Old 12-30-2018, 06:29 PM   #29
new2subaru
Weight Weenie
Drives: 15 FR-S
Likely to be the carpet knap acting like a big spring washer.
Makes sense but it's metal on metal.
The Following User Says Thank You to new2subaru For This Useful Post:
Leonardo (01-02-2019)
Old 01-02-2019, 11:06 AM   #30
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by GrantedTaken View Post
Pretty sure an impact is less likely to strip than a breaker bar
Lots of little taps vs. a twisting.
If you feel that way, that's fine with me.
I have stated how I feel after actually dealing with a few stuck seat bolts.
I LIKE TIRES!
Old 01-02-2019, 11:20 AM   #31
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
I used both a heavy duty Milwaukee impact gun on one seat and a breaker bar on the other to remove mine, sheared the torx heads off the front bolts regardless. Rears came out fine on both.
I felt like I could push down more with the impact gun for a better bite, but the end result was the same.
spitsnaugle is offline   Reply With Quote
Old 01-03-2019, 02:52 PM   #32
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
The easiest thing from experience on those bolts that I stripped as well was to heat them for about 10seconds with a torch from Home Depot. A little bit of the carpet got singed in the process but those bolts turned so easy after the heat. You will seriously not believe how easy it is after that
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
eastendraceshop (01-09-2019), jcw99 (07-23-2019)
Old 02-01-2020, 01:49 PM   #33
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Does anyone have the Toyota part number for the 2017+ hex head seat bolts? Looking to replace the torx type with the updated version. Thanks!
skylinekin is offline   Reply With Quote
Old 02-01-2020, 02:06 PM   #34
spitsnaugle
if you cant find it, get a M10x1.25 flange bolt
Seat rail bolt part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 10:16 AM
Passenger Seat Rail Plastic End Piece Off skyre Issues | Warranty | Recalls / TSB 4 12-04-2013 10:56 PM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
Nagisa Auto D-Lock Super Low Seat Rail poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 3 11-06-2012 04:35 PM
