Old 01-12-2020, 08:52 PM   #1
pher.da.rico
Drives: 2018 Premium Black silica BRZ
Leak on top tranny!!??
I was wondering if anyone knew what this leak is about !? I don’t know what to check for. Please help !
pher.da.rico is offline   Reply With Quote
Old 01-12-2020, 09:18 PM   #2
pher.da.rico
So the “leak” is from my master cylinder I believe. How should I approach this ?
Old 01-12-2020, 09:28 PM   #3
It's the slave cylinder. Replace it.
Old 01-13-2020, 04:03 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Car is totaled.
What ultramarron said.
Simple fix if you can use a wrench.
Old 01-13-2020, 07:35 AM   #5
pher.da.rico
Thank you guys !
Old 01-13-2020, 01:29 PM   #6
Stomachbuzz
Drives: 2013 FRS
Did you discover that because your clutch pedal was getting sloppy?
Stomachbuzz is offline   Reply With Quote
Old 01-14-2020, 01:17 AM   #7
pher.da.rico
@Stomachbuzz not so much but every now and then when I let off the clutch there’s a knock sound!
Old 01-16-2020, 11:30 PM   #8
I forgot to remind you to check the fluid level in the clutch reservoir. A small leak by itself will have no effect on typical clutch operation. Only when it gets bad will it start leaking down allowing the clutch to drag while the pedal is held for long periods.
Don't let the reservoir run dry. Life sucks when the clutch goes away.
pher.da.rico (01-22-2020)
Old 01-17-2020, 06:57 PM   #9
pher.da.rico
Just checked it and it’s at max capacity
The Following User Says Thank You to pher.da.rico For This Useful Post:
Ultramaroon (01-17-2020)
Old 01-20-2020, 12:15 AM   #10
ng-86
Drives: 18' 50th An. BRZ, 79' RX7
Did your clutch pedal start to feel any different? Mine started to feel a touch rough along its travel, which prompted me to check the fluid level and notice the fluid stain in the same spot beneath the slave cylinder. My fluid level is also at max.
I guess it’s not a huge issue, but if you’re still under warranty, may as well see if they’ll replace it- I plan to on at my next service.
ng-86 is offline   Reply With Quote
Old 01-22-2020, 07:28 AM   #11
pher.da.rico
So I didn’t think much was wrong with my clutch till today my girlfriend got herself an 86 and the clutch feels way smoother. my clutch reservoir is dirty. Can anyone let me know why it is that my slave cylinders would fail?
Old 01-22-2020, 07:17 PM   #12
The roughness that you feel is all under the bell housing. Typical crappy situation. The stuff that you see in your master cylinder reservoir is just normal rubber dust from the piston seals. I say that with confidence because you haven't lost any fluid.
pher.da.rico (01-23-2020)
Old 01-23-2020, 04:09 PM   #13
pher.da.rico
After I replace it would I need to bleed the system? By the way thank you all for your time and help!!
Old 01-23-2020, 04:17 PM   #14
My pleasure! What are we replacing? I recommend not worrying about the slave cylinder unless it gets really soggy around the rubber dust cover over the end. I don't think that anything is wrong with it.
Bad tranny Retrorv Issues | Warranty | Recalls / TSB 16 10-16-2018 07:50 PM
Looking for 86 A/T Tranny Soloside Want-To-Buy Requests 0 03-10-2017 10:45 AM
STI JDM tranny mount vs Perrin tranny support NVH khrono Engine, Exhaust, Transmission 2 03-15-2016 09:43 PM
Tranny to Driveshaft Oil Leak BDotG Engine, Exhaust, Transmission 3 09-07-2015 12:05 PM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 07:53 AM
