Old 01-16-2020, 07:37 PM   #5279
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by ML View Post
has anyone seen this Rotrex technical hand book? (https://rotrex.com/wp-content/upload...l-Handbook.pdf). It has a lot of info in it, and some contradict the way JR designed their kit. Interesting stuff, in there.
I assume you're talking about Reservoir location? FYI that is only for C-8 and C15 units. C30 and C38 units do not need to follow that.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
mrg666 (01-16-2020)
Old 01-25-2020, 06:56 PM   #5280
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
As an update to all our Jackson Racing Supercharger customers. We are now implementing LSPI adjustments in all our tunes since November 2019, which includes version 28.00 and higher.
A short education post on what we have been spending a LOT of time on (within our tunes) over the better part of the last year in order to remove LSPI issues. We worked with other professional tuners, motor oil companies, and even vehicle manufacturers to understand what the issues are and how to best mitigate this issue while maintaining power and response even on 91 octane fuels.
You may ask what is LSPI. Low Speed Pre-Ignition (LSPI)
This trait is inherent on high compression, forced induction, direct injected engines, such as the BRZ (with forced induction) and 2015+ WRX, that can cause the combustion to pre-ignite at low RPM's and high loads.
Here is a good article on what the issues are and what we are trying address in tune, along with other physical changes.
https://www.motor.com/magazine-summa...-pre-ignition/
We have found a few key items within the tune to mitigate this issue while trying to offering safety, drivability and power for daily commuters.
Some other things to watch are the oil that you are using in your engine. Cars that are prone to LSPI, please make sure you are using an oil that is SN PLUS rated.
Make sure to speak to your tuner about LSPI and how to best mitigate these issues through the type of oil you use, adjustments within the tune and even the brand of fuel you use.
Regards,
William Knose
Pushing The Boundaries Since 1999
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
FunnyGopher (01-27-2020), mixxxx (02-04-2020), mswbrz (01-26-2020), wheelhaus (01-25-2020)
Old 01-25-2020, 09:07 PM   #5281
wheelhaus
wheelhaus's Avatar
SWEET. After many years I’m finally within spitting distance of getting the JR kit, JR dual radiator, and Delicious tune. This news makes me happy in was only car guys can appreciate. I use my 86 for both street and track duty so daily OEM-level livability and track reliability are paramount. THANK YOU for not only continuing to support this platform but continuing to improve quality.
The Following User Says Thank You to wheelhaus For This Useful Post:
sroby (02-04-2020)
Old 02-04-2020, 10:32 AM   #5282
AndreC
Drives: Fast track beast
Recirc valve upgrade?
Has anyone replaced their recirc valve?
If so, what did you go with?
Looking to possibly replace it with a Mach 2 unit from GoFastBits.
AndreC is offline   Reply With Quote
Old 02-04-2020, 04:45 PM   #5283
mixxxx
mixxxx's Avatar
Regards,
William Knose
Hello! Does this mean JRSC cars tuned by DT pre-Nov2019 will need to be retuned again for LSPI since it was not accounted for before then?
mixxxx is offline   Reply With Quote
Old 02-04-2020, 07:18 PM   #5284
DeliciousTuning
We did some LSPI back then but and easy way to tell is to look at your version number of the tune. If you are prior to 28.xx then you do not have the necessary LSPI updates needed in the tune.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
mixxxx (02-04-2020)
Old 02-07-2020, 12:56 PM   #5285
StraightOuttaCanadaEh
Wes
Can this supercharger be run with ITBs?
Instagram: @gt86ws
Old 02-07-2020, 01:24 PM   #5286
CSG Mike
CSG Mike's Avatar
Yes!
StraightOuttaCanadaEh (02-07-2020)
Old 02-07-2020, 07:12 PM   #5287
steved
Drives: 2013 FRS
The dual rad doesn't have enough cooling capacity for track work from my experience. I'm in the process of replacing it with a standalone oil cooler atm. But if you're really set on it, you can buy my dual
steved is offline   Reply With Quote
The Following User Says Thank You to steved For This Useful Post:
wheelhaus (02-08-2020)
Old 02-07-2020, 07:13 PM   #5288
AndreC
Any recommendations in recirc/bypass valves?
Sent from my SM-G965W using Tapatalk
Old 02-07-2020, 07:48 PM   #5289
mrg666
pessimistic skeptic
mrg666's Avatar
I used a cheap RKX, it works okay. Others used Turbosmart which is more expensive. JR recommends using the softest springs to ensure Rotrex unit is protected from surge. You need 25mm inlet and outlet size if I remember correctly. If you search the thread you can find more information.
The Following User Says Thank You to mrg666 For This Useful Post:
Jasper (03-30-2022)
Old 02-07-2020, 08:00 PM   #5290
kowalski
kowalski's Avatar
Drives: 2016 brz
Just curious; if replacing the recirc valve (with softest spring available), would a retune be needed? or recomended? thx!
Enviado desde mi SM-A730F mediante Tapatalk
kowalski is offline   Reply With Quote
Old 02-07-2020, 08:31 PM   #5291
mrg666
pessimistic skeptic
mrg666's Avatar
Recirc valve replacement does not need retune.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Jasper (03-30-2022), kowalski (02-07-2020)
Old 02-07-2020, 10:56 PM   #5292
CSG Mike
CSG Mike's Avatar
@wheelhaus
I always recommend the standalone cooler for track work.
Also, Zach, is no longer at Delicious.
Jackson Racing (03-04-2020), wheelhaus (02-08-2020)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
