Old 12-18-2019, 03:52 PM   #1
dodj
Drives: Rallye Blue BRZ
Battery service life
How much life do you Canadians and northern state Americans get out of a battery?
Myself I usually get 5-6 years on an AGM battery on all my vehicles EXCEPT the BRZ. It seems to need a new battery every three years.
I have a 2013 Sport tech BRZ. In 2016, the factory Panasonic battery couldn't start the car in the cold. So I replaced it with an AGM battery. This morning.....that battery started the BRZ but just barely. Time for a new one again.
You guys out there have a similar experience?
dodj is offline   Reply With Quote
Old 12-18-2019, 06:18 PM   #2
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
My original battery got weak after about 3.5 years and I replaced it.
Now you've forced me to look at my replacement, which is leaking from it's top, causing corrosion...something to deal with, shucks, but thanks.
Running a battery down, like leaving the lights on, just one time even, can cause a wimpy battery to not be able to restore itself.
Our best bet would be a deep cycle battery...why didn't I do that ...
My lifetime experience is that battery life varies greatly, from 2 to 6+ years.
Note: In some forums, members have reported having trouble with short life of Optima agm type batteries, since they moved their production facilities to Mexico...yet my research today shows me that move was ten years ago. Johnson Controls owns Optima. All auto batteries that I've seen in recent years are made in Mexico.
"it's probably from the mexican water. there is a reason they say "don't drink the water" when you go down there
maybe the batteries don't like it either."
Recovering an AGM battery which is difficult to recharge:
ToySub1946 is offline   Reply With Quote
Old 12-18-2019, 06:23 PM   #3
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Running on about 5 years so far on stock battery for my FRS with no issues. I guess I'm spoiled with my California weather.
Could be due to harsh weather conditions, alternator, or maybe starter?
Hopefully others can chime in on the issue.
KMA KiCKz is offline   Reply With Quote
Old 12-18-2019, 07:18 PM   #4
qqzj
Drives: MDX, Camry
I am from CA too. Battery is 6 years and 2 months. I typically get 7-8 years out of them.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 12-18-2019, 07:53 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I'd suggest a block heater if you aren't using one.
If I drive mine another winter I'm installing one as well.
On my Suzuki it was the difference between an easy normal crank to start and be buying a new battery if I didn't plug it in on a particularly cold evening. Night and day difference.
Old 12-18-2019, 07:57 PM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Replaced mine this year fall, so stock one lasted... lil over 5yrs. I live in the state that only have 2 season. Burning hot summer and frozen ice winter (no in between), so lasting 5 yrs isn't bad. BUT of course, I had 2 accident in between those 5 yrs and the shop recharge my battery every time, so you wanna add that to the factor.
Old 12-18-2019, 08:39 PM   #7
7 skulls
Drives: 2014 scion frs
My stock battery lasted 2 years and the replacement would have went down in 2 years as well if I didn't buy a small duracell battery tender. Something in these cars, combined with cold, just eats batteries.
7 skulls is offline   Reply With Quote
Old 12-18-2019, 09:49 PM   #8
dodj
Ya, the barely starting included it being plugged in all night at work...12 hours.
Plus I use Amzoil signature synthetic oil.
Maybe I just need to move to California?
Old 12-18-2019, 10:40 PM   #9
StraightOuttaCanadaEh
Wes
4th canadian winter, going strong. I charge it once in a while
Instagram: @gt86ws
Old 12-18-2019, 11:31 PM   #10
Aluma007
Drives: 2017 Brz
south texas here...3 years....about 30k miles... kaput. :P
Aluma007 is offline   Reply With Quote
The Following User Says Thank You to Aluma007 For This Useful Post:
Grady (12-18-2019)
Old 12-18-2019, 11:45 PM   #11
Grady
Grady's Avatar
Heat kills them!
Old 12-19-2019, 02:34 AM   #12
alan.chalkley
Drives: 4wd zooks
Originally Posted by Grady View Post
Heat kills them!
My original battery is over six years old and still going strong , plenty of hot days and bush fires around here.
alan.chalkley is offline   Reply With Quote
Old 12-19-2019, 09:54 AM   #13
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
Mine gave out after about 3 1/2 years. So about normal maybe since I live in Michigan.
Hot-Lava_Dave is offline   Reply With Quote
Old 12-19-2019, 12:52 PM   #14
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
My original battery lasted 6.5 years. But the car is garaged. My other car is 6 yrs old with original battery and the stop/start function stopped working, which typically means the battery is almost done.
davesrave is offline   Reply With Quote
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Why is my GoPro battery life so incredibly bad? qoncept Off-Topic Lounge [WARNING: NO POLITICS] 5 05-20-2013 02:43 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 08:33 PM
