Old 01-30-2020, 01:04 PM   #65801
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well now the computer tells you exactly which cyclinder it is [sometimes]! (Too bad you have to take off all the engine accessories just to get in there now a days though)..
I have been dealing with this damn mini van for 2 weeks now. The dreaded Chrysler 3.6
Cylinder #5 missfire.
I have replaced the coil. Verified power to the coil on the harness. Verified pulse signal from the PCM to fire the coil. Checked spark with coil out. Swapped coils with known working cylinder. Swapped injectors with known working. Tested injector. Verified power to the injector on the harness. Verified pulse signal from PCM to fire the injector.
Still missfires. Comp and leakdown is next
NoHaveMSG is offline
p1l0t (01-30-2020)
Old 01-30-2020, 01:14 PM   #65802
p1l0t
p1l0t's Avatar
I don't even talk about compression loss... if it gets to that it's a bad time probably.
p1l0t is offline
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
NoHaveMSG (01-30-2020), spike021 (01-30-2020)
Old 01-30-2020, 01:34 PM   #65803
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
@Ultramaroon @soundman98
Alright I know there are people that are way smarter then me on this, and well, in general
Each one of these heating panels is about 2100 watts and pulls 4.2-4.5amps. On leg one I am pulling about 36 amps in this zone. The manufacturer says it should be 55-60. I don’t see how the heck that’s possible.
He also says if I loose some panels it will put more load on the others. But from my understanding the panel can only draw what it can draw regardless of what the other panels are doing.
Am I crazy here?
korhun (01-30-2020)
Old 01-30-2020, 01:35 PM   #65804
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yay Asshat Crew! You guys are damn funny today. Happy Thursday, all!
Sapphireho is offline
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
NoHaveMSG (01-30-2020), soundman98 (01-30-2020), spike021 (01-30-2020), Ultramaroon (01-30-2020)
Old 01-30-2020, 01:53 PM   #65805
spike021
spike021's Avatar
Yep, I agree. Back in the day it was an easy diagnostic and fix.
Just pull off the spark plug wires one at a time till you find the one that doesn't change the idle speed. Replace that plug with one of the better looking plugs from the bag in the trunk. Yep, a 1/2 beer job.
humfrz - again, stuck in the 50s -
Thing is I did bring the car into a local shop a couple months back and asked them to check the spark plugs and stuff, and according to them the plugs were fine.
So unless they’re clueless, which I don’t believe is the case, then it’s gotta be something else.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (01-30-2020)
Old 01-30-2020, 02:01 PM   #65806
korhun
Database error
korhun's Avatar
Speaking of being smart, I have no idea what your are asking. All I can see is 2 buts, and 2 cemetery stones.
korhun is offline
The Following 7 Users Say Thank You to korhun For This Useful Post:
cjd (01-31-2020), Dadhawk (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020), ScoobsMcGee (01-30-2020), soundman98 (01-30-2020), Ultramaroon (01-30-2020)
Old 01-30-2020, 02:27 PM   #65807
Am I crazy here?
I see series-parallel config for the heating elements. If one of those elements opens, the resistance of that bank would approximately double. Can you disconnect just downstream of the line filter and test there?
Ultramaroon is offline
korhun (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020)
Old 01-30-2020, 02:30 PM   #65808
line filter, current sensing, isolation, ...whatever those devices are.
Old 01-30-2020, 02:33 PM   #65809
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
korhun (01-30-2020), p1l0t (01-30-2020), ScoobsMcGee (01-30-2020), soundman98 (01-30-2020), spike021 (01-30-2020)
Old 01-30-2020, 02:36 PM   #65810
Yep, they used to be right there on top - we have come a long ways -
humfrz is offline
p1l0t (01-30-2020), soundman98 (01-30-2020)
Old 01-30-2020, 03:43 PM   #65811
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
ScoobsMcGee is offline
The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post:
korhun (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020), Ultramaroon (01-30-2020)
Old 01-30-2020, 04:01 PM   #65812
ScoobsMcGee
So if anyone wanted to know what passes for a legit stop sign in York, PA. Here ya go.
The Following 5 Users Say Thank You to ScoobsMcGee For This Useful Post:
korhun (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020), Spuds (01-30-2020), Ultramaroon (01-30-2020)
Old 01-30-2020, 04:18 PM   #65813
ls1ac
ls1ac's Avatar
The butts are coils for the control relays.
The stones have their connections not shown so could do anything.
The pink heaters are two in series but have no values so V=IR needs one more value to be calculated.
ls1ac is offline
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
Old 01-30-2020, 04:23 PM   #65814
Glad you had more than the first pic since I thought you had the only area in PA with no trees!
Tcoat is offline
