Old 01-15-2020, 07:15 PM   #295
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I'll bet it's fewer than that. Honestly fitting the LS in here was pretty hard.
AWD is super off topic, but FWIW, the LS AWD oil pan sets the diff/front driveshafts in the correct spot for axle into front hubs... but still need to get around the steering shaft and subframe clearance issues.
Old 01-17-2020, 02:44 PM   #296
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
speaking of oil pans...... lol any updates on what that looks like for the kseries swap?
pgranberg11 is offline   Reply With Quote
Old 01-17-2020, 02:50 PM   #297
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Trying to make it affordable and repeatable. I know its taking a while but unless you guys want to pay $1000 for an oil pan like the one on KMiata, I need a little more time to figure out how to do it for less but still be a decent product.
Pure Automotive is offline   Reply With Quote
The Following 6 Users Say Thank You to Pure Automotive For This Useful Post:
Drifter X (01-17-2020), DustinS (01-17-2020), Jyn (02-10-2020), pgranberg11 (01-18-2020), wparsons (01-17-2020), Zer0 (01-18-2020)
Old 01-18-2020, 01:18 PM   #298
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
So you must be working on a cast piece then; a stamped piece would probably be more expensive and require large equipment. That should keep the price reasonable. For instance, I’ve seen cast bell housing adapters be reasonable in price compared to their CNC-machined, billet counterparts, which is surprising because they look OEM. Similarly, a custom welded oil pan that needs to be pressure/leak tested has to be more expensive than a cast piece that can get machined and decked quickly and consistently.
Old 01-18-2020, 02:18 PM   #299
Ashikabi
Ashikabi's Avatar
Casting is practical for large scale production. Fabrication is generally better for small run due to up front costs. I don't know how many of these they think they will sell or if there is some new cheap casting technology but I can't see casting being more practical.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Irace86.2.0 (01-18-2020), Ultramaroon (01-18-2020)
Old 01-18-2020, 03:05 PM   #300
Tough problem for the numbers. Maybe set up a core exchange for rework.
Old 01-18-2020, 09:26 PM   #301
Irace86.2.0
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Custom bellhousing for BRZ to CD009. It is hard to know what the bellhousing would retail for by itself, but I can’t imagine these kits selling in high volumes.
GM/LS to r154 Toyota trans bellhousing adapter
https://www.summitracing.com/parts/add-712561v/
Old 01-18-2020, 09:56 PM   #302
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I'm in no rush I was just looking to see what the latest was. Thanks!
Old 01-19-2020, 03:29 AM   #303
Irace86.2.0
Originally Posted by solidsnake11 View Post
You would be way better off with cd009. Had a 86 toyota truck 2wd with 7m gte 450rwhp, broke 3 r154s sold it because of the issue. R154s do not like 1st gear burnouts, always do burnouts in 2nd with the 154.
Ok...thanks...for the info ...but those were suppose to be examples of bellhousings that were produced at relatively low volume with decent prices to support my theory that Pure Auto might be working on a cast oil pan.
I suppose they could be working on a machine welded oil pan versus a custom welding one too, but again, I was just posting links and examples of bellhousings that didn't break the bank. Maybe you missed that.
Old 01-24-2020, 04:33 PM   #304
Pure Automotive
UPDATE!!
-After consideration of a lot of factors, we have decided to go with a modified steel stamped pan. The pan will be steel, designed to clear the 86 cross member using our K Series mount kit.
-The pan will come with an aluminum baffle that bolts in. The baffle is designed to shield the oil pickup from sloshing under hard braking and acceleration.
-The pan will require that you switch the oil pump to the RSX Type S oil pump. This is for a couple of reasons. 1-The stock K24 oil pump with balance shaft is a huge piece that makes fitting a pan around it while still clearing the cross member almost impossible. 2-The RSX oil pump allows up to 8500 RPM before it has any cavitation issues. There are hundreds of write ups and videos out there about changing the oil pump to the Type S, it requires the pump, a different lower chain, a couple bolts, and a windage tray.
We have the final design of the pan on our test car along with the baffle. Clears with no issues using our mounts! They will be ready to sell within 2 weeks we are hoping. I will have a Pre-Sale available on swapyour86.com soon.
Baffleclose by Brady Johnson, on Flickr
PanOnCar by Brady Johnson, on Flickr
The Following 5 Users Say Thank You to Pure Automotive For This Useful Post:
Drifter X (01-24-2020), DustinS (01-24-2020), Irace86.2.0 (01-25-2020), pgranberg11 (01-28-2020), venturaII (01-27-2020)
Old 01-24-2020, 06:19 PM   #305
venenon
Drives: 2013 FRS , 2002 MDX, ZZR600
👏 buying it as soon as it posts. my swap is going down president's day weekend. Thanks for all your hard work. The best solution I've seen so far and looks amazing.
venenon is offline   Reply With Quote
The Following User Says Thank You to venenon For This Useful Post:
Pure Automotive (01-27-2020)
Old 01-24-2020, 06:32 PM   #306
Ashikabi
Ashikabi's Avatar
Starting or finishing?
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 01-24-2020, 07:16 PM   #307
venenon
Just starting. Stockpiling parts until now.
Old 01-24-2020, 07:18 PM   #308
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Can't wait for your update!!
Drifter X is offline   Reply With Quote
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 02:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 12:57 PM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:49 PM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:23 PM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 07:33 PM
