Old 01-01-2020, 09:39 AM   #1
Open Loop
2013 FR-S Whiteout / SSC
Brake pedal feel issue
Hi everyone. My 2013 FR-S with 60k miles (solo spec coupe autocross/time trials car) is exhibiting an unexpected issue with brake pedal feel. First application of the pedal while driving seems to have a bit more travel than the second application immediately thereafter. My initial thought is brake master cylinder, but I can't feel any sinking of the pedal with constant pressure on it. This issue seems to have arisen after the racing season ended and when the car gets parked for a week or so without being driven, left outside but under a carport. No apparent buildup of rust on the rotors. I am interested in whether anyone has experienced this before. Thank you.
Open Loop is offline   Reply With Quote
Old 01-01-2020, 10:40 AM   #2
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
When was the last brake fluid change\bleed?
skylinekin is offline   Reply With Quote
The Following User Says Thank You to skylinekin For This Useful Post:
strat61caster (01-01-2020)
Old 01-01-2020, 11:32 AM   #3
Open Loop
Middle of last season Stoptech 660.
Old 01-01-2020, 12:59 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would agree with your diagnosis given the pedal feel, however i would try flushing the lines first to be hopeful for some air in one of the lines before going through the ordeal of changing the brake booster.
Old 01-01-2020, 01:42 PM   #5
skylinekin
skylinekin's Avatar
How worn are the front and rear brake pads?
Old 01-02-2020, 07:40 AM   #6
Open Loop
Shouldn't I just replace the master cylinder and leave the booster in the car? I don't think it's exhibiting any symptoms of a bad booster.
They're OK. Half worn at most.
Old 01-03-2020, 04:38 AM   #7
Gazzabean
Drives: Toyota GT86
Buy a brake fluid moisture tester from amazon for £5. Place into reservoir, if it flashes orange to red, you need to change it out. What you’re experiencing is similar to me. What is happening is the heat from braking is actually boiling the “water” inside the brake fluid. Causing the brake line to expand. If you leave the brake fluid in there, it will corrode your brake lines, soften your pedal dramatically and therefore decrease stopping power. I have racing fluid and SS braided lines with stock callipers, EBC Grooved and EBC yellowstuff pads. You may not need the racing fluid as it is extremely expensive for a complete change, but I wouldn’t advise buying DOT 3/4/5.1. Somewhere in between. If you’re not sure how to bleed the system in the correct order and what steps to take, or any questions at all, PM me.
Hope this helps!!!
Gazzabean is offline   Reply With Quote
Brake firmness/pedal feel Hyper4mance2k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 05-22-2019 01:22 PM
Clutch pedal/transmission issue ft86chiver Issues | Warranty | Recalls / TSB 3 06-27-2016 05:19 PM
How to fix light feel with the clutch pedal? hot86lova Scion FR-S / Toyota 86 GT86 General Forum 8 08-04-2014 02:06 AM
Disappointed brake pedal feel, what am I doing wrong ZionsWrath Other Vehicles & General Automotive Discussions 12 11-15-2013 03:03 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 01:29 PM
