Old 10-19-2018, 04:43 PM   #29
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Nice gradual build with fine results both visually and on the dyno. I like!
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
HeresMyMind (07-03-2019)
Old 07-03-2019, 11:32 AM   #30
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
I updated the mod list / photos on the main post. Things have changed since I was last here.
Wheels,
Rotors/Pads
Removed lowering springs
changed foglights out
-B
HeresMyMind is offline   Reply With Quote
Old 12-18-2019, 11:19 AM   #31
HaXx
Drives: jrsc_brz
my favorite oem+ style build
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
HeresMyMind (12-22-2019)
Old 02-06-2020, 12:57 PM   #32
HeresMyMind
A bunch of big upgrades!
KW V3's lowered -1.1" from stock
Verus front Camber Plates set to -2.1* camber
Perrin Front Endlinks
OEM STi front lip
18x8.5 Rays 57DR w/ 255/35r18 Firehawk Indy 500s
Grey/Black Subaru Badges front/rear
Focal 165 AS3 3 way component speakers
Painted all interior silver trim to Black
02C TRD rear spoiler
-B
How it sits with suspension/new wheels (front lip is off for this photo)
Front Badge / Lip
rear badge / spoiler
The Following User Says Thank You to HeresMyMind For This Useful Post:
HaXx (02-06-2020)
Old 02-06-2020, 01:50 PM   #33
BigTuna
BigTuna's Avatar
Originally Posted by HeresMyMind View Post
I installed STi-r clear lenses on the OEM projectors, new bulbs are on the way to replace the 4 year old faded d4s bulbs.
Doing this mod replaces the oem projector lenses which cause the cutoff to be foggy/blurry. This makes for a more crisp / blue cutoff. Because I am a retrofitter it only makes sense to do this! It also adds a bit more intensity in the center.
I then installed an OEM front license plate bracket to give the local police 1 less reason to pull me over.
I also installed genuine Subaru "STi" valve caps because it had none when I got it.
-B
I love this build. Do you have a write up or a DIY sort of procedure for the projector lens swap? I think it'd be something that members (not unlike me) would be interested in.
BigTuna is offline   Reply With Quote
Old 02-06-2020, 02:00 PM   #34
HeresMyMind
The BRZ and HID model FRS/GT86 all use the sane projector commonly known as the RX350 projector
-B
BigTuna (02-06-2020)
Old 02-06-2020, 03:30 PM   #35
BigTuna
BigTuna's Avatar
-B
Awesome. If you aren't the guy making the video, did you also do the washer and shield trim he mentions?
Old 02-06-2020, 03:33 PM   #36
HeresMyMind
I did both. Always trim the 2ndary shield. The washer mod is a preference for color and tuning.
-B
Old 02-06-2020, 07:40 PM   #37
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Looks good with that new front lip
Si_Chris is offline   Reply With Quote
Car failed inspection; told I need to "build up the drive cycle"? irocz0r Issues | Warranty | Recalls / TSB 11 06-22-2017 08:25 PM
TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D WTF Member's Car Journals 224 08-18-2016 09:39 PM
Meet "Cloud" Errol's FR-S Build Thread RainEG Member's Car Journals 12 08-01-2014 05:18 PM
BRZ "Limited" STX build xDanger_208x Member's Car Journals 48 04-21-2014 11:38 PM
