Old 02-01-2020, 11:05 AM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
VVT Not Enabled
Chasing an issue with VVT staying at 0 in my car. Here's what I've done so far-
Checked my clamped vacuum lines on the solenoid under the intake plenum
Checked for vacuum leaks overall
Re-flashed my tune and reset the ECU by removing battery power with all accessories on for 30 minutes
Started car and did not touch gas pedal for 15 minutes
Reverted to first tune revision for car when turbo was installed
Reset ECU the same way I did before
Started car with the car already hot, no gas pedal for 15 min
VVT still will not enable.
One cam in ECUTEK is not cycling until I start driving the car, it is exhaust bank 2.
I replaced the OCV solenoid with a known good one and reset ECU again.
My question also is this: does exhaust bank 2 normally not oscillate with the other 3 cams, or is the actual OCV probably filled with gunk?
This started with sudden loss of power in most of the load map one morning. Idatalogged and found that VVT isn't turning on, which is why the car isn't building boost quick and has 1/4 of it's power in positive boost pressure load areas because there's no timing from VVT.
The picture below shows 3 of the 4 cams oscillating during a cold start cycle, and exhaust bank 2 sitting calmly at 0.
Thank you for any insight. The car has no other trouble other than it runs like shit in most of the load map.
Car is a 2013 FRS running at custom turbo setup. Stock engine, ECUTEK is my tuning platform and I'm using A01C revision since B01C bugs out with Racerom. Car has been turbo and had 63 tune flashes with no issue and 9,000 miles.
Old 02-01-2020, 12:28 PM   #2
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
I had the same issue and it was a bad cam angle sensor. Not the solenoid, but the actual sensor.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following 2 Users Say Thank You to Tonrogs For This Useful Post:
DarkPira7e (02-01-2020), Ultramaroon (02-01-2020)
Old 02-01-2020, 01:39 PM   #3
DarkPira7e
DarkPira7e's Avatar
Thank you! I have a spare, I'll swap it. I've nothing to lose, so why not!
Old 02-01-2020, 04:16 PM   #4
Until Tonrogs' reply, without codes, I would've never guessed. Awesome insight.
Old 02-01-2020, 04:36 PM   #5
tomm.brz
Drives: brz 2017 hksv2
a hint is that vvt exhaust reached negative values
Exhaust cams aren't allowed to go advanced past 0 so that is a false logging, so I also think is the cam angle sensor
Also cheap to buy, but be aware it needs a really careness to install because the distance must be corrected with special gaskets if needed, to have around 1.3mm of distance between the sensor and the cam plate
Otherwise you can induce misfires, there is a TSB explaining very well this
I mean, just install it, but if you get cel and misfire at least you know why
Old 02-01-2020, 05:43 PM   #6
DarkPira7e
DarkPira7e's Avatar
I replaced it. VVT hasn't come on but exhaust bank 2 is reading now! It won't 0 out though, it's hovering around +3 degrees. I'll reset the ECU again and see what happens. No CEL or misfire
Ultramaroon (02-02-2020)
Old 02-01-2020, 05:51 PM   #7
tomm.brz
Hope it fixes, could also be the cam actuator that went bad, if it struggles to go to 0
Does it follow the other exh cam?
Does it swing or steady at a value while idling?
Old 02-01-2020, 05:59 PM   #8
DarkPira7e
DarkPira7e's Avatar
Steady value. Other cam hovers around 0 so no, it's not following the same value but it does follow the up/down trend while driving.
EDIT: After letting it idle for 10 minutes, it is following the other cam and zeroing out. I went for a 5 minute drive, still not activating
Here's a datalog - https://datazap.me/u/darkpira7e/no-v...?log=0&data=24
Old 02-02-2020, 01:47 AM   #9
tomm.brz
tricky
post a log of prolonged idling with warm oil and idle under 950 rpm, with all VVT loggable values activated maybe...
Old 02-02-2020, 03:09 AM   #10
I think bank 2 exhaust is still mostly dead. I bet that long stretch and chunks of perfectly zero indicate lack of signal.
DarkPira7e (02-02-2020)
Old 02-02-2020, 04:01 AM   #11
tomm.brz
i don't know, i also get sometime an evenly 0 in my exhaust side, a looot more smoother than intake
and don t have problems
Also i think a lack of signal could have thrown a CEL
and misfires, since cam angle sensors are used to dictate the firing order
Old 02-02-2020, 04:14 AM   #12
but only one bank? o.0
I'm also surprised no CEL.
Old 02-02-2020, 04:19 AM   #13
tomm.brz
this engine is weird, and his oil channels too,
i too have super steady exhaust cams, and stupid retarded-responding intake cams, but no problem at all
I think there is something else in his car stopping the vvt to enable
DarkPira7e (02-02-2020), Ultramaroon (02-02-2020)
Old 02-02-2020, 04:50 AM   #14
JIM THEO
Drives: BRZ 2018
Did you have the famous valve recall that affects someway the cam oil channels?
JIM THEO is offline   Reply With Quote
Edge Insight CS Monitor (1996 & Newer OBDII Enabled Vehicle) FBPARTS Exterior Parts - The Rest 3 12-02-2015 04:08 PM
Album art enabled but not displayed (bespoke)? Mexibeetle Electronics | Audio | NAV | Infotainment 7 01-22-2013 09:39 PM
