my profession is and what i do for a living, we focus on the reason this thread and the whole site was created in the first place and that is for the cars that we enjoy so much. Back on topic now? Thanks.
Old 07-21-2012, 10:05 PM   #434
sierra
The topic is "Engine idle chirping" and we are on topic.
I appreciate any input but by speaking on behalf of dealerships on a technical matter you were assumed to be qualified on a technical level.
Fair enough now we know you aren't.
You have asked about the problem at work and passed on what you were told.
Thanks for that.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
