CANADA Canada
Old 12-27-2019, 08:47 AM   #15
86TOYO2k17
Drives: 2017 toyota 86
Boostane has done and posted many dyno tests as well as independent dyno testing showing it works.
Old 12-27-2019, 09:20 AM   #16
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by JDM_Import View Post
Who said anything about 8oz of RaceGas? You need boost and 32oz of RaceGas to make that kinda power.
In my next post I said that I read it wrong...
Old 12-27-2019, 03:00 PM   #17
RFB
RFB's Avatar
Drives: FRS
The 2 or 3 brands of octane booster that really work are no substitute for real high octane race gas available from tracks and some race shops.
Their real value is for 94 tuned cars in areas where 94 is not sold or when it is out of stock in your locality , or when high octane race gas is unavailable to mix in lower octane fuel.
I've used TORCO in my FRS since 2012, stock and boosted, when I got a bad batch of 94 that showed knock, in travel through areas with no 94, or at Mosport , Cayuga etc. when the pumps are closed. The small amount (of TORCO) required to bring it up to 94 makes it economical.
In those conditions of over 7 years use, no problems were caused. All it did was leave an orange colour to the plugs and cat, and the cat did not plug up.
I am assuming the new competitors to Torco are similar.
RFB is offline   Reply With Quote
Old 01-02-2020, 01:03 PM   #18
86Tony
Drives: 2015 AOZORA EDITION
You can get vp race gas and e85 locally.
86Tony is offline   Reply With Quote
Old 01-06-2020, 07:13 PM   #19
SpankNapkin
Drives: 2013 Subaru BRZ
E85 in the GTA? Where? And how much $$?
SpankNapkin is offline   Reply With Quote
Old 01-13-2020, 06:30 PM   #20
86driftcar
86driftcar's Avatar
I'd like to know the answer to this too...
86driftcar is offline   Reply With Quote
Old 01-14-2020, 09:53 AM   #21
RayRay88
Drives: 2017 86 860 Special Edition
Last I checked, only FT86Motorsports carried E85. You can always import it by the barrel yourself. VP and race gas can be bought by the barrel pretty easily if you know where to check.
RayRay88 is offline   Reply With Quote
Old 01-14-2020, 04:41 PM   #22
wparsons
wparsons's Avatar
Buying by the barrel is hugely cost prohibitive unless you're only using it for special occasions. You also need to be able to store it properly to keep moisture out of the drum once opened.
A 5 gallon drum (19L) is like $80-$100 Canadian IIRC, and a 55 gallon drum (208L) is like $500-$800 Canadian (depending on brand, etc), plus shipping.
Touge Tuning was selling it for about $2.50/L a while ago, not sure if they still do at all or what the prices are like now.
Assuming the cheapest prices, you're still looking at almost double the cost of pump gas, plus then have to take into account the extra consumption from it burning richer. It's way better than traditional race gas, but still not cheap at all like it is down in the US where it's usually cheaper than regular pump gas.
Not sure about the RaceGas additive, but Boostane would need about 12oz added to a full tank to bring 93 octane up to 100 octane, and a can of 32oz is under $30 Canadian (based on exchange only, haven't looked to buy it locally). Much cheaper than e85 on a per tank basis.
flickr
Old 01-14-2020, 05:33 PM   #23
RayRay88
Oh I agree 100%, just answering the question above. It's really not worth it at all for us up in Canada, but for those odd few occasions that call for it, it can be found.
I've seen few amateur race teams buy it in bulk, or a few buddies get together and split a barrel or two over the summer.
Old 01-15-2020, 03:04 AM   #24
Turbo
Drives: FR-S Turbo
Is boostane available in Canada? When I first when shopping for an octane additive it wasn't.
I saw Sasha using RaceGas so I tried that and it's been great.
Turbo is offline   Reply With Quote
Old 01-15-2020, 06:42 AM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
I've seen this article at Touge Tuning. I may try it. I see it at a local shop.
https://tougetuning.com/do-octane-bo...roven-results/
Old 01-15-2020, 10:28 AM   #26
Turbo
Drives: FR-S Turbo
Thanks, Glenn!
Nice that it's available in 5 gallon pails. Looks like that will drop the cost by about 50% compared to buying the 32oz cans.
Old 01-19-2020, 06:13 PM   #27
JDM_Import
Drives: Boosted Toyobaru
Thanks for sharing some good points. I also see real real value in going from 94 Octane to approximately 99-100 Octane.
Orange plugs will definitely happen with octane boosters. In regards to that bad batch of 94 Octane you experienced... its always good to have 91 Octane back up map!
JDM_Import is offline   Reply With Quote
Old 01-19-2020, 06:16 PM   #28
JDM_Import
I rather go with an Octane booster any day!
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
Road Race Engineering(RRE) FRS Custom Tune StancedLifestyle Software Tuning 0 03-25-2014 01:41 PM
Road Race Engineering Tune Wes Software Tuning 6 03-23-2014 02:25 PM
Visconti Tuning: EcuTek STG1 Pumpgas + E85 + RaceGas Calibrations Visconti Engine, Exhaust, Bolt-Ons 177 12-24-2013 01:29 AM
because racegas Silverdub Forced Induction 14 06-07-2013 07:50 PM
