Old 12-22-2019, 12:42 AM   #8793
jflogerzi
jflogerzi's Avatar
Originally Posted by 86TOYO2k17 View Post
Do you have a boost gauge? If you have a vacuum leak at idle post blower it would turn into a boost leak under loads great enough to create boost. A common failure is the recirculation valve, or the plastic fittings have known to fail overtime http://www.ft86club.com/forums/showthread.php?p=1362857.
First i would clean maf, and double check all fittings on intake cold weather makes things shrink and worm clamps don't shrink with changes like spring clamps. could always try spraying some brake cleaner or do a smoke test to find a leak.
When the kit was installed we replaced the plastic connectors with brass fittings. When you say post blower do you mean around the manifold or where the blower connects to the manifold? No on boost gauge. Where is the recirculation value? Picture would help.
2013 Series 10 FRS #553
Old 12-22-2019, 12:56 AM   #8794
86TOYO2k17
Drives: 2017 toyota 86
The black thing in back also known as the bypass actuator valve.
Anything pre engine and post maf could have a vacuum leak. But if it is post the “twin screws” so between blower and manifold or manifold and head it would turn into a boost leak under boost and vacuum leak out of boost. If it was pre blower then your boost and power would not be effected.
Old 12-22-2019, 01:33 AM   #8795
kev0
Drives: '14
Keep me posted on this. Have you done a smoke test yet to see if you have any leaks?
Yup. It was leaking at bypass and the elbow where metal touches metal. Sprintex didn't include seals on there. They cut corners a lot. Getting it done right by Jon Bond Performance.
kev0 is offline   Reply With Quote
Old 12-22-2019, 09:56 AM   #8796
jflogerzi
jflogerzi's Avatar
Question. Where you able to get the charger removed and leave the manifold still on the engine? I am thinking of sending mine in to Jon bond. How did you see the leak at the bypass?
Old 12-22-2019, 08:40 PM   #8797
sam69
Drives: GT 86
You are probably one of few people who have.
What was temps after jacket install?
How long did it take your temps to get that high?
Didn't take that long only a few good longish hard runs and then it would take quite a while (ages) for the temps to come back down due to the heat soak through the entire unit .
With the jacket which was only the prototype which covered only a bit over half of the SC the temps would spike but not as high but would settle very quickly compared to standard.
The new Jacket covers the whole casing of the SC so has to be more effective than what I was running before .
Did find my notes but they are badly water damaged
New laminova/ intercooler core is progressing well and will flow infinitely better.
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
jflogerzi (12-22-2019)
Old 12-22-2019, 09:15 PM   #8798
jflogerzi
jflogerzi's Avatar
So you are designing a better core to go into the SC so in theory you would not need the jacket. If that's the case count me happy to buy one if the price is semi reasonable
Old 12-22-2019, 10:13 PM   #8799
86TOYO2k17
Someday i plan on a built FA20 with the sprintex 335 and if the new core is available I would be interested.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 12-24-2019, 10:14 PM   #8800
jflogerzi
jflogerzi's Avatar
Debating on selling the SC kit in favor of a turbo kit. I am Not ready to give up quite yet on the little SC. Still trying to chase down this dumb high positive LTFT. Next step is to get a shop to smoke test the car and see if we can track down the leak. I just hope the SC is not going to need a rebuild :/ if the leak is between the screws and manifold and before the engine
Old 12-26-2019, 07:35 PM   #8801
kev0
Drives: '14
I hear a whoosh of air releasing in my engine bay when i tirn my car off. What do you guys think this could be? Lasts about 1 second.
It can best be described as a 'sigh' sound or low pitched 'hiss'.
Old 12-26-2019, 08:42 PM   #8802
kev0
Drives: '14
If nobody else is hearing the wooshing sound when they turn the motor off, I'm starting to think that a hose might be connected into the wrong hole in the back of the SC. If that's the case...the car shouldn't even run, right?
Old 12-27-2019, 12:41 AM   #8803
jflogerzi
jflogerzi's Avatar
Got the smoke test done. at both ends of the plastic intake tube after the MAF some smoke was coming out. Is it safe to use some sealant on the intake pipe at both ends? Or do you think they had to much pressure. Would this make sense for an idle vacuum leak? Buddy who did the install did not need it... and I tighten down the worm clamps as tight as they can go...
Old 12-27-2019, 09:08 PM   #8804
sam69
Drives: GT 86
You could just use the new core but still think the core/laminova with jacket would be the ultimate but will know more when ever I get mine back on the road
Have no plans at this stage to make these as has taken alot of work so would need to be put into even a limited production run to make it viable .
Found out Sprintex has a new CEO and apparently he is a car nut and has bought himself an 86 and put a kit on it so will be interesting to see if they do more development work.
Would be good if they offered stage 1 , 2 and 3 kits like others do .
Old 12-27-2019, 09:11 PM   #8805
sam69
Drives: GT 86
Any leaks at all will play havoc and if you over tighten the clamps that can cause issues .
Old 12-27-2019, 09:12 PM   #8806
jflogerzi
jflogerzi's Avatar
Okay understand. Keep us posted and maybe try and share this with Sprintex. Plenty of kits out there still on our twins. Everyone knows heat soak is the biggest issue next to obvious desgin flaws...
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
