Old 12-09-2019, 06:00 PM   #71
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by smg1138 View Post
Have you seen any kind of actual evidence of that? People like to talk a lot of trash on the internet, but I've never seen any proof of e85 having negative effects on our cars.
No, I have not. But a friend runs a race shop (well-respected, national-championship winning, etc.) and they do a lot of work on Subaru engines. He's seen it and has recommended strongly against using ethanol in FA20s.
Old 12-09-2019, 08:12 PM   #72
kev0
Drives: '14
A VERY reputable tuner (probably the best for our platform) told me although stock injectors are 'ok' for E85, he wouldn't recommend it for long term use as it is hitting the limits and shortening the life span of my fuel system and will eventually cause engine failure. What should I upgrade besides the injectors?
kev0 is offline   Reply With Quote
Old 12-09-2019, 08:37 PM   #73
new2subaru
Weight Weenie
Drives: 15 FR-S
What exactly does that mean though? It's good for 50k 100k 200k?
Old 12-09-2019, 08:39 PM   #74
new2subaru
Weight Weenie
Drives: 15 FR-S
Hey Pat,
Same, seen what and why? E10 E50 E70 E85?
Old 12-09-2019, 10:32 PM   #75
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't have any more details for you unfortunately. I wish I did, sorry.
Old 12-09-2019, 10:48 PM   #76
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks, Pat. It'll turn up.
Old 12-09-2019, 11:20 PM   #77
Lantanafrs2
Drives: 2013 frs red
What would make the fa20 unable to handle ethanol? Did they use new, unknown materials? I dont buy it.
Lantanafrs2 is offline   Reply With Quote
Old 12-09-2019, 11:30 PM   #78
kev0
Drives: '14
...I actually have no idea. Depends on how often you run it I guess. My tuner just told me to switch injectors as soon as I can to prevent failure.
Old 12-10-2019, 12:13 AM   #79
86TOYO2k17
Drives: 2017 toyota 86
These are two different issues. This thread is discussing long term negative effects from E85 and not about maxing injectors because boosted.
People are worried E85 will either destroy fuel lines or because it is hygroscopic it will cause rust to form inside the gas tank or engine.
What you are referring to is when boosted running around 300whp on E85 you are maxing out stock injectors and it is not good to be running over 90% duty cycle ideally you want to be at 80% allowing you to have both more room to spray more fuel incase you have more air/boost coming in for various reasons as-well as not over heating the injectors causing premature wear and failure. But this is less from the inherent nature of E85 and more from demanding more fuel from the system because you are boosted and E85 has less energy requiring more fuel.
Old 12-10-2019, 01:31 AM   #80
kev0
Drives: '14
Ahh okay. My bad for the confusion. Are you running 700cc injectors for your setup?
Old 12-10-2019, 08:37 AM   #81
86TOYO2k17
No, I am on stock injectors because i am not on E85. I use 92+WMI. I would listen to your tuner and go with whatever injectors he recommends, sooner would be best.
Old 12-10-2019, 01:07 PM   #82
DarkSideFRS
Drives: 2013 pearl white FR-S
Ok...lots of conflicting info here.... Assuming an N/A setup (prob with aftermarket headers), is it safe to run e85?
Pat says no with no evident proof, and some swear there are no issues at all in relation to the health of the fuel system and motor...
DarkSideFRS is offline   Reply With Quote
Old 12-10-2019, 01:25 PM   #83
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Running E85 will cause the engine to fail at some point! It may take 300k miles or so but it will eventually fail.
Old 12-10-2019, 01:35 PM   #84
PulsarBeeerz
Drives: JRSC BRZ SOLD
People having been running E85 since 2013 on this platform without problems. You always have someone say "My tuner said.." and they are always the best tuner somehow.lol Tuning engines and living with a platform day to day aren't the same. I saw one guy with bad DI seals blame it on E85 but they have been known to go on gasoline. and he also tracked on faulty coil-packs while on that E85..
PulsarBeeerz is offline   Reply With Quote
Long term E85 use redrocket89 Engine, Exhaust, Transmission 92 06-28-2021 05:40 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 07:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
