Old 12-19-2019, 09:54 AM   #169
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Originally Posted by SuperTom View Post
I must confess I am a weight reduction addict in relapse already took out rear spare and tools and will be looking for a lithium battery up front to keep the stock balance.
I had never given this much thought until now. That is quite interesting, retaining the 50:50 split when stripping out weight. Certainly brings a new perspective to my world.
ROFL it's Waffle is offline   Reply With Quote
Old 12-19-2019, 11:35 AM   #170
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by 86TOYO2k17 View Post
what did you do for "DI Brackets/Others -5.5 lbs"
or what page on your thread is this one on.
EDIT: I see the two verus fuel rail covers drop 4.7lbs combined, that plus beatrush crash beam should have me back to OEM weight balance.
You have a 17+ so you don't need the verus aluminum bracket since our years have an area to bolt the bottom to the block.
Then I just zip tied the top bolt hole to a fuel line I think. The second top hole on the ecu I added a ground strap although I don't think its necessary with the bottom bolt doing the grounding.
SuperTom is offline   Reply With Quote
Old 12-19-2019, 12:02 PM   #171
SuperTom
SuperTom's Avatar
Yeah I try to hit weight reduction as a combo. If I take this much off the rear then I take the same off the front to try to keep the stock balance.
Examples:
Shorai Battery / Spare Removal
AC Delete,DI brackets,Windshield Washer / Rear Seat Delete
Front Bumper Beam / Rear Bumper Beam
ACE headers, Lighter FP / Titanium Catback
The car is still a bit light in the rear but I do plan to add in a Non-Aggressive diffuser and possibly a Sard wing.
While still trying to get more weight off the front:
-MPH CF hood
-Titanium Bolts (will take a lot to make a difference)
-Lighter Front Sway Bar, Cusco 16mm
-Maybe Lighter control arms
-Making Shorai Battery cradle lighter with Aluminum
-Chase Bays Clutch line replacement (-1lb)
-Chase Bays Brake Booster/Remove ABS (concerned about the computers reaction)
-Lightening Dash Beam (project in process)
-Dash Sound Deadening Removal
-Removing Front Tweeters
-Replace Headunit with a tablet and mini amp <1lb (Just running Wire to rear speakers)
-Figuring out how to get passenger Radiator fan to run by itself (both shut off when driver side one is unplugged)
-Removing AIRBAG box + wiring in car
-Possible AC condenser still behind firewall
-Possibly Moving Shorai battery to rear but Cabling will add weight but will help with FR/R balance
-Making any Steel Brackets out of aluminum somehow
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Iceman (12-20-2019), why? (12-20-2019)
Old 12-20-2019, 03:03 PM   #172
ROFL it's Waffle
@SuperTom have you taken this obsession from side-to-side (not just front to back)? I've always wondered if suspension is slightly tuned to account for the weight of the driver and no passenger. Maybe it's marginal, but makes me wonder none the less.
Old 12-22-2019, 12:38 PM   #173
SuperTom
SuperTom's Avatar
No my suspension is not tuned or corner balanced. Want to get it light as possible first before paying to do that.
Chase Brake booster/ ABS delete will take a lot of weight off Driver Front side. Will keep power steering as its built into the steering shaft and is only about 6lbs extra
Old 12-22-2019, 03:19 PM   #174
SuperTom
SuperTom's Avatar
Well a great day today got weight reduction and potential power boost at the same time. Got rid of my Hooker Headers FP and replaced it with a straight shot 2.75"/70mm ebay special front pipe.
The ACE 350 headers are shown to have gains with a larger front pipe.
Also lost -7lbs compared to stock front pipe!!
Here is the inside of the HOOKer FP with the cat got completely blown out
Ebay special $75 2.75" FP
Only 5.25lbs
Same inside diameter as my Ti catback
Connect to Faction Fab TI catback, pipe diameter the same all the way through for smooth power!! no more bottle necks with stupid donut gasket connection. Smooth is Fast!
New video not much sound difference but seems more smooth in the higher RPM's. Exotic racecar sound to me!
[ame]https://www.youtube.com/watch?v=yRxMv3lE3kM[/ame]
I will try to get a in cabin driving clip soon
Also down to 2350lbs now! 50lbs to go
The Following User Says Thank You to SuperTom For This Useful Post:
ElijahF (12-23-2019)
Old 12-23-2019, 12:01 AM   #175
jflogerzi
jflogerzi's Avatar
Only 5.25lbs
How the hell are you at 2350 and still street legal?
2013 Series 10 FRS #553
Old 12-23-2019, 12:17 AM   #176
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
That is pretty loud lol interested in hearing some drive-bys. Are you going to keep it like that or will you switch out the front pipe?
Will BRZ is offline   Reply With Quote
Old 12-23-2019, 09:34 PM   #177
SuperTom
SuperTom's Avatar
I would need to swap in stock FP for inspection but that would do it. Weight list on first post. Been reading Miata forums they are a creative bunch
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
jflogerzi (12-23-2019), ROFL it's Waffle (12-30-2019), why? (12-24-2019)
Old 12-23-2019, 09:43 PM   #178
SuperTom
SuperTom's Avatar
I don't have a good setup for driving videos but this should give an idea of the sound. Yes its loud but I love the tone. Cruising at 70 near the end of the clip its very sane.
Also keep in mind all my foam under carpet sound deadening is removed and I scraped out all the tar sound deadening.
Personally I love it and drive close to 100 miles a day on my daily work commute.
[ame]https://www.youtube.com/watch?v=vwRz6SjD-NA[/ame]
new2subaru (12-24-2019), why? (12-24-2019)
Old 12-23-2019, 09:55 PM   #179
jflogerzi
jflogerzi's Avatar
That does have a very nice tone. Windows down I am assuming?
Old 12-23-2019, 10:11 PM   #180
SuperTom
SuperTom's Avatar
No windows were up. I have a wind leak im chasing when I get up to higher speeds and its a windy day out. That's why you only hear it at the end
Old 12-24-2019, 06:27 AM   #181
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I swear my passenger window refuses to crank up all the way. And of course the weather stripping isn't remotely tight by the back of the windows, like it was just never glued on and it is just not meant to be tight there.
Did you put your Ace header on a scale? I've been wondering the actual weight of that, and whether or not titanium headers are significantly lighter.
why? is offline   Reply With Quote
Old 12-24-2019, 07:55 AM   #182
SuperTom
SuperTom's Avatar
Originally Posted by beltax90 View Post
windows up??
sounds sick btw. went single catback and took out the rear seats... don't know if i could handle more than that!
Yeah windows up, its 32 and windy round these parts
All I have is a carpeted piece of coroplast where my rear seats were, the rear seats definitely offer some sound protection
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
