Old 12-15-2016, 06:38 PM   #113
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Bowen View Post
But for the track I think I'll pick up the +35s. The poke with my camber setup will help make the wheels fit inside of the wheel wells.
You're speaking visually correct?
Because I couldn't get my +45s to rub even when I pulled the springs out.
ineedyourdiddly
Old 12-15-2016, 06:44 PM   #114
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Oh yea I'm talking visually, previously in the thread people were complaining that the 35s had way too much poke with 245s, and the only way to correct it was with some camber.
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 09-20-2017, 07:29 PM   #115
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Originally Posted by Mad_Mike View Post
I fit 245/40 rs3s on completely stock suspension fine with +45, but you can't run any more camber than stock spec. I've done 3 autoxs with them with no issues aside from wanting more camber.
That's good to know ! I think I found a deal on RPF1s with +45 ... even though still it's looking like the +35 a better choice. Especially since I think I'll stay stock suspension for a while.
rookietopro_frs is offline   Reply With Quote
Old 09-29-2017, 02:29 PM   #116
Jordanwolf
Rice King
Jordanwolf's Avatar
Hey friend, would it be possible to get a birds eye picture of the front wheels poke, much like you have for the rear end. Otherwise, these pictures are great for reference ty
Originally Posted by wgnzlz View Post
Got the tires mounted today and put them on the car to see what it looks like at the stock ride height. Excuse the picture quality, they were taken with my phone.
PSS mounted on wheels, 39.3lbs.
Attachment 28850
Stock wheel and tire, 40.9lbs.
Attachment 28851
245/40 vs 215/45
Attachment 28852
Some pictures on the car.
Attachment 28853
Attachment 28854
Attachment 28855
Attachment 28856
Attachment 28857
Attachment 28858
Attachment 28859
Attachment 28860
Attachment 28861
Attachment 28862
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 12-28-2019, 06:57 AM   #117
Deisou
Drives: 2013 Subaru BRZ
+45's rub on the inside fender liners at full lock, it's really minor if you're on 245's, might loose a string of rubber on the brake line bracket, bigger tires may have more of an issue.
Will this (RPF1 17x9 +45 with 245/40 tyres) happen even on coilovers? And will that be the only issue with rubbing? No touching tie rods?
I'm in the process of making this same decision of +35 or +45, and I prefer the look of the +45s but it seems the +35 has less rubbing issues.
Deisou is offline   Reply With Quote
Old 12-28-2019, 10:35 AM   #118
Vital
Drives: 2015 BRZ
No you will not have rubbing issues on Coilovers. Coilovers dont have the spring perches like the OEM shock/spring so you'll have more clearance. Typically a lower offset is desirable for clearance and looks, but its all personal preference. You'll be fine with a 17x9 +45 on coilovers.
Old 12-28-2019, 01:24 PM   #119
strat61caster
Yes, wheel to fender liner clearance is not affected by aftermarket coilovers. Some cars may be different, as above I use a 5mm spacer with extended studs and am quite happy.
I was under the impression 45s rubbed on stock struts but apparently others disagree, I never tried it.
No other rubs to my knowledge.
ineedyourdiddly
Old 12-30-2019, 06:47 AM   #120
Deisou
Thanks for the reply. I'm on coilovers so not too worried about the clearance around the stock struts anymore.
But if the tyres rub the the fender liner with +45 without spacers but don't rub at all with the +35, I'd be tempted to go the +35 despite the slightly more flush look just to avoid using spacers.
Sent from my SM-G965F using Tapatalk
Old 02-17-2020, 10:39 AM   #121
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Ashame these don't come in +40 would be the best fitment between the 2 options
SuperTom is offline   Reply With Quote
Old 03-10-2020, 09:43 PM   #122
ciller
Drives: 2017 Toyota 86
Would Enkei RPF1 Wheels 17x8 +45mm be really sunken in and look bad? I would be getting coilovers at some point at the end of the summer (if that can fix anything).
Everyone here seems to prefer the 9's but 8's still seem like a good improvement over the stock rims. I'm less interested in looks as I am in maximizing the performance of the vehicle. What specific trade-offs are there? More traction versus less weight/better fuel economy? I won't be putting a turbo or supercharger on it (at least not for awhile) and I don't want to put too much tire on the car for its current power levels.
Making the right wheel choice is harder than I thought it would be.
ciller is offline   Reply With Quote
Old 03-10-2020, 11:48 PM   #123
Chuckable
Help, 17x9 +35 or +45 RPF1?
Sorry I don’t have a better picture, but here is 17x8+45 with a 245/40/17 tire.
If you ever plan to use a big brake kit, the 17x9 often causes fitment issues.
Chuckable is offline   Reply With Quote
Old 03-11-2020, 12:38 AM   #124
ciller
Looks great!! I think Ill go with the 17x8 +45s then!
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 07:23 PM
