#379 |
Drives: 2013 FRS
I finally have an end to the long journey, i hope. My car entered the dealership with a blown engine on June 2 2019, I picked up the car this week 4 1/2 months later. Toyota Canada covered the replacement short block after I hired a lawyer, it 1 1/2 months to get the parts. The car sat outside all summer so all the brakes were completely rusted everything was replaced after the rear piston seized while driving. I never saw a nice summer day this year. Interesting to note there are some people that knew that the way I was treated was wrong and they now have a specific protocol for dealing with this type of issue at least in Canada. The Dealership was great, they are car people and fought for what I finally received. Yelling and screaming will not work but clearly pressure will. I have been disappointed with the way all this was handled and now drive a car that I am not sure I trust. The engine now has a warranty, the dilemma is do keep the car with a new engine or do I sell the car with a new engine warranty? I feel for anyone having to go through this, at least it is fun to be driving again.
| The Following 2 Users Say Thank You to Parrot Head For This Useful Post: | DarkPira7e (12-09-2019), gravitylover (10-27-2019) |
#380 |
Drives: Toyota 86 2012
Vehicle Mileage: 96307 km (59842 miles)
Vehicle Make: Toyota 86 (2012) in South Africa Mileage After Recall Performed: 1414 km (878 miles) Symptom(s): Vehicle started making odd noises (I now know this was knocking) while driving home from work, then died on the side of the road. I happened to be logging some parameters during the death trip, and (afterwards, when looking at the data) saw IAM going down from 1 to .84, then .5, then .24, then the car stopped. Engine oil temperature went up to 120 degC (248 degF) even though rpm stayed below 4000. Failure: Big end bearing spun, cylinder nr 3. State: Gauteng, South Africa Is Dealership Offering Repair: Yes, currently it looks like they will. They initially quoted R45,000 (approx $3000) for a new short block, stating that the vehicle is no longer under warranty and that "the recall was done but has nothing to do with the damages on the engine as this failure is internal and not from the valves." I then sent them a rather detailed technical summary of the issue (forum posts, the spreadsheet with cases, a summary of articles from thedrive.com etc.). They did not engage with me on a technical level at all, just continued stating blankly that the failure is not related to the recall work. After some more back and forth, the service manager changed course, and offered to repair the car via a "goodwill claim" to Toyota South Africa (which must still be approved). They've ordered parts and started the repair work, although I have not agreed to pay for it. So now for more waiting. Last edited by cheymann; 12-13-2019 at 09:52 AM. Reason: Updated with new developments in my story. |
#381 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
This kind of borderlines on "telling the dealer how to do their job." We like to think we're being helpful, but 95% of people who go to the dealer don't understand cars (like how to rotate their tires or do an oil change). Dealers (and most shops) just need the general symptoms. Usually when you start diving into specifics, they only look at those specifics (which cost you money in the long run). |
#382 |
Drives: brz 2017 hksv2
In italy they started doing the recall since few month, the first destroyed engine from rod bearing knock are coming out (at least 3 I know), all Toyota and dealer say it s the customer fault and they Don t want to pay
#383 |
Drives: ‘13 BRZ Limited SWP
Vehicle Mileage: 42,756
Vehicle Make: Subaru Mileage After Recall Performed: ~1600 (44,350) Symptom(s): I was coming home from work and lifted off the gas as I approached my exit off ramp. Oil light flickered for a couple seconds, then came on solid followed immediately by CEL, followed by stall. Very bad knock on restart. Drove a few hundred feet to a safe area despite it sounding awful. Failure: Spun bearing State: WA Is Dealership Offering Repair: Not even sort of, quoting $13k. Subaru won’t even authorize an engine tear down and want to charge labor if I want that, but seems unlikely they will change their mind even if I find anything. Oil pan was pulled and there were some threads in the pickup but no massive sealant blockage. You would think for a company that bases their entire brand around people loving their cars they would be willing to entertain the idea of fixing a problem to keep a customer happy. |
| The Following User Says Thank You to Snow27 For This Useful Post: | bcj (12-16-2019) |
#384 | |
Drives: 13' Lightning Red Brz
| The Following User Says Thank You to Ichima For This Useful Post: | Gunman (12-17-2019) |
#385 | |
Edit: I’m not even sure what rod it is, though I think it’s safe to assume #3 or 4... |
#386 | |
#387 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (12-17-2019) |
#388 |
Drives: Whiteout FRS
#389 | |
Drives: 2013 Scion FRS & 2022 GR86
Sent from my SM-G965U using Tapatalk
2013 Scion FRS 2022 Toyota GR86 |
#390 |
Glad to hear that you are fine with it. Unfortunately I am located in So Cal so Concord is a little far for me. Thank you for the information though.
| The Following User Says Thank You to dezmoondo For This Useful Post: | Exrald (01-07-2020) |
#391 | |
#392 | |
Drives: Ultramarine FR-S 6 speed
hey dezmoondo, Where are you located in so cal if you don't mind. I have to take my car in for the recall fix and I am trying to find out who in socal has done it and where without having any issues. Like you stated, that now the dmv is requiring it otherwise I won't get my tags. I'm in the same boat man.
| Tags |
| fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
| Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
