| View Poll Results: Is our gearlever rattling? | |||
| Yes |
39 | 84.78% |
| No |
7 | 15.22% |
| Voters: 46. You may not vote on this poll | |||
#15 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
The fix is really very easy. I've explained it to Barloworld Centurion so they should be able to help.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#16 |
Drives: Toyota x86 GRT
Brilliant thanks!
#17 |
86 Challenge
Drives: 2017 BRZ
Yes! This fixed the 4000RPM+ rattle/vibration!
-No tools needed -Jack up the car so you can reach around underneath comfortably. -Pull the shift linkage rubber boot carefully away from the shifter and slide it onto the gear selector shaft; lots of stretching needed but it can take it! -Do whatever is needed to keep the washer from rattling. I just applied some thick silicone grease, and oriented the washer so the convex side was on the plastic bushing and concave side on the spring washer. Maybe this issue has to do with how this conical washer is oriented? For anyone interested in getting shims or alternative washers, I took some pictures and measurements while I was there. Last picture is linkage pin diameter than the washer fits over. |
| Ferrari like gear lever ? | mashal | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 10-20-2015 02:03 AM |
| first gear rattle | Raves614 | Engine, Exhaust, Transmission | 11 | 04-14-2015 10:39 PM |
| Found the source of a rattle, and fixed it! | BRZnut | Issues | Warranty | Recalls / TSB | 10 | 05-08-2014 10:39 PM |
| Front KNocking Noie and Gear Lever rattle | Naughty | AFRICA | 17 | 10-26-2013 02:56 PM |
| Transmission rattle while revving in gear with clutch both engaged and disengaged | robo_robb | Engine, Exhaust, Transmission | 2 | 06-16-2012 01:35 AM |
