Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 01-31-2020, 09:55 AM   #1
86_n00b808
Drives: 2017 Raven Toyota 86
Taking off Front Plate Bracket...
Hey guys, does anyone know how to take off the front license plate bracket? I decided to relocate my front plate. Got my car almost 2 years ago and didn't really had a thought of using the tow hook area, but now that I relocated my plate, I'm left with the bracket that the dealership installed and it won't come off. I tried almost everything but cutting the bolt off, does anyone have any suggestions before I cut it, kinda don't want to do that though cause I'm afraid of melting my bumper..
86_n00b808 is offline   Reply With Quote
Old 01-31-2020, 10:48 AM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pics?
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 01-31-2020, 09:40 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
the front plate uses expandable rubber plugs in the bumper. you need to take the screws out.
Old 02-01-2020, 10:30 PM   #4
86_n00b808
This is the back of my bumper
Old 02-01-2020, 10:32 PM   #5
86_n00b808
And then here’s the front
Old 02-01-2020, 11:02 PM   #6
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
What are you going to do about the holes?
Will BRZ is offline   Reply With Quote
Old 02-01-2020, 11:33 PM   #7
soundman98
soundman98's Avatar
and the bolts/nutserts are just spinning?
Old 02-02-2020, 12:19 AM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My $.02, unless I could afford and was willing to replace the bumper, I would just put the plate back. A bumper with holes is going to look like shit.
korhun (02-05-2020), soundman98 (02-02-2020)
Old 02-04-2020, 07:37 PM   #9
86_n00b808
I'll probably use a license plate delete to cover the holes or my friend offered to bondo it for me.
Old 02-04-2020, 07:39 PM   #10
86_n00b808
Yeah they just spin, I tried holding them while I unscrewed it from the front but it doesn't work.
Old 02-04-2020, 07:40 PM   #11
86_n00b808
Yeah I thought about that too, but I found license plate deletes that I could just screw on or my friend offered to bondo the holes for me. Thank you for your opinion though! Maybe in the future I'll replace it, but for now I don't really want to.
Old 02-05-2020, 08:32 PM   #12
soundman98
soundman98's Avatar
yep. i've got a theory they make the threaded nut portion directly out of Fe2O3.
the only way to get them out is a massive amount of work (cutting/grinding/drilling, with a ton of breaks to avoid the low melting point the bumper) and a donation to the swear jar.
no. just no. the bumper is plastic. bondo is not compatible with plastic. bondo is for hackjob hustlers and wannabe's. don't be a wannabe.
korhun (02-05-2020)
Old 02-08-2020, 06:01 AM   #13
86_n00b808
Yeah I've realized that might just be the option I'm gonna have to take since everyone said to cut it off, I'm gonna need to look for a huge swear jar lol. I wasn't planning on bondo since I found this website https://billetworkz.com/collections/...-plate-deletes, whats your opinion on it?
Old 02-08-2020, 09:46 AM   #14
soundman98
soundman98's Avatar
i don't think those 'plate delete plates' look any less stupid than a normal vanity plate in the oem plate holder... i've never been of the opinion that a installing a larger hole to cover a smaller hole is a 'solution'.
so bumper urathane has a melting point of around 100 degrees. meaning your day gets worse right before the point where it's considered warm/hot to the touch.
if you can get a channel locks behind the bumper, you could possibly try to hold the anchor while using an impact on the bolt on the other side to attempt to break it loose.
if that doesn't work(it probably won't), drill bits, with some cold water can help-- put the hose on a trickle to wash over the bumper hole and let it water cool the bumper as you drill the bolts out. you'll still want to hold the retainer from the back though to keep it from spinning. it's messy, and it will still take a lot of time, as the metal bolt will attempt to retain the heat, so you need to take frequent breaks to allow the cold water to bring the bolt back down off temp.
Where to position front license plate bracket? stlgrym3 Cosmetic Modification (Interior/Exterior/Lighting) 3 07-23-2018 02:00 PM
Front License Plate Bracket mervingee BRZ First-Gen (2012+) — General Topics 22 07-03-2014 10:43 AM
OEM Front License Plate bracket installation mwy23 Northwest 13 12-25-2013 05:50 PM
WTB: BRZ OEM Front license plate mount bracket KayoTrap Canada Classifieds 7 10-01-2013 03:08 AM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 01:25 AM
