Old 01-14-2020, 04:40 PM   #43
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by why? View Post
It totally depends on the tire and how strong the sidewall is. I have general snow tires with very weak sidewalls. About 40 psi strengthens the sidewalls enough that you have some confidence in the handling. Lower and they feel squishy and awful.
I bet this is the same in many tires that have weaker sidewalls.
the chart takes into account the load index. also snow tires should be higher psi for various reasons
Old 01-14-2020, 06:13 PM   #44
mrhayes1
Drives: 2013 Scion FRS white
The stock tires are super fun, but the issues arises when you actually want to be fast around a corner. The turning point for me was a few years ago when I was making a left hand turn in a (double left turn lane) at the same rate as a mini van and I was loosing the rear end around the corner. The mini van rolled thru like nothing. Granted, I was on the outside of the corner so covering greater distance, but still you get the point...
mrhayes1 is offline   Reply With Quote
The Following User Says Thank You to mrhayes1 For This Useful Post:
Ultramaroon (01-14-2020)
Old 01-14-2020, 07:08 PM   #45
Canyon carving and racing are two different things. I laugh when sedans out-handle me. I'm on my third set of stock hand-me-down tires. Thanks, @humfrz! I love 'em!
humfrz (01-14-2020), why? (01-15-2020)
Old 01-15-2020, 10:42 AM   #46
CatDaddysBBQ
Drives: '13 FR-S
A while back I went from OEM rubber to 215mm Pilot Super Sports. Those were insanely fun road tires - if you drove like a hoon they'd oblige and slide like crazy but if you drove "properly" they had more grip than you could use on the street.
As others have said - that 300tw class is probably perfect for what you want. Your tires should do this too - perhaps you need a bit more commitment. They aren't THAT grippy.
I fully understand if you're never had a proper performance tire before that these would SEEM like racing slicks compared to the primacy or like an all season touring tire on a fwd compact car you may have had prior to this, but I assure you the indy tires aren't that grippy to zap fun with only 225mm.
CatDaddysBBQ is offline   Reply With Quote
Old 01-15-2020, 12:34 PM   #47
churchx
churchx's Avatar
Drives: 2014 GT86
Also imho FWD provides for many false sense of not slipping or more grip just because when one spins fronts on FWD, car tracks straight (torque steer aside) and/or straightens out. Otherwise similar tires/similar weight/similar power should be close enough in slipping or not, no matter what type of single-axle drivetrain (AWD will slip less, simply because at same power half the torque at wheel due double the wheel count driven).
From my experience, even when still on OE primacies, in same roundabouts i usually went at relatively higher speeds w/o slipping vs that of "normal" corolla i had prior buying twin.
Old 02-03-2020, 04:53 AM   #48
Wil
Wil's Avatar
Drives: Drives like a crab.
Still no definitive answer?
I've run the OEM tires and Michelin Pilot Sport 4. Love them both.
Now looking for a similar option at a not so similar price.
My tires are bald both at the front and back. And I love it in the city and when kicking the tail out is an option a light flick just does it. But on the highway, in the rain, it's very, very dangerous.
Looking for something with the stiffest sidewall possible.
Any recommendation?
Leaning towards Hankook Ventus V12 Evo2 and Goodyear Eagle F1.
What about the Falken FK453/510?
Wil is offline   Reply With Quote
Old 02-05-2020, 02:39 PM   #49
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you are looking for the stiffest sidewall, skip the Hankook Ventus V12 Evo2. I am running them now. My only complaint is how soft the sidewall is.
I am going to try the Indy 500 next.
I LIKE TIRES!
Old 02-05-2020, 07:40 PM   #50
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Indy 500 definitely has the stiffest sidewall out of the budget tires IMO
I'm on Falken Azenis FK510 right now, good grip but the sidewall is a bit mushy too. Ride quality is nice for a daily driver though, just can't push it to 95-100% around corners without feeling a little squishy/numb. Great 8/10ths tire if that makes sense. & solid wet grip too. So far the only tires I've been on that feel comfortable right up to the limit are the PS4S and then the crazy stuff like R888r...
Shizuka is offline   Reply With Quote
The Following User Says Thank You to Shizuka For This Useful Post:
Leonardo (02-05-2020)
Old 02-05-2020, 08:43 PM   #51
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Continental Extreme Contact Sport is the go to alternative to the MPS4S, Conti's latest offering supposedly got a stiffer sidewall but I believe it is still considered softer than the Michelin.
https://www.tirerack.com/tires/tests...y.jsp?ttid=223
https://grassrootsmotorsports.com/ar...laren-mp4-12c/
ineedyourdiddly
Old 02-06-2020, 06:16 PM   #52
Shizuka
Shizuka's Avatar
They're not much cheaper though, may as well go with the MPS4S (at least in 255/35/18)
Old 03-14-2020, 09:46 PM   #53
Mr Breeze
Drives: 2014 BRZ Limited, 2018 Crosstrek
Smile
Originally Posted by Clutch Dog View Post
might try a UHP all season then.
alot of what makes the primacies fun is the 215 sizing
I just went Continental Extreme Contact DWS in stock size. I haven't been able to test them in warmer weather, but they seem stickier than the OEM tires in cold weather. Looking forward to putting some miles on them.
Mr Breeze is offline   Reply With Quote
Old 03-26-2020, 12:17 PM   #54
jdemm
Drives: Blue 2014 FRS Limited
Originally Posted by Stomachbuzz View Post
Lol
This thread has been pretty funny so far
Got my car stock with indy 500s.
Left all aids on. Car would slide out under a moderately hard turn, or quick shifting into 2nd around a bend.
UEL header, stage2 OFT, and Eibach rear sway bar and the back end is "on ice skates" as someone else said.
Definitely wasn't expecting it to break loose so easily first time I drove it after the sway bar
My new 86 actually came with a sway bar. Plus I'm getting coils so I can adjust the front camber. I think part of what happened last time with the FRS is that I was on springs with no camber so that back end was more grippy that the front. I plan to dial in some front camber and hopefully that car will stay a bit more neutral to oversteery, rather than understeer.
jdemm is offline   Reply With Quote
Old 03-26-2020, 04:43 PM   #55
mrhayes1
Check out the Continental Extreme Contact Sports next, it is a great tire. I just went from the hankooks ventus evo ll to those. They have about the same grip as the Hankook but a stiffer sidewall so steering feel is better. The sidewall on the hankooks is absolutely too soft. Wet and dry grip for the continental and hankooks is great though. With the Hankooks you know your tires will grip and gain trust over time but they always feel like play doh. Got 40k miles out of the hankooks so hoping the Continentals get me similar mileage.
Edit: I don't know why you would run 25psi in a tire; unless it is a track tire designed to run at low pressures. Running 25 psi in a street tire is pointless and just resulting in more tire wear and is less safe b/c it is not a recommended pressure...If you have a decent high performance tire, you can easily run 40 psi and not have any issues in a 200hp car. That is probably how I manage to get 40k miles out of a set of high performance tires. Oh and little performance driving/track note, generally, the higher the tire pressure so cooler the tire stays. A tire at 25psi will overheat and become slick much quicker on the track than a tire at 40psi.
OFT Keep plugged in without killing battery? Axion Software Tuning 19 06-06-2020 10:30 AM
Supra...killing the 86/BRZ? jrb363 Scion FR-S / Toyota 86 GT86 General Forum 238 02-08-2019 11:44 PM
FS (GA) 15 BRZ Stock Wheels + Tires + TPMS + stock lugs & locks (tires 10k miles) GTHachiRoku Wheels and Tires 15 07-30-2016 11:51 AM
Would 23 lb wheels (Miro) offset the advantages of upgrading to grippier tires? Meanderchap Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 01-07-2016 08:28 PM
I guess i'm killing people... Darryljr11 Scion FR-S / Toyota 86 GT86 General Forum 49 09-06-2013 12:54 PM
