Old 12-27-2019, 06:36 PM   #1
nwgabrz
Drives: BRZ Limited
Gear Shift Indicator not showing, although it is selected 2017
The GSI (Gear Shift Indicator) is selected on the screen and is on, but the cluster does not show which gear the car is in, including reverse. It showed before, but all of a sudden, it is not longer showing. I tried turning it on and and then off and tried disconnecting the battery and reconnecting it, and it still will not turn on.
Any help or ideas?
It is a 2017 cluster.
Thanks!
nwgabrz is offline   Reply With Quote
Old 01-13-2020, 08:20 PM   #2
willburr
Drives: 2017 BRZ
First place I'd check is the clutch switch.
Is the cruise control working?
willburr is offline   Reply With Quote
Old 01-13-2020, 11:12 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Read your manual. It's in there.
Why it got turned off? Beats me.
Old 01-14-2020, 11:21 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Is gear indicator by default on for MY2017? It certainly wasn't on early cars, thus battery disconnects were what reverted to default of not displayed, indicator that was manually enabled prior disconnect.
Old 01-14-2020, 03:52 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The only gear it will show regardless of clutch state is Reverse.
1-6, you need to have clutch in with engine running and car rolling. ECU probably uses RPM and Wheel Speed to calculate gear
EndlessAzure is offline   Reply With Quote
Old 01-14-2020, 04:07 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, indeed it's so, and i dislike laginess how gear is displayed due that, relatively long after actual gear change. It shouldn't be too hard to add some not that complex sensors in gearbox to read gear right away w/o calculating, but i guess such thing was outside things to implement in car, essence of which is to be good enough for cheap, not best at any costs, including extra features/gadget area.
Old 01-14-2020, 05:57 PM   #7
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Calculations implemented in software are dirt cheap to replicate and install.
Switches and sensors add to the cost of the vehicle.
LimitedSlip is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
2017 Dynamic Shift indicator. paulca Scion FR-S / Toyota 86 GT86 General Forum 10 08-10-2017 07:49 AM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 08:23 PM
Selected gear indicator on dash for Manual transmissions. Rumbaar Cosmetic Modification (Interior/Exterior/Lighting) 18 02-14-2016 09:56 PM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 02:50 PM
