Old 01-09-2020, 03:46 PM   #57
beastman5
Drives: non
KW C30 unsure if its the -94 but it has the all silver casing not the black casing that some have. The kit is off the car, all the bolts/screws removed from the unit except for the impeller(dont want to risk taking it off because I dont want to break the sunshaft) and the bolt in question .
I have taken off the pulley that the belt usually is attached. Under that pulley is a metal ring with 6 holes around it (that the pulley bolts into) and inside that ring is a larger allen head bolt. That is the bolt that I cannot remove. If i spin it the impeller spins on the other side, if i hold the ring with a plier (like you did with the counter spin tool) the bolt is stuck and no amount of torque takes it off (tried impact gun).
Should i hit the unit with a mallet to try to seperate the unit a bit? or do I have to loosen that bolt first regardless
beastman5 is offline   Reply With Quote
Old 01-23-2020, 03:00 PM   #58
poormansr
Drives: Japanese
U have Mail. Check yoour Private Messages..
poormansr is offline   Reply With Quote
Old 01-23-2020, 03:29 PM   #59
Well that isn't suspicious at all!
Old 01-23-2020, 06:30 PM   #60
poormansr
Drives: Japanese
lol its to the original poster..
im rebuilding a rotrex c30-84 and i wanted to ask him questions. and also ask if he had his original pictures he posted up. since those are down now..
LOL sorry i wasnt trying to be a wierdo LOL
guess what.. Check ur messages LOL
Old 01-23-2020, 07:33 PM   #61
LOL! Good. You have no idea how many people appear with one post and say "send me a PM". 99% of them end up being something shady.
Old 01-24-2020, 12:34 PM   #62
poormansr
Drives: Japanese
i was actually stuck on this part last week. Mine came with a KW 85mm Pulley. 6 small hex holding the Pulley to the Hub Adapter. the Hub adapter is Bolted down to the SC with 1 large Hex Bolt. That Bolt is a Pain in the ass checks.
I first tried making a Pulley Tool out of Aluminum , i thought it would be Strong enough. I tried my dewelt cordless brushless battery powdered Impact gun and Nothing. It wasnt strong enough..
so i charged up my air compressor and used a air gun at 120 Psi.. It destroyed the aluminum Pulley tool..
what i did was use a Old Oem Honda Tow Hook made out of Steel. I redrilled Holes for the Puley Tool. Then their was a Hole big enough to fit a 3/8 drive Breaker Bar. I used the air tool and Bam.. the Hex Bolt came Loose..
Old 01-24-2020, 12:40 PM   #63
poormansr
Drives: Japanese
Does anyone Know what Material the Impeller Shaft - Sun Shaft is made out of ?
nevermind that question. Im gonna end up Sanding down that 10.5 Oil Seal shaft section of the impeller Sun shaft down to a 10mm.. So i can find a more common oil seal of 10x21x5.
10.5 x 21 x 5 Oil seal is only made by one company SOG aka SO Giant. Ive tried emailing them. They said No. I found a company that wil reproduce custom size oil seals. I gave them that size and they said No. Even though i know someone who used them and made 4 oil seals in that Off size.
Lets say i wanted a Custom impeller Shaft made.. Who would i go to ? what type of Business would even do it ?
Oem rotrex Impeller Shaft - sun shaft
custom Made impeller shaft , looks like its 10-10.5 all the way through to the threads. Looks way stronger then the factory size of 7mm and 8mm
Old 02-17-2021, 04:44 PM   #64
beastman5
Drives: non
How did you guys remove the 6 bearings off the 3 rollers? My bearings seem so stuck no matter what I try pulling or prying with.
Shopping cars today, test drove an fr-s..my thoughts and I'd like more opinions plz. maybebrz BRZ First-Gen (2012+) — General Topics 55 11-04-2015 09:49 AM
Thoughts on Kraftwerks C-Type Rotrex Supercharger Piper606 Scion FR-S / Toyota 86 GT86 General Forum 5 07-31-2015 09:59 AM
FS:CA Brand new never opened KW INOX V3 for sale stiboost08 Brakes, Suspension, Chassis 6 07-31-2014 01:18 PM
FS/FT: Apple tv! Brand new never opened! Duthebarber Miscellaneous 0 10-07-2013 02:34 PM
18x8 Drag DR 38 +35 Never opened Tdooley Wheels and Tires 2 02-09-2013 11:42 PM
