#29 | |
TRACKBREAD
I haven’t found many reviews but they are consistent in saying that they are marginally better than stock, definitely no worse. |
#30 | |
Drives: FR-S Whiteout
The 309 stoptech sports compared to the stock pads there is a noticeable increase in heat capacity and slightly better initial bite. More than just "barely better" than stock pads. Where the stock pads would fade, such as toward the bottom of a downhill run, on the stoptechs I'd have to be really pushing. At the track, depending on the driver they might last one lap or more, but they definitely did last for many more miles after a full track day. Not sure what pad (Stoptechs) these other guys are using where it performs worse than stock, but I highly doubt they're the same ones ive been using. The TRD pad seems to be similarly priced to the Stoptech sports, maybe a $10 more per pair. Worth a shot. For me, TRD pads would be a question mark that would cost me extra $20 to answer. I'd stick with a sure thing in the stoptechs, since I already know what to expect.
Intent > Content
cowardice is the mother of cruelty. |
#31 |
Drives: 2014 GT86
Pads do not exactly increase heat capacity, which is more thing of rotor mass (and from enhanced cooling rate in eg. BBK or from brake ducts and alike).
Uprated/more track oriented pads simply have higher working without fade temps range, not increased heat capacity of brakes. |
| The Following User Says Thank You to churchx For This Useful Post: | wparsons (01-07-2020) |
#32 | |
Drives: Crapcan
#33 | |
Intent > Content
#34 |
Drives: 2015 Subaru BRZ Limited ISM
Not true. If you're in a place that's cooler in the winter the stoptech 309 (Sport) will squeal. Mine squeal under light braking in the winter. They're fine at higher ambient temperature. However my biggest problem with them is the dust. They dust like crazy after a few weeks.
#35 | |
Intent > Content
#36 |
Drives: 2013 Scion FRS white
Here's my 2 cents. I think aftermarket/performance brakes pads are highly overrated in terms of performance unless you are on a track, etc. I did quite a bit of research on aftermarket pads and was considering the Hawk pads (cant remember specific type/model). Anyway, after quite a bit of research, I stuck with OEM for the following reasons:
1. Consistency: I know OEMs are always consistent (unless driving really hard or on the track). I want to be a able to get off the freeway in Arizona in the middle of summer or winter and slam on the brakes and know exactly how they will behave. OEM pads are consistent and don't need a warm up time. If you buy a high temp performance pad you will probably pay the price for it when you get off the freeway after miles of not touching the brakes in the winter time. 2. Compound: I read various reviews on ceramic pads and stuff and was scared of destroying my rotors. Many reviews with higher performance pads blamed very premature failure of rotors on the pads. Remember, if you buy ceramic pads they may last forever....but your rotors wont. 3. Brake dust: OEM pads are good and brake dust isn't bad. I don't want my nice Niche wheels covered in brake dust after one day of driving just so I can shorten my stopping distance from 100-0 mph by 2 feet. 4. Squeal: OEM pads are quiet. Some aftermarket ones aren't. In summary, my advice is go with OEM unless you either drive extremely hard on the street or track the car. |
#37 | |
Only downside was more brake dust.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | solidONE (01-11-2020) |
#39 | |
Drives: Crapcan
An aggressive track oriented pad is nowhere near this temperature sensitive. |
#40 |
Drives: Friggin Really Sweet
Hello i use Winmax W3. A W2/W3 sounds like its what fits your needs.
With W3 you dont have to worry about fade as much during ur rare runs and works right off and becomes optimum after a certain temperature threshold. Heres a short blurb: W2 – The W2 is a step up from the W1. It still provides a very consistent feel of the stock pads, use parameters are the same, where it is mainly designed for street use, but with a lot more overhead and the most sporting of the pads that are still non-metallic. Because it is non-metallic like the W1, it has no significant dust issue or noise levels to be concerned. W2 increases driver control feel, a bit more bite, and higher temperature ranges and predictable fall off for when it does fade eventually. You get a slightly better sporting use characters, and endurance, but still without the concerns associated with racing brakes. Perhaps the best I can recommend if you are a typical casual Sunday low speed track folk, or auto-crosser, and still predominantly daily driven car, on summer radials. It is also a good economical upgrade. It’s minimal requirement too, if you are a down-hill canyon enthusiast. W3 – W3 is the most economical grade of so called, “metallic pads” which introduce a ton more braking control, very different bite characters that are more intended for track conditions, and use of race compound tires. If you are an avid track driver, or semi-professional autocrosser, this is where you’d start to see very positive and racing use braking forces. Of course, as with any metallic compound mix brake pads, you will encounter increased rotor wear, noises, and black dusting, and daily driven role becomes more a secondary use. It’s still perfectly safe for street, as long as you can deal with dust and slight noises. Some can, others abhor it… That’s just a choice for what people place as priority. W3 is VERY capable on the Sunday race scene, totally fir for those who use the brakes to 100% capacity, and driving skills to take it there. Autocrossers and canyon runners will feel a new level of control and bite, that extended consistently into very high temperature ranges. It does strike an exceleent balance for those that need a daily driven brake pad, and are not willing to forgo any performance, at cost of a bit of noise, dust, and slightly higher wear rate. |
#41 |
Drives: MY14 86 GTS Manual Velocity Orange
I have recently switched over to Intima SR pads. They're a street/race pad. I don't do any track work but wanted a pad that gives more bite for heavy road use i.e. blasting through the twisties. I am happy with them and they have been a good upgrade from the stock pads.
Don't know if these are available outside of Australia though. https://www.intimabrakes.com.au/home...ate/intima-sr/ |
#42 |
Drives: 2019 BMW ///M4
I had the stop tech and they were only a tad better than the stock pads. You'll end up with more noise with a more aggressive pad (if you're okay with that).
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 06:27 PM |
| Narrowing down my next car: TLX vs. WRX | AznBRZer | Other Vehicles & General Automotive Discussions | 26 | 02-10-2015 11:15 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
