Old 02-01-2020, 12:10 PM   #29
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
For those with Perrin engine mounts, did your exhaust develop a nasty rattle? It's super embarrassing, especially in closed spaces like indoor parking lots, people are looking at my car like wtf, something's about to go terribly wrong with that. Is this an exhaust hanger issue, i.e. something that can be mitigated, or does every car with stiffer engine mounts suffer from this? If you've ever heard something metallic roll down the road, like a hub cap or a freakin cooking pot lid, that's what it sounds like.
Did you ever get this resolved??
I remember years ago I put Solid MM on my 3000gt. My uncle who is a great mechanic said they really had to be torqued down a lot. I had them on tight but not tight enough. Everything was great after torqueing them down with a breaker bar.
SuperTom is offline   Reply With Quote
Old 02-01-2020, 03:54 PM   #30
StraightOuttaCanadaEh
Wes
When I first installed them, the NVH increase was so dramatic that I thought something was wrong so I took it back to the mechanic the next day. He called me back literally an hour after opening saying the car is ready, everything tight, nothing loose. However when you start the engine, there is a very strong initial jolt and I’m thinking that’s what loosened something in the catback. Haven’t gone back yet but I am due for an oil change soon so I’ll ask him to check again. If everything is tight, I’ll get Perrin exhaust hangers and see if that helps.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
SuperTom (02-01-2020)
Old 02-01-2020, 04:03 PM   #31
SuperTom
SuperTom's Avatar
Did you happen to notice if the Perrin mounts were lighter than OEM?
Old 02-01-2020, 09:48 PM   #32
Wes
what I can do is weigh the OEM mounts and you can get in touch with Perrin meanwhile and see if the can provide you with a weight
Instagram: @gt86ws
SuperTom (02-02-2020)
Old 02-02-2020, 07:14 AM   #33
SuperTom
SuperTom's Avatar
That would be great! Im hoping the Perrins are lighter if they are made of aluminum like the description says
Old 02-02-2020, 05:55 PM   #34
Wes
1.5 kg is as precise a measurement as I could get. Don’t have one of those small scales. Had to use a foot scale. Stepped on it with the mount and then without, subtracted the difference.
Instagram: @gt86ws
Old 02-03-2020, 08:36 AM   #35
SuperTom
SuperTom's Avatar
3.3lbs. Sorry to be a pain was that for one or both?
Old 02-03-2020, 11:17 AM   #36
Wes
For one
Instagram: @gt86ws
SuperTom (02-03-2020)
Old 02-04-2020, 12:40 PM   #37
SuperTom
SuperTom's Avatar
For one
Perrin got back to me and said listed weight is 5lbs. So could be ~1.5 loss for both.
Old 02-04-2020, 12:51 PM   #38
Wes
yeah I figured the difference wouldn't be much. It's a very hefty mount
Instagram: @gt86ws
Old 06-12-2020, 09:27 PM   #39
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Thanks for the info here. I was considering the Perrin Engine mounts as well, but i think im going to go with the STI ones instead.
Jfheisenberg is offline   Reply With Quote
Old 06-13-2020, 06:41 AM   #40
JD001
JD001's Avatar
Drives: Subaru BRZ
The STi are great!! I love them.. only wish it was my first mod as it made such a difference to the way the car drives... Brilliant!!!
The Following User Says Thank You to JD001 For This Useful Post:
Jfheisenberg (06-14-2020)
Old 06-13-2020, 06:42 AM   #41
JD001
JD001's Avatar
Drives: Subaru BRZ
It's always better after a bit of "torquing".. clears the air...
Old 08-10-2020, 03:12 PM   #42
j_motion
Drives: 14 BRZ Red premium
My is exactly the same with the new Perrin engine mount.
There are certain load at idle will make some not so pretty noice.
But once RMP is up it gose away.
I will put the car a bit more after getting tire alignment and see how they are through out the rpm range.
j_motion is offline   Reply With Quote
The Following User Says Thank You to j_motion For This Useful Post:
Joveen (08-10-2020)
Reliability concerns after major warranty engine repair? guanqi89 Engine, Exhaust, Transmission 10 07-10-2018 09:40 PM
Wtb frs/brz sti engine mount bartuc Want-To-Buy Requests 0 01-05-2018 06:17 PM
FS: Mtec Shift Springs / Perrin Support Mount / Perrin Shifter Mount andy86 Transmission and Driveline 6 05-25-2017 01:26 AM
Perrin Trans Mount and Perrin Shifter Bushing 00vsmcoupe Transmission and Driveline 1 03-09-2016 10:02 AM
sti engine mounts, oem engine/tranny mount, oem radiator sickmint79 Engine, Exhaust, Bolt-Ons 0 08-08-2015 03:15 PM
