Old 12-24-2019, 08:53 AM   #1
teamhoneybunny
Drives: Toyota 86
Dumb question on oil
Is this the right oil for an 86, internet says 0W-20. Is this the same?
Sorry i did try asking google first.
Cheers
Sent from my SM-G960F using Tapatalk
teamhoneybunny is offline   Reply With Quote
Old 12-24-2019, 08:57 AM   #2
j_ros94
Drives: 2017 Subaru BRZ
Im sure its not the same thing.
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 12-24-2019, 09:32 AM   #3
gravitylover
Not even close.
Old 12-24-2019, 09:40 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Are 20 and 0 the same number? Are 20 and 50 the same number?
I would leave your car in the care of a shop to have your oil changed and ask their advice on the oil you should be using
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Busybee (12-24-2019), Impureclient (12-25-2019), ShadowReaper (12-24-2019), Spuds (12-24-2019)
Old 12-24-2019, 10:09 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Good dumb question.
The Following 4 Users Say Thank You to JD001 For This Useful Post:
bcj (12-24-2019), Busybee (12-24-2019), gravitylover (12-25-2019), Ultramaroon (12-24-2019)
Old 12-24-2019, 10:32 AM   #6
teamhoneybunny
Drives: Toyota 86
A friend just suggested i read the manual but to be honest never occurred to me.. I went straight to Google. I dont want to pay mechanic to top up the oil and coolant.. I should be able to do that myself even though im not mechanicly inclined. I think I remember someone saying it's a specialty oil... proberly so we have to pay them to service it...
Old 12-24-2019, 10:35 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Just make sure you find the "right" hole for topping up the oil... We don't want to find another new thread 'Dumb question - how do I remove washer fluid from my oil?' or ' how do I remove oil from my washer fluid bottle?'.
Old 12-24-2019, 11:00 AM   #8
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
First I would like to hope that you haven't cursed your brz by putting that in, and no not at all. The first number is the viscosity which is different, usually want to keep these low if you are in location with low temperatures.
The second number is the how thin the oil is, and that is wayyyyy thicker to sustain engine oil temperatures that you will probably never reach. The higher the second number the thicker it is and the more it takes to break down under temperature.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 12-24-2019, 11:10 AM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
By "top up" the oil do you mean change the oil and filter?
And 0w20 is extremely common oil amongst new vehicles. Visit any parts store and you'll see a variety of 0w20 synthetics.
The Following User Says Thank You to RToyo86 For This Useful Post:
Spuds (12-24-2019)
Old 12-24-2019, 11:14 AM   #10
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Correct oil and how to change the oil.
Just love all the help..... We all have to start somewhere.
Go To Walmart and buy this
Mobil 1 120758 Advanced Full Synthetic Motor Oil for 0W-20 5, 4.73L
Two important points are:
1. 0w-20
2. Full Synthetic
As long as the oil you buy has those two items you are good.
Amazon sell it here:
https://www.amazon.com/Mobil-120758-...%2C159&sr=8-17
Before you attempt it watch this video. If you feel you can't cope go to a Toyota dealer, they will charge about 60 bucks to do an oil change. The truth is the cost of oil and a good filter is not much less than paying for an oil change.
[ame]https://www.youtube.com/watch?v=sYwSrfjcnVo[/ame]
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
The Following 2 Users Say Thank You to Darth Khan For This Useful Post:
dodj (12-28-2019), Spuds (12-24-2019)
Old 12-24-2019, 12:25 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I mean $30 for oem filter and 5qt jug is still half price. I guess it's not bad if you don't change your oil often. But that's ~$100 a year for me lol
Old 12-24-2019, 12:33 PM   #12
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Don't listen to all these guys. That oil is fine. You just need to put in less to make up for the added viscosity. It's about 3x thicker than normal oil, so only put in about a third as much after you dump the old oil. So about 2 quarts should be plenty. If you fill it back up, you risk overloading the oil pump, which may cause cavitation in the pump, resulting in poor oil flow, and eventual failure of the hub assembly.
Disclaimer: Don't do this.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
AngelGT86Racer (12-26-2019)
Old 12-24-2019, 01:19 PM   #13
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
^ Dood...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 3 Users Say Thank You to venturaII For This Useful Post:
gravitylover (12-25-2019), soundman98 (12-24-2019), Ultramaroon (12-24-2019)
Old 12-24-2019, 01:57 PM   #14
finch1750
finch1750's Avatar
Don't troll someone who doesn't have a clue. At least he came looking for answers. It sounds funny but would be jacked up if dude blew his motor thinking that made sense since he doesn't understand oil obviously.
The Following 4 Users Say Thank You to finch1750 For This Useful Post:
kev0 (06-20-2020), soundman98 (12-24-2019), Spuds (12-24-2019), weederr33 (12-25-2019)
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
might be a dumb question TooChang Scion FR-S / Toyota 86 GT86 General Forum 1 08-05-2014 10:10 PM
Dumb First Question FlamingRectumSyndrome Software Tuning 4 04-05-2014 11:29 PM
Hey dumb question? FullTuneZN6 Engine, Exhaust, Transmission 4 03-06-2013 09:59 PM
Dumb question ExWhyZer0 Electronics | Audio | NAV | Infotainment 2 01-25-2013 06:44 PM
