Old 01-08-2020, 08:01 PM   #15
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so what is the maxium camber that i can be running daily? I was running -2.5 front last year then got some indys and was running on the outside edge. So i maxed the plate out for about 1/2 a degree more and i still had a hotter outside than inside. This year ill be running re71rs and figured id even even more but i dont want to shred my dailys.
i was thinking about asking the place to set me at -3 front and keep the back at -2.1 but leave 1/2 a degree so i could max them out at events and not have a huge toe problem
Old 01-08-2020, 08:45 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm on -4/-2.3 right now and just eating the tire degradation at the front inside on the dailies with cheaper Indy 500s, -3/-2 with an additional half a degree available up front for testing makes sense. I say grab some toe plates and zero out the toe yourself, sure it's extra work but eventually you'll know how much to turn to get it to work.
ineedyourdiddly
Old 01-08-2020, 08:46 PM   #17
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
As long as you toe it to zero, and depending on the softness of the tire, anything in the -3 range should be fine. On regular roads, you normally aren't going to be using that much camber through dynamic camber loss and you will have decreased braking performance... but as long as you are smart, it is fine... in the southern US.
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
DocWalt (01-09-2020)
Old 01-08-2020, 09:00 PM   #18
Breadman
Breadman's Avatar
do you have a link to these plate? i thought they only made rear toe arms. is there a calculator on how much toe out you get added with camber? im already running toe out up front so it might just make sense to pick something and 0 it then i adjust it at the event and then ill have toe out. also suspension isnt my forte
yeah i drive this in the snow. not trying to drive to work with -3.5* tilty wheels in the slush.
Old 01-09-2020, 07:34 AM   #19
steverife
Drives: 2016 Scion FRS
I assume he means toe plates, as in the alignment tool.
http://www.longacreracing.com/produc...9&prodid=10270
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (01-09-2020)
Old 01-09-2020, 09:27 AM   #20
M0nk3y
If you're running your car in winter, it makes sense to just reset alignment to something reasonable and deal with it come the spring.
I run -4.2/-2.5
Debating on more front camber for next year
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
Old 01-09-2020, 09:47 AM   #21
Mball19
Drives: Toyota 86 TRD/SE
Has anyone else looked at the 2020 draft rules? It looks like the twins have been moved into STS for 2020.
Mball19 is offline   Reply With Quote
Old 01-09-2020, 10:23 AM   #22
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I see this as well. This would put the twins in a totally different slower pack. (not that I've ever won my class since im out-tire'd and out-skilled)
Whereas I normally race against a few Civic Si, Mini Cooper S, and some 3 series BMW's, now it would be a field of non-si civics, non s coopers, and most any NA compact cars.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 01-09-2020, 10:27 AM   #23
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
M0nk3y has a setup that works, but the front camber previously seemed extreme. Now, I don't think so.
I'm going to go up in camber in front this year. I'll probably be in the -4.1 range.
I switched to 7k springs in the front during the down season, so with the softer setup, I decided to raise my car's ride height. I noticed at national's last year, I was probably the lowest setup, and not in a good way. In a different thread I mentioned bottoming out (tire hitting the top of the wheel well), and I want to reduce that.
With more travel and softer springs, and Yokohama tires, I think I'll have more front grip, so I'll probably need more camber. I measure tire temps, so I'll know if the adjustment helps.
Sent from my SM-G930P using Tapatalk
sifl is offline   Reply With Quote
The Following 2 Users Say Thank You to sifl For This Useful Post:
snoxracer183 (01-14-2020), strat61caster (01-09-2020)
Old 01-09-2020, 10:36 AM   #24
BarryOtt
Hmmm, that doesn't make sense. The stock limited slip diff is specifically not allowed in STS so all the twins would have to install aftermarket diffs????
"STS class: No limited slip differentials are permitted except for factory standard viscous coupler-type units."
I suspect the twins will be moved backed to STX after this is pointed out to the SEB...
Letter sent to the SEB requesting they stay in STX
Doh, looking a little closer, it's just the header on that column. It should have been "STX continued" instead of "Street Touring Sport". The next page has "STS Continued" but that's really the start of STS (it starts with Acura....)
BarryOtt is offline   Reply With Quote
The Following User Says Thank You to BarryOtt For This Useful Post:
yelsew (01-09-2020)
Old 01-09-2020, 10:50 AM   #25
ka-t_240
That also means every stx brz setup is illegal as tire and wheel size is reduced.
****Looking at Rules, I think SCCA messed up. The title shows STS but, STS clearly starts on the next page as they always do groupings by manufacture in alphabetical order.
ka-t_240 is offline   Reply With Quote
Old 01-09-2020, 10:55 AM   #26
BarryOtt
See above:
"Doh, looking a little closer, it's just the header on that column. It should have been "STX continued" instead of "Street Touring Sport". The next page has "STS Continued" but that's really the start of STS (it starts with Acura....)"
I sent a letter to the SEB to point it out...
Old 01-09-2020, 02:25 PM   #27
Autoxer62
Perhaps in those letters ask for the 2018-2020 cars to be included too? Right now the STX listing ends at 2017.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 01-09-2020, 06:44 PM   #28
cjd
cjd's Avatar
Drives: 2017 BRZ
STS, STX... I'd still be slow.
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
