Old 01-11-2020, 08:51 PM   #1
yash
Drives: 2013 Scion 10 Series FR-S
Installed backup camera install, now the car wont start :(
Hey guys,
I installed a backup camera today on my 2013 FR-S 10 series, got it working until I somehow managed to break something with electrical and now my car won't start. It's not the battery (tried jump start) i've checked most of the fuses and they are ok. I haven't checked the relay and not sure how. I've recorded what's going on below.
Any help is much appreciated
Problem:
yash is offline   Reply With Quote
Old 01-12-2020, 02:04 AM   #2
Originally Posted by yash View Post
Hey guys,
Problem:
Hello yash and welcome to our group -
So, your car is an AT, are you sure the shifter is solidly in "park"?
What else, if anything, did you do the car around the same time you installed the back up camera?
I'd suggest you "review" what you did to install the camera, to see what might have gotten "unplugged".
You might check to make sure the ECU is screwed down tight.
Since the battery is turning the engine over good but it's not firing, it's most likely not getting fuel or spark (ya, I know daaaaaa).
OK, some other folks will be along soon, to - take er on in -
(mumble-mumble, back in the 50s it would have been it was either out of gas or someone pulled the coil wire off)
Old 01-12-2020, 12:42 PM   #3
entaroadum
Drives: 2013 Subaru BRZ
Hey guys,
Problem:
I noticed you said in the youtube comments that you wired the camera to the reverse light. I would suggest checking that connection, maybe it is shorted and making the car think it is on 'R' instead of Park.
That is assuming it is an AT car...
entaroadum is offline   Reply With Quote
Old 01-12-2020, 02:11 PM   #4
norcalpb
norcalpb's Avatar
Did you plug the connector back into the Amp when you were done?
Old 01-12-2020, 06:53 PM   #5
yash
Thanks for replying!
Yes i see the park indicator next to gear and on dash,
It could be the fuel or spark, its sitting in garage now, guy said he would take a look tomorrow, will post update
Old 01-12-2020, 06:55 PM   #6
yash
entaroadum, Definitely messed with the reverse wire, but i do see that it registers park and drive when i change gear and yes its an AT
Old 01-12-2020, 06:56 PM   #7
yash
yes i did plug it back
Old 01-14-2020, 12:08 AM   #8
Well, @yash, did you get your car started?
Old 01-15-2020, 08:09 AM   #9
RickyBobby
Drives: 2013 Firestorm FR-S AT
Hey guys,
Problem:
How can anyone here help you if you do not tell us exactly how you wired up the backup camera and what camera you purchased???
RickyBobby is offline   Reply With Quote
Old 01-15-2020, 08:23 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Revert back to stock and see if the car will start.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-15-2020, 06:37 PM   #11
mrhayes1
Drives: 2013 Scion FRS white
As others have said, check all connections and basic stuff first. Is it an alarm issue, is shifter in park, etc.? I find it highly unlikely that the majority of the backup camera wiring would impact the car from starting; even if you ground something out. If I recall from doing mine, you should have tapped into a power source in the trunk to power the camera (ground should go to other wire paired with the + you are getting power from). Your video jack will connect to the headunit of course; pretty straight forward.
Where I could see issues is when you tap into the reverse wire at the driver side kick panel. Your FRS doesn't have a trigger wire and I didn't watch the video but I assume you did this. Your trigger wire should go from the head unit to the reverse wire (located by the drivers side left foot area), and perhaps you shorted something out. If you used t-taps like I did to tie into the cars reverse wire, perhaps you could have completely severed your cars reverse wire all together. That's an easy fix if so.
mrhayes1 is offline   Reply With Quote
New headers installed but car wont start Snitko13 Engine, Exhaust, Transmission 34 07-22-2019 12:07 AM
Backup Camera Install Help Kaotic Lazagna Electronics | Audio | NAV | Infotainment 7 11-26-2018 04:27 PM
INSTALLED TURBO, CAR WONT START Nightflo Forced Induction 23 06-23-2018 09:26 PM
Backup camera installed in FR-S babydriver DIY (Do-It-Yourself) Guides 3 04-16-2015 05:07 PM
Anybody can help me install a backup camera? dingledangle Northern California 0 12-01-2014 11:25 PM
