Old 10-21-2018, 09:45 PM   #15
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Based on all of the replies, the problem is that you bought an automatic when the twins clearly prefer to be manual. Take it back to the dealership and see if they’ll swap the correct transmission into the car. Just kidding... but seriously, it’s under warranty, let the dealership work on it.
NCtoBRZ is offline   Reply With Quote
Old 10-23-2018, 07:08 AM   #16
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
keep it in manual mode and rev the piss out of it. Never let it under 3k RPM. The best cure for the torque dip (that does not include re-tuning or modding) is to never let the car run in the torque dip RPM range.
guybo is offline   Reply With Quote
Old 12-02-2018, 10:15 PM   #17
csol
Exact same problem I'm having..
csol is offline   Reply With Quote
Old 11-14-2019, 07:37 AM   #18
kishi23
Drives: TOYOTA GT86 2014
95% Direct Injectors
95% clearly for me is Direct Injector issue, happens and experienced the same issues and hiccup.
kishi23 is offline   Reply With Quote
Old 11-14-2019, 08:22 AM   #19
kev0
Drives: '14
Any other symptoms? Did you get any codes? Did you replace the seals or the injectors itself?
kev0 is offline   Reply With Quote
Old 12-22-2019, 08:56 PM   #20
entaroadum
Drives: 2013 Subaru BRZ
I'm interested in this. I've had this behavior too, especially when going uphill in 2nd gear between 2k and 2.5k rpm
Is there a method to confirm it's indeed related to DI? and which one is the problematic one, it would suck having to replace all 4 of them at $170 each.
entaroadum is offline   Reply With Quote
Old 12-28-2019, 02:47 AM   #21
kishi23
No Check Engine Lights, You just feel your car under powered and hesitating on the range of 2500~3500 RPM.
Glad 2 months before warranty expired I noticed and fix the issue.
Old 12-28-2019, 02:48 AM   #22
kishi23
It might be spark plugs. When was the last time you change your plugs?
Old 12-28-2019, 10:48 PM   #23
entaroadum
about 5k miles ago. BTW it had the same behavior before and after the change.
engine, hesitation, rpm, stutter
"Scraping/Scratching" noise on acceleration? Berzerk Issues | Warranty | Recalls / TSB 18 09-30-2018 12:28 PM
Jackson Racing Supercharger Initial Impression from an "Average Consumer" bobsacamenoh Forced Induction 8 09-09-2014 01:03 AM
Switching back to 17" Wheels from 18" for acceleration feel? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2014 08:35 PM
"Buzzing" From behind the steering wheel under hard acceleration husker741 Issues | Warranty | Recalls / TSB 13 06-30-2013 02:18 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
