#57 |
Drives: non
KW C30 unsure if its the -94 but it has the all silver casing not the black casing that some have. The kit is off the car, all the bolts/screws removed from the unit except for the impeller(dont want to risk taking it off because I dont want to break the sunshaft) and the bolt in question .
I have taken off the pulley that the belt usually is attached. Under that pulley is a metal ring with 6 holes around it (that the pulley bolts into) and inside that ring is a larger allen head bolt. That is the bolt that I cannot remove. If i spin it the impeller spins on the other side, if i hold the ring with a plier (like you did with the counter spin tool) the bolt is stuck and no amount of torque takes it off (tried impact gun). Should i hit the unit with a mallet to try to seperate the unit a bit? or do I have to loosen that bolt first regardless |
#58 |
Drives: Japanese
U have Mail. Check yoour Private Messages..
#59 |
Well that isn't suspicious at all!
#60 |
Drives: Japanese
lol its to the original poster.. im rebuilding a rotrex c30-84 and i wanted to ask him questions. and also ask if he had his original pictures he posted up. since those are down now.. LOL sorry i wasnt trying to be a wierdo LOL guess what.. Check ur messages LOL |
#61 | |
#62 | |
Drives: Japanese
![]() i was actually stuck on this part last week. Mine came with a KW 85mm Pulley. 6 small hex holding the Pulley to the Hub Adapter. the Hub adapter is Bolted down to the SC with 1 large Hex Bolt. That Bolt is a Pain in the ass checks. ![]() I first tried making a Pulley Tool out of Aluminum , i thought it would be Strong enough. I tried my dewelt cordless brushless battery powdered Impact gun and Nothing. It wasnt strong enough.. ![]() so i charged up my air compressor and used a air gun at 120 Psi.. It destroyed the aluminum Pulley tool.. ![]() what i did was use a Old Oem Honda Tow Hook made out of Steel. I redrilled Holes for the Puley Tool. Then their was a Hole big enough to fit a 3/8 drive Breaker Bar. I used the air tool and Bam.. the Hex Bolt came Loose.. ![]()
#63 |
Drives: Japanese
Does anyone Know what Material the Impeller Shaft - Sun Shaft is made out of ?
nevermind that question. Im gonna end up Sanding down that 10.5 Oil Seal shaft section of the impeller Sun shaft down to a 10mm.. So i can find a more common oil seal of 10x21x5. 10.5 x 21 x 5 Oil seal is only made by one company SOG aka SO Giant. Ive tried emailing them. They said No. I found a company that wil reproduce custom size oil seals. I gave them that size and they said No. Even though i know someone who used them and made 4 oil seals in that Off size. Lets say i wanted a Custom impeller Shaft made.. Who would i go to ? what type of Business would even do it ? Oem rotrex Impeller Shaft - sun shaft ![]() custom Made impeller shaft , looks like its 10-10.5 all the way through to the threads. Looks way stronger then the factory size of 7mm and 8mm
#64 |
Drives: non
How did you guys remove the 6 bearings off the 3 rollers? My bearings seem so stuck no matter what I try pulling or prying with. |
| Shopping cars today, test drove an fr-s..my thoughts and I'd like more opinions plz. | maybebrz | BRZ First-Gen (2012+) — General Topics | 55 | 11-04-2015 09:49 AM |
| Thoughts on Kraftwerks C-Type Rotrex Supercharger | Piper606 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-31-2015 09:59 AM |
| FS:CA Brand new never opened KW INOX V3 for sale | stiboost08 | Brakes, Suspension, Chassis | 6 | 07-31-2014 01:18 PM |
| FS/FT: Apple tv! Brand new never opened! | Duthebarber | Miscellaneous | 0 | 10-07-2013 02:34 PM |
| 18x8 Drag DR 38 +35 Never opened | Tdooley | Wheels and Tires | 2 | 02-09-2013 11:42 PM |
