Old 01-06-2020, 01:12 PM   #21491
kyle116
Drives: 2015 Scion FR-S
Originally Posted by Busybee View Post
Finally got them. Do not know why I did wait so long!
If you have the driver side mat as well, the mat ends up scratching up the dead pedal and vice versa. The back of the mat will turn silver and the pedal will have black scuffs. In case you care. At least thats what happened to mine
kyle116 is offline   Reply With Quote
The Following User Says Thank You to kyle116 For This Useful Post:
Busybee (01-06-2020)
Old 01-06-2020, 01:15 PM   #21492
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Good to know to tane precautions!
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 01-11-2020, 07:11 PM   #21493
mrg666
pessimistic skeptic
mrg666's Avatar
Stock valve springs failed outside recall and I got GSC 5756 valve springs installed with a fresh set of spark plugs this week. It was expensive since my warranty was void. But I had the option of upgrading the springs since I was paying for the service. It drives okay so far.
Old 01-12-2020, 05:42 PM   #21494
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Snuck in a rinseless wash using my tiny ass garage. I had to open the door and reposition the car to do the other side 😆 .
Topped it with a Sio2 Sealant for my coating.
It was only clean for 2 minutes, but worth it.
RToyo86 is online now   Reply With Quote
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
MCTeeJ (01-14-2020), Myriad (02-13-2020)
Old 01-13-2020, 08:03 AM   #21495
RickyBobby
Drives: 2013 Firestorm FR-S AT
Your 2014 is not on the valve spring recall list. It has/had the improved valve springs.
Just curious why you went with the GSC 5756 valve springs and not OEM. Are they better than OEM?
Did a dealer do the install or someone else?
RickyBobby is offline   Reply With Quote
Old 01-13-2020, 09:27 AM   #21496
Renault Discordia
Giant Robots and Stuff
Renault Discordia's Avatar
Drives: Oceanic 2019 86 GT (6AT)
Took the girl mudding this weekend for the first time, trip up to Western PA. I swear, I'm learning more and more things about this car as time goes on. Still hella responsive in mud, I think the VikingContacts are doing what I wanted them to do. Definitely needs a bath before I throw my OLM VLs on her, though. lol
Renault Discordia is offline   Reply With Quote
The Following 6 Users Say Thank You to Renault Discordia For This Useful Post:
beltax90 (01-13-2020), ElijahF (01-23-2020), Magyarman (01-13-2020), MJones_RB (01-13-2020), Myriad (02-13-2020), Ultramaroon (01-13-2020)
Old 01-13-2020, 10:39 AM   #21497
Pbrown
Drives: 2013 Scion FRS Raven
Originally Posted by mazeroni View Post
I continue to ponder my throwout bearing. On cold mornings it squeals until I touch the clutch, then the sound goes away. The colder it is, the more pumps of the clutch it takes it make it shut up. I'm told it may be a lubrication issue, and as the bearing warms up it properly lubricates and that is why I only hear it during the winter. I may have had the issue last winter, but it was never this loud.
Based on other opinions it sounds like a somewhat common and not entirely dire situation. Some people say it could go in 100 miles, while others suggest that it will last forever so long as you are okay with noisy startups. As far as I can tell the clutch is in overall great shape.
I called a local shop and they said around $1200 for parts, labor, and resurfacing the flywheel.
I'm down to driving around 4K miles a year with very little clutch usage, so I'm wondering if I can keep it alive until Gen 2 hits the market.
Oh, also the Firestone Firehawk 500 tires are really, really good. I think better than the MPSS at about half the cost, especially in the cold. A little soft on initial turn-in, but still great. Got them about a month ago. No regrets.
Had the same issue. Thought I too could make it to the next gen but alas it really got bad and ended replacing the entire clutch. Soooo much better now.
Pbrown is offline   Reply With Quote
Old 01-13-2020, 01:26 PM   #21498
mazeroni
Drives: 2013 Scion FR-S Series 10
Yea, I'm scheduled to go in next Monday to get the entire clutch assembly replaced. After reading up on it more, while I'm certain I could probably go another 6-12 months without issues, it wouldn't be worth sacrificing my flywheel and transmission if the bearing decides to grenade.
I'm still working out OEM vs generic Exedy parts with the shop. The supplier isn't getting back to them. With the generic parts, it should be about $1050 total for parts and labor and resurfacing the flywheel. Right now they are saying $1250.
Not as bad as I expected. Some people were saying $1600-2000.
mazeroni is offline   Reply With Quote
Old 01-13-2020, 01:41 PM   #21499
Maybe they have lower overhead in Tennessee -
korhun (01-14-2020), mazeroni (01-13-2020)
Old 01-13-2020, 09:18 PM   #21500
mazeroni
That's really, really creative. No lift. No problem.
The Following 2 Users Say Thank You to mazeroni For This Useful Post:
humfrz (01-13-2020), korhun (01-14-2020)
Old 01-14-2020, 03:19 AM   #21501
mrg666
pessimistic skeptic
mrg666's Avatar
Yes, my car wasn't in the recall but the springs failed anyway. I am not sure if it was related to FI or just a defective part. Dealer did the work and asked if I wanted to go with an aftermarket spring set with better specs since I am paying for it anyway. Since my engine is boosted, I went with GSC 5756.
Old 01-14-2020, 10:19 AM   #21502
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
A long time family friend built something similar back in the 40's. He built a garage with an apartment above were he and his wife lived while they constructed their forever home. He was a design engineer and used coated steel I beams for the main house structure. (You can see them in the house to the right in the photo.) His garage was in the side of a small hill. He poured a concrete ramp that ran from the garage back door up to the top of hill. He laid a tower of bricks at the back of the garage offset from the back door that came level with the ground. He place an I beam on it's side on that tower that ran parallel with the sides. The I beam acted as one side of the makeshift hoist. being offset you could drive a small car up one side or a larger car up the other.
I can't find a photo of it but thanks to Google Earth I have a snip showing the garage from the front. (Part of the main house is visible too.)
The Following 3 Users Say Thank You to Stephen W. For This Useful Post:
ElijahF (01-23-2020), humfrz (01-14-2020), mazeroni (01-14-2020)
Old 01-14-2020, 12:07 PM   #21503
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
Fixed a pesky little exhaust leak today with some RTV sealant and a new gasket.
hpanju is offline   Reply With Quote
The Following User Says Thank You to hpanju For This Useful Post:
humfrz (01-14-2020)
Old 01-14-2020, 04:23 PM   #21504
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
If that doesn't hold i recommend remflex gaskets. They are some THICC gaskets.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
hpanju (01-14-2020)
