Old 12-14-2019, 12:42 PM   #1
solidsnake11
Drives: brz
What would be needed for engine dyno?
If I was going dyno an engine on a engine dyno would it start with just the ecm and the injector driver?
solidsnake11 is offline   Reply With Quote
Old 12-15-2019, 06:16 PM   #2
steve99
Drives: FT86
Im just guessing here but
Unless you hack round the secutity, the ecu will want to see all the modules in secutity set dash, imobilisier , authentication and key id reader and a key
Also ecu might keep triggerning limp mode or similar if it doesnt see steering ecu, abs,vsc and stuff as it will think they are broken
solidsnake11 (12-15-2019)
Old 01-01-2020, 08:59 PM   #3
ML
ML's Avatar
Drives: 13 White MT FR-S
When are we just going to get a third party ecu?
Engine Tune Needed for Track Day? Faulkner Engine, Exhaust, Transmission 21 11-21-2018 07:08 PM
HELP needed to diagnose engine noise Docmattic Engine, Exhaust, Transmission 17 01-23-2018 01:42 PM
Help needed! Check engine light after weird traction lights. dillanp86 Engine, Exhaust, Transmission 3 12-08-2016 10:17 AM
Urgent help needed to identify blown engine driftking96 Engine, Exhaust, Transmission 30 06-14-2016 11:32 PM
engine dyno! carbonBLUE Engine, Exhaust, Transmission 21 04-25-2012 09:29 PM
