Old 01-01-2020, 09:17 PM   #18047
edwardl
Drives: 2018 BRZ
Originally Posted by Busybee View Post
That was the initial plan. The module has the - (ground) and + (fuse tap with 10A fuse includes- not sure which fuse to use, maybe the p/pin1 or 2 which are the cigarette lighters). But in addition to those two wires there is also an auxiliary wire which is for custom color door opening.
I tried to wire it to the door light trigger but it did not light up when opening the door. I was little scared to short the system so I decided not to wire it. What I want is that the auxiliary wiring gets activated like the dome light when you get closer to the car with the key fob.
The footwell illumination with the cigarette lighter turns on only when the engine is on. Ideally the whole system should be activated with the dome light and change the custom color when the door is opened.
Will definitely search and finalize a hardwire.
Thanks
I still haven't hooked up my auxiliary wire. I tried to tap it into the dome light but all it did was short out my bulb lol. I may try to get another fuse tap and find the dome light fuse for that.
Anyway here's where I have the fuse tap. It's the unlabeled spot next to the tail light fuse.
They only turn on when the car is on. Only thing is when you put the fuse tap in, you can no longer put the fuse box cover back on. I just keep it in the glove box.
Here's the video I mentioned that shows where to ground it.
[ame]https://www.youtube.com/watch?v=MS4TBKhM1u8[/ame]
edwardl is offline   Reply With Quote
The Following User Says Thank You to edwardl For This Useful Post:
Busybee (01-01-2020)
Old 01-01-2020, 09:28 PM   #18048
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Thanks for the extra information. I wired my radar and camera with fuse taps so the cover is already in the glove box
Never thought about an unlabeled fuse slot (Tbh I did not know whether they are just + getting activated with the engine start). Good to know!
Do you think that the dome light is the only option to get the system activated before you start you car?
Would be nice to to have the system light up when the dome light is on.
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 01-02-2020, 12:23 AM   #18049
HaXx
Drives: jrsc_brz
Thanks
That would be smooth, open your door at night and the dome light and your 8nterior lighting comes on.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Busybee (01-02-2020)
Old 01-03-2020, 02:32 PM   #18050
norcalpb
norcalpb's Avatar
Sanded/buffed my headlights. They were looking pretty crap after 6.5 years.
The Following 5 Users Say Thank You to norcalpb For This Useful Post:
Busybee (01-05-2020), Lonewolf (01-05-2020), MJones_RB (01-07-2020), new2subaru (01-06-2020), re-animator (01-09-2020)
Old 01-06-2020, 12:08 PM   #18051
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Same here! I picked up the $9 turtle wax kit and it fully met expectations!
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 01-06-2020, 06:18 PM   #18052
edwardl
Drives: 2018 BRZ
Seibon CSL carbon fiber trunk. Still not sure if I like it.
The Following 3 Users Say Thank You to edwardl For This Useful Post:
HaXx (01-08-2020), JD001 (01-07-2020), MJones_RB (01-07-2020)
Old 01-06-2020, 06:22 PM   #18053
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Damn that’s beautiful
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
edwardl (01-06-2020)
Old 01-07-2020, 02:24 AM   #18054
JD001
JD001's Avatar
Drives: Subaru BRZ
The carbon trunk is very nice, however, IMHO the car ride height needs to be tweaked so that the truck is visually balanced and why not swap the hood?
Old 01-07-2020, 01:11 PM   #18055
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I did the same thing, sadly it's a temporary fix. Once you sand off that factory clear coat, they are always going to haze up again. You can try adding some film protection on top after you buff them, that might help.
MJones_RB is offline   Reply With Quote
Old 01-07-2020, 11:02 PM   #18056
MilkyWitness
Drives: fdsgh
asdf
MilkyWitness is offline   Reply With Quote
Old 01-08-2020, 10:13 PM   #18057
Chikna
Drives: 2018 BRZ TS 244/500
I was driving on Hwy 290 (Houston) and I hit an object not sure what it was could be a metal and in fraction of a second I had a flat tire. I could barely drive 300 ft and I had to stop in the shoulder. Luckily, there was a tow truck and drove me home (just under 5 miles) took $125 for a flat bed price I guess. He inspected the tire and it had a slit on the front left side, he also said there was no damage to the car except the tire.
Question is does Subaru replaces the tire since the car is just a year old?
Chikna is offline   Reply With Quote
Old 01-08-2020, 10:25 PM   #18058
Decep
Drives: 2013 FR-S Series 10
i bought some 3m clearcoat wipes that come with a sanding disc that worked really well and was super easy to apply. highly recommended and only like 5 bucks
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
MJones_RB (01-09-2020)
Old 01-08-2020, 10:38 PM   #18059
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Not for free
Old 01-09-2020, 07:36 AM   #18060
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
midnight dragon in the moonlight.
the new section of foothills parkway is quite stellar
thomasmryan is offline   Reply With Quote
