Old 12-27-2019, 08:44 PM   #211
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by jflogerzi View Post
I wonder who the OEM is..
more than likely, CN Light...
Old 12-27-2019, 08:45 PM   #212
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Osram are oem. D4S 4900k
-B
HeresMyMind is offline   Reply With Quote
Old 12-27-2019, 08:46 PM   #213
soundman98
soundman98's Avatar
Yup I saw there bulbs as well. Leaning towards morimoto 5500k bulbs. 3 sets for the price of one set of the osram's
I need to do some research
back in the day, the osram's were impossible to find, and people were paying twice the value to get a pair...
the osram's are significantly higher quality than the TRS bulbs. but if you don't care about quality, then it really doesn't matter. osram's are somewhat of a no-compromise design, the cheaper variants compromised somewhere in the build quality to lower the overall cost
Old 12-27-2019, 08:49 PM   #214
jflogerzi
jflogerzi's Avatar
I care about quality but I am more about bang for buck. Are they that much better... To justify the cost.
2013 Series 10 FRS #553
Old 12-27-2019, 09:27 PM   #215
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
looking for a glass version of the factory foglights. I remember reading that there was a part number from a previous gen forester that came with them. Any help would be appreciated!
jbsali is offline   Reply With Quote
Old 12-27-2019, 10:04 PM   #216
soundman98
soundman98's Avatar
probably not that much better.
Old 12-27-2019, 10:27 PM   #217
jflogerzi
jflogerzi's Avatar
Well osram CBI 5500k HIDs are on there way. It's only money
Old 12-28-2019, 12:56 AM   #218
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://www.ft86speedfactory.com/fog...l#.XgbuAiWIaEc
Old 12-28-2019, 01:22 AM   #219
Irace86.2.0
I’m going to upgrade my wife’s Audi Q5. The stock light output of the D3S Philips bulbs is shit for HIDs. My Morimtos are much better, even at 6500k. I was thinking of doing new HID bulbs for the headlights then doing dual LED fog lights. Does anyone have any experience with these types of bulbs? The idea is to have a white fog light and a yellow/amber fog light for when it is actually foggy. I think the low LED bulb will complement the HID by saturating the field up close. I don’t want a LED that disperses light all over and blinds oncoming drivers, so I don’t know if I need to retrofit projectors, and I don’t want it to significantly different in output from the headlights, so it all matches. Does anybody have any ideas?
Old 12-28-2019, 08:30 AM   #220
soundman98
soundman98's Avatar
do you understand how they change modes? they work by you having to turn them off and then back on again to change. in my experience with other products, it generally means that they are mind readers, and half the time, will start in the opposite setting you desire.
if you're concerned about blinding others, with the design of the shallow reflector on the q5, you're best off retrofitting something. i really like my nolden/rostra fog lights for the same reason of foreground lighting, they do have an angled model that might e able to be adapted to the q5 mounting points with some work.
black:
https://www.ebay.com/itm/Nolden-LED-...cAAOSwj0NUjsbA
chrome:
https://www.ebay.com/itm/NCC-by-Nold...gAAOSwaNBUjssp
the version i've installed on my vehicles:
https://www.ebay.com/itm/Ncc-Nolden-...4AAOSwgQ9Vkk3p
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Irace86.2.0 (12-28-2019), korhun (12-30-2019)
Old 12-30-2019, 05:18 PM   #221
iconic
Drives: 2015 Scion FRS Auto
Can I mount 15 brz oem headlights on a 15 frs? Will I need to rewire anything, as my frs does not have DRLs in the headlights? Im planning on buying these thursday so any information will be much appreciated.
iconic is offline   Reply With Quote
Old 01-01-2020, 10:42 PM   #222
jflogerzi
jflogerzi's Avatar
PT41318130AA that might be for a pair but it's a start. It's a Toyota part number.
The Following User Says Thank You to jflogerzi For This Useful Post:
jbsali (01-02-2020)
Old 01-01-2020, 10:48 PM   #223
jflogerzi
jflogerzi's Avatar
BTW the led hyper flasher is a giant PITA to replace... Dear God. Nothing else to report
Old 01-04-2020, 01:20 AM   #224
DaveB.inVa
Drives: 2016 BRZ Premium
I intend to eventually to follow instructions from a thread to allow the headlight boomerangs to run at full brightness.
I would like to have the boomerang turn off when the signal on that side is activated. I can build a circuit with a relay to interrupt the boomerang circuit when the signal is on and have the relay continue to be powered during the off period of the signal by using a diode and capacitor to keep the relay pulled in.
However, is there a simple module I can buy that does this?
Thank you for any info you can provide.
DaveB.inVa is offline   Reply With Quote
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
