Drives: '13 Whiteout
Private Mechanic doing Valve Spring replacement
Has anyone done this? I'm in Calif where its mandatory to have this done for registration. It isn't a safety issue so not sure why. Anyway I'm thinking of having a private mechanic do the work and just pay for it. I've just heard too many horror stories about engine failure after the dealers performs the work then the owners are stuck with a 7K bill.
#2 | |
Most of the horror stories were back when they first stated doing them and then taper off as the issue became known. Check with a couple of dealers and see how many they have done and if they had problems. I think you will find they pay a lot more attention to the work now.
| The Following User Says Thank You to Tcoat For This Useful Post: | TommyW (12-21-2019) |
#3 | |
#4 |
Also @TommyW it's important to note you're in california which most likely has a wide spread of dealers that have done this valve spring job before. So as tcoat said you can contact them and have less of a chance of something going wrong.
#5 |
Drives: 2013 FRS
This knee jerk fear over the valve spring recall is like totally unreal lol
Yall know it's like a 12 hour job as per the shop manual, right? Like, the motor has to be removed, and then the heads pretty thoroughly disassembled. It's a lot of labor to pay for. And then you have to pay for the new springs. I have no idea how much they are, but it's laughable to even consider paying for it out of pocket when it's being offered for free. One of the mechanics is a Subaru tech, with all the parts laid out, specific instructions from Subaru, all the tools and equipment to do the job. By now, they have probably done at least 200 of them. Oh, and, by the way, it's free. The entire job, plus oil change, plus coolant, and a few other small trinkets. The other mechanic is a private tech, with none of the parts until you either supply them, or he finds a list of all the parts necessary. He has no instructions, other than his own intuition/experience. Maybe he can find some torque values, but that's it. And all his tools/equipment are generic. This will very likely be the first valve spring recall he's ever done. Oh, and his price is $1000 + parts. Tough call.... If you're THAT worried about it with $$$ to blow, why don't you just let the dealer do it for free, sign off on the recall, and then immediately go to a private shop and have performance valvetrain put in or something? The fear mongering just don't make sense to me. |
| The Following 4 Users Say Thank You to Stomachbuzz For This Useful Post: |
#6 |
Famous Potatoes
Drives: '15 ultramarine
Well there you go. Stomachbuzz has spoken. Nothing to worry about.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | DarkPira7e (12-22-2019), Impureclient (12-22-2019) |
#7 |
Well with all the posts and the lawsuits I’d say that there are concerns. Toyota dealers working on Subaru FA20’s. Then not taking the blame when the motor goes then you have a very expensive problem. I think Coat is right though enough time has gone by to where they should know what the fu*k they’re doing. Good time to get a new clutch installed to handle the FI that’s coming soon
#8 |
Drives: 2015 FR-S
| The Following 2 Users Say Thank You to Impureclient For This Useful Post: | Sapphireho (12-22-2019), soundman98 (12-22-2019) |
#9 | |
Famous Potatoes
| The Following User Says Thank You to Sapphireho For This Useful Post: | Will BRZ (12-22-2019) |
#10 | |
Drives: 2013 FRS
#11 | |
Drives: 2013 FRS
#12 |
well I have a very trusted mechanic that has worked on all but my Porsches for 30:years. I’m sure this is hard for you to understand. Carry on....
| The Following User Says Thank You to TommyW For This Useful Post: | weederr33 (12-23-2019) |
#13 |
Famous Potatoes
| The Following 5 Users Say Thank You to Sapphireho For This Useful Post: | Dadhawk (12-23-2019), finch1750 (12-24-2019), Impureclient (12-22-2019), Norotor (12-22-2019), Teseo (12-23-2019) |
#14 |
Drives: 2015 FR-S
I am a travelling bacon collector with a penchant for kite flying. I have arachibutyrophobia and like long walkways that lead to beaches.
Sapphireho is a former conjoined twin educated in endogamic marital counseling and trained in Sambo. He likes long walks on the beach, is allergic to peanuts and has luposlipaphobia. Also, he's Batman. |
| The Following 5 Users Say Thank You to Impureclient For This Useful Post: | bcj (12-23-2019), NoHaveMSG (12-23-2019), Norotor (12-22-2019), Summerwolf (12-24-2019), Will BRZ (12-22-2019) |
| PCV Valve Replacement with STI Valve | apelpapa | Forced Induction | 30 | 06-03-2022 08:23 PM |
| Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style | Dake | DIY (Do-It-Yourself) Guides | 24 | 10-07-2020 11:56 AM |
| 2013 Scion FR-S Valve Spring Replacement Recall | Aussie | Northern California | 29 | 06-22-2020 01:51 AM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Has anyone considered doing the J02 valve spring replacement themselves? | gutbuster | DIY (Do-It-Yourself) Guides | 15 | 11-04-2019 09:37 AM |
