Old 12-13-2018, 10:28 PM   #15
dewittk
The click is the starter solenoid engaging but not spinning. I am currently putting the tranny back together but will try jumping those point I have a hand held switch
Sent from my SM-G965U using Tapatalk
dewittk is offline   Reply With Quote
Old 12-14-2018, 08:46 AM   #16
Brz_racer
Drives: Subaru BRZ
You said you tested the new starter you put in it? I had a similar issue on a different vehicle. Starter would click but not turn the engine over. Turned out to be a bad starter from Autozone. This could be the issue you are having as well.
Brz_racer is offline   Reply With Quote
The Following User Says Thank You to Brz_racer For This Useful Post:
humfrz (12-14-2018)
Old 02-07-2020, 11:52 AM   #17
chucky12012
Drives: 2013 Asphalt Scion FR-S
I've been dealing with my car not starting for a few weeks now. It happened suddenly, not gradually. No work done on the starter or related elements immediately proceeding the issue (work has been done recently a couple of weeks prior... full exhaust, intake tube, and replaced the battery with a lightweight setup). We thought it might be the starter itself, so we replaced it, but that wasn't actually the problem. Went ahead and replaced the starter relay and clutch switch, but no fix there. I can start the car by shorting the starter itself across connections and it starts up fine and runs. We're hearing clicking when trying to start in the fuse box, but the starter relay itself looks fine. Grounds all look good. Not sure what else to check, any thoughts?
chucky12012 is offline   Reply With Quote
Old 02-07-2020, 12:57 PM   #18
Have you tried jumping it through the battery from another vehicle?
Old 02-07-2020, 01:10 PM   #19
chucky12012
It's not a battery issue, since we can short the starter connection and start the car up fine. Or at least not a battery voltage issue directly I should say.
Old 02-07-2020, 02:47 PM   #20
Check the ground strap on the bell housing. May have got damaged doing the exhaust.
Old 02-07-2020, 05:59 PM   #21
chucky12012
Where on the bellhousing is the ground connection?
Old 02-07-2020, 07:19 PM   #22
Left side where it says "disconnect".
Old 02-07-2020, 07:53 PM   #23
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
One way to figure out where to focus is to test the state of vehicle electronics during the start attempt.
Ideally, you would have an inductive amp measuring device on the positive battery cable.
Alternatively, you can put a DVOM on the battery itself.
Starters draw approx 150-300 Amps when working properly.
If you have an electrical issue, you will see lower than expected amps.
If you have a mechanical issue, you will see higher than expected amps. A weak battery can also cause excessive amperage when starting.
If you are only measuring voltage, expect to see around 10-something volts during a normal crank attempt on a good battery. Lower will indicate mechanical issue and higher electronic. This method is not nearly as accurate as an amp test though.
After this test, you can zero in better..
As others have said, if you didn't have a problem before you did the work and then suddenly after the repair, you do, it's almost always a result of work performed.
I had a guy walk into my shop asking for a jumpstart. I obliged, grabbed our jump box and got his car started back up. After talking to him and learning he had only been parked for a few minutes, I was curious as to why suddenly it wouldn't start. I grabbed and twisted the battery cables. The negative cable was loose. Turns out, he had just done a headlight bulb and did not properly reconnect the cable end.
That may not be what's happening here, but just saying that sometimes we can be sure that we've done something correctly when in fact.. oops.. we actually did forget to do such and such a thing.
Also, there's always the chance that during disassembly you damaged the starter. Maybe it dropped? Then you replaced it, but got a defective starter. You can't always trust new parts. Not all that likely of a scenario, but throwing that out there.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following 2 Users Say Thank You to ActionMaxon For This Useful Post:
humfrz (02-09-2020), Tcoat (02-08-2020)
Old 11-07-2024, 12:47 PM   #24
^^reported and to @ichitaka05 via PM^^
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
Headlight wont turn on. Replaced bulb and fuses HachiRokuBoy Issues | Warranty | Recalls / TSB 3 08-19-2018 06:14 PM
Toyota replaced battery with group 26R?! Mikeez Electronics | Audio | NAV | Infotainment 6 02-06-2017 10:27 AM
FS Phantom Supercharger PC680 starter battery, new display-2050 alex345 Engine, Exhaust, Bolt-Ons 20 04-12-2015 01:00 PM
WTB: stock turn signal relay Cajun Interior Parts (Incl. Lighting) 1 07-23-2013 03:56 AM
