Old 12-28-2019, 09:47 PM   #15
Stomachbuzz
Drives: 2013 FRS
Originally Posted by isaiah990 View Post
The metal rapping sound is what I’m trying to figure out, I thought it was part of the misfire
-I’ve swapped coil packs and the misfire remains on cylinder 4
-cylinder misfire occurs constantly after 15 seconds when idle rpm drops on cold start
-When I unplug coil pack #4 right after I start the car it causes it to stall. When I unplug the same coil pack after the misfire occurs or 15 seconds after start it has no effect on the idle
Could this noise be a failing injector?
I'm fairly confident that metal rapping sound is not from the engine itself. That would be an extremely alarming sound to come from the engine core.
Almost certainly from a belt-driven accessory or pulley.
...unless your valve spring broke...
I notice you have 2013 FRS.
A broken valve spring or non-operational valve would explain pretty much all of these symptoms.
Wouldn't quite explain the whole 15sec thing though.
At this point, I suppose it's pointing more towards an injector issue.
I guess make sure there isn't an injector plug loose.
Again, not trying to be vague, but these audio/video diagnoses suck with the poor audio quality. Very hard to determine exactly where the noise is coming from. Like higher, lower, left, right, etc.
Why don't you use a stethoscope or long screwdriver to determine more specifically where the noise is coming from
Stomachbuzz is offline   Reply With Quote
Old 12-28-2019, 09:52 PM   #16
Stomachbuzz
Drives: 2013 FRS
Just watched the 2nd video.
You definitely got at least 2 issues going on there.
Motor is missing pretty bad, and then there's that metal sound.
Metal rapping sound is far too slow to be from the engine internals.
Almost sounds like you have a nasty exhaust leak as well.
Why are you putting your hand down into the bottom of the engine bay in the video?
Old 12-28-2019, 10:00 PM   #17
isaiah990
Drives: Scion FR-S
I’m not sure what the metal rapping noise is from as it comes on at the same time it begins to misfire. And I cropped the video, I was unplugging the coil pack to see if it it had an effect or not
-Sheesh now an exhaust leak, I’ll have to check that out. What noise is the exhaust leak making?
isaiah990 is offline   Reply With Quote
Old 12-28-2019, 10:38 PM   #18
Stomachbuzz
Drives: 2013 FRS
Exhaust leak is a flange leaking a bit of air. It will create like a raspy, muddy, air puffing noise. You mentioned aftermarket exhaust, you might want to recheck your flanges for leaks.
Engine seems to start at like ~1800rpm.
The exhaust-leak-like noise is most prominent in the beginning. It stops sharply at 8 seconds in the 2nd vid.
At that point, the engine slows down (maybe 1000rpm), the exhaust leak noise goes away, and the metal rapping starts. Although I'm 50-50 if I can very faintly hear the metal rapping (at higher speed) starting at like ~6 seconds. Could just be my imagination.
At 10 seconds, motor seems to speed up slightly (maybe 1250 rpm). No real other changes.
Stays mostly the same until 24 seconds when you seem to unplug the coil.
Motor slows down again (like 800rpm) and seems to miss more. Or motor sounds slower due to cylinder missing.
I guess the "exhaust leak" sound could simply be how your aftermarket exhaust normally sounds, but I wouldn't expect the microphone to pick up your exhaust note (from the tailpipe) so prominently while recording from inside the engine bay.
P0463, u0122, and P0301 Cylinder 1 misfire Shark_Bait88 Issues | Warranty | Recalls / TSB 0 08-12-2019 06:34 PM
Recurring P0354 P0352 Mr.Scion Issues | Warranty | Recalls / TSB 8 02-12-2019 12:56 PM
P0354 Ignition Coil Malfunction Trending Gords_zenith Issues | Warranty | Recalls / TSB 8 05-15-2014 01:41 PM
Misfire Jono AFRICA 49 12-12-2012 06:01 AM
