Old 01-10-2020, 05:30 AM   #1
gt7877
Drives: turbo frs
white smoke
Dear
I have turbo frs
From the first tune (Dyno tune)
To the second remote tune (online)
I noticed that when I put gear for example at 3rd gear and rpm
Lower than 3k some withe smoke coming from exhaust .
What could be the issue ??
Thnx
gt7877 is offline   Reply With Quote
Old 01-10-2020, 07:12 AM   #2
Grady
Grady's Avatar
White smoke is coolant.
Blue smoke is oil.
Black smoke is fuel.
White and Blue smoke look similar. Have you had a chance to smell the smoke. Coolant will have a sweet smell, oil will smell like.... burned oil.
The Following User Says Thank You to Grady For This Useful Post:
YamahaR86 (01-10-2020)
Old 01-10-2020, 07:48 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
yep thats coolant so your either cracked your block or blew a head gasket
Old 01-10-2020, 10:12 AM   #4
gt7877
Drives: turbo frs
Nooo
This happened just at high gear and low rpm
Coolant level is good all the time
Also oil level is good
Old 01-10-2020, 11:06 AM   #5
Breadman
Breadman's Avatar
Originally Posted by gt7877 View Post
Nooo
have you tested it to make sure? it might be a very minor leak under high load. does the smoke stick around or go away pretty fast like when you start a car in the cold?
Old 01-11-2020, 02:52 AM   #6
gt7877
Drives: turbo frs
My dear
This just happened at low rpm
Or when I shift to reverse .
Just for few seconds and gone when rpm go up
I think it is maf scaling issue
Steve any thing from your side
Old 01-11-2020, 07:26 AM   #7
steve99
Drives: FT86
Very unlikely to be a tune related problem unless it was black fuel smoke
Smoke is most likely oil, but possibly coolant
Coul be turbo seals
Catch can routing issue
PCV vavle or check valve issue
Rings valve guides worn broken
Overfilled oil
Blocked or restricted turbo oil return
Check turbo intake for oil
Overoiled air filter
Probably a few others
It only takes a small amount of oil to see smoke might take a fair bit of driving before you see levels drop.
gt7877 (01-12-2020)
Burning smell and white smoke Tacticalpanda Issues | Warranty | Recalls / TSB 22 09-04-2024 08:18 AM
White smoke decelerating azynneo Engine, Exhaust, Transmission 6 07-23-2016 10:14 AM
Cloud of white smoke on startup wawro569 Issues | Warranty | Recalls / TSB 25 01-16-2015 12:55 PM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 06:10 PM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 04:23 PM
